Old 10-11-2007, 06:18 PM   #1
Default Clutch Bearing Life.
I was just wondering how often you all change your clutch bearings. This season I have been running the cheap bearings from Carolina RC. I replace my clutch bearing every week. They still feel pretty good but I don't want to take a chance of one going out during a race. Plus they are cheap. I was thinking about using a better grade bearing and was wondering if it was worth it. Give me some input.
www.roarkfabworks.org
tubehead is offline   Reply With Quote
Old 10-11-2007, 06:22 PM   #2
Advantage Racing Bearings are the best. With any other brand you will be replacing them every day. Keep using them.
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Machine's R/C H is offline   Reply With Quote
Old 10-11-2007, 06:36 PM   #3
Are you using Advantage Ceramic bearings. I'm using their standard bearings.
Old 10-15-2007, 05:58 PM   #4
Anyone else have any input?
Old 10-15-2007, 06:02 PM   #5
hiliter03's Avatar
YAH WHATEVER YOU DO DO NOT.....DO NOT GET ANY KIND OF LIQUID ON THEM.FUEL,WATER,ENGINE SPRAY.......ANYHTING!!!! AND AVID BEARINGS ARE THE BEST.$1.OO DOLLAR,1 DOLLAR YOU CANT BEAT THAT FOR A BEARING AND THEY WORK GREAT,JUST DONT SPILL ANYTHING ON THEM.
hiliter03 is offline   Reply With Quote
Old 10-15-2007, 06:54 PM   #6
pserve's Avatar
The first set I had in my car went for 2 gallons. I bought it used, so I don't know what brand they were. Since then, I've tried a couple different brands, and they've only gone for 1-1.5 quarts before blowing, so I have to change often. I'd really like to find better ones to cut down on that.
On a side note, I've been getting the rubber/metal sealed ones, but I swear that first set were metal on both sides. I'm just going to keep trying different brands until I find some that hold up longer.
pserve is offline   Reply With Quote
Old 10-15-2007, 07:02 PM   #7
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
I run Avid Revolution bearings and usually change them about every gallon to be on the safe side as I would hate to dnf due to bad clutch bearing .
Briguy is offline   Reply With Quote
Old 10-15-2007, 07:41 PM   #8
sickboy's Avatar
Trader Rating: 72 (100%+)
every time i run. at a buck a piece, consider it cheap insurance.
sickboy is offline   Reply With Quote
Old 10-16-2007, 10:42 AM   #9
I use standard bearings in the clutch bell. Metal/rubber seal.
Old 10-16-2007, 12:10 PM   #10
I do the same thing. It just makes sense.
Bruce Edwards
Thanks to:
Go Tech Engines www.racefactorindustries.com
Merlin Glow Plugs www.merlinglowplugs.com
Vantage Racing www.vantageracing.com
Mods by Rocket Ray! email: CowboyRa@sbcglobal.net
satoch is offline   Reply With Quote
Old 10-16-2007, 02:34 PM   #11
houston's Avatar
Trader Rating: 91 (100%+)
Talking
kyosho bearings are probably what were in the 2 gallon run on clutch bearings !! they are the best quality bearings out on the market , just cost $$$$ . personally , i run kyosho cars but use avid bearings in the cluch and hubs , just not on the diffs of the st-r , too much sideplay in the bearings . if you really want long lasting bearings , heat up the bearing on the metal shield side with your heat gun and drop a few drops of a synthetic gear oil in them . i am very experienced and not just a dumbass and found clutch bell bearings being smoother for much longer after starting this method about 2 years ago . also be sure to throw those super worn out clutch bells away a lil tip from uncle Mont
later ,
Monty
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 10-20-2007, 07:52 PM   #12
houston's Avatar
Talking
Old 10-20-2007, 08:19 PM   #13
I second the Advantage Bearings. We have been running the ceramics in both the 8ight and 8ight T and they are awsome. We run the standard bearings in the clutch just for the fact I would probably still change the ceramics just as often just to be safe.
We will be running the ceramics in the clutch at the Worlds Warm-up tho.
Troy Weatherholt
gasser is offline   Reply With Quote
Old 10-20-2007, 09:04 PM   #14
AZRCaddict's Avatar
I have got the greatest life out of Boca Bearings, I still replace them before my qualfiers and mains, you dont have to though.
I'm running the rubber seal bearings they are in their $1 store.
Team EMB
AZRCaddict is offline   Reply With Quote
Old 10-20-2007, 09:47 PM   #15
Joe_Racer's Avatar
Trader Rating: 31 (100%+)
I 100% agree on the Kyosho bearings. I was in the local hobby shop and they were out of the $1 bearings. The only thing they had was a package of Kyosho bearings at $13 for 4. If I didn't buy them I wasn't racing that night. They lasted forever. While I liked how long they lasted that is still to much for 4 bearings.
Jack G.
Mugen MBX-7 Novarossi Plus 4, Mugen MBX-6TR Novarossi P5
RC10 GT2 OS TG, RC10 B4.2 17.5, SC10 FT 13.5, RC10 T4.1 13.5
Joe_Racer is offline   Reply With Quote
Clutch Bell Bearing Issue 843rcguy Nitro Off-Road 18 08-22-2008 10:09 AM
Clutch Bearing Maintenance pracy Nitro Off-Road 18 06-17-2008 07:15 PM
Clutch life Pete G Nitro Off-Road 10 05-24-2008 07:30 PM
Clutch bell bearing problems rltanner Nitro Off-Road 14 02-20-2008 12:52 PM
clutch bearing problems cwalters Electric Off-Road 39 09-11-2006 06:59 AM
