Old 10-15-2007, 02:49 PM   #16
sport10's Avatar
Originally Posted by rregl0612 View Post
I any metal to metal contact will do it.. your throttle linkage rubs on the aluminum post for ex..
Any of your linkages..could cause a problem check for rubbing metal to metal..
The pipe connection I had happen to me.. my seals went bad and it must have taken me 2 race days to figure out what the heck was causing this mysterious right turn glitching..
Assuming you tried Rebinding the Reciever to the TX..??
I have also had switches and batteries go bad on me .. deffinately worth a check.. even grab a buddies Batt just to see if there is any difference..
I know several racers here who have all together done away with switches for this purpose..
I will indeed say that glitching is by far the most annoying part of this hobby.. It ranks right up there with changing diff fluids..!!!!
Spectrum operates in the 2.4 GHZ band and is not acceptable to metal to metal noise. He just needs to try to rebind the reciever to the transmitter, look for loose connections, or a bad battery. If that fails try a new reciever.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 10-15-2007, 03:01 PM   #17
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
You mean it is not susceptible...
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 10-15-2007, 03:04 PM   #18
rregl0612's Avatar
Trader Rating: 33 (100%+)
Haha... Good to know .. one more thing you can check off..
On another note.. do you have a spektrum radio.. or a M8 .. or other radio.. if you have a M8 is the mod done to put the antenna in the case like the factory antenna... you may have a loose connection there as well..
This is probably the last place I would check..
Just trying to come up with Ideas..
rregl0612 is offline   Reply With Quote
Old 10-15-2007, 04:54 PM   #19
chris72983's Avatar
Found the problem. It was the switch in the car it had a nearly broken wire in it. I tried a new switch and problem gone.......for now anyways. I hope it stays that way.
Thanks to everyone for all the help. I would have never have thought to have tried a new switch. Oh well, live another day to learn something new.
[COLOR="Magenta"][FONT="Arial"]Schumacher Mi3[/FONT][/COLOR]
[FONT="Arial"][COLOR="Lime"]Jammin X1CR[/COLOR][/FONT]
[COLOR="black"][COLOR="Red"]North Hills Hobbies (601-696-9767) Meridian, MS[/COLOR][/COLOR]
chris72983 is offline   Reply With Quote
runaway car problems thinguy10 Electric Off-Road 10 10-18-2013 11:10 AM
DX2.0 Glitch? monkeyracing Radio and Electronics 3 03-25-2008 10:51 AM
Feedback For Runaway Imdadundada7 Buyer/Seller dispute and Feedback discussion forum 0 03-06-2007 01:31 PM
runaway azfabguy Buyer/Seller dispute and Feedback discussion forum 1 02-12-2007 02:37 PM
Stupid Curbs... I had a runaway B3boy Electric Off-Road 3 04-12-2003 05:31 PM
