Old 10-08-2007, 06:51 PM   #1
jatoman1992's Avatar
Trader Rating: 4 (75%+)
Send a message via Yahoo to jatoman1992
Default Piston out of Sleeve
ok, i need to get the piston and sleeve out of my stupid force .25 engine and i've tried the technique where u stick some zipties in the exhaust port and move the flywheel around to push the sleeve up but it just wont move. can someone tell me another way to get it out.
thanks
-Tyson
Pre-mix:
Kawisaki KX125-bored out to a 134cc, VForce reed valves, FMF gold series pipe and shorty silencer, phathead racing cyl head w/ interchangeable domes, and wiseco flat to piston
Nitro:
Ofna Ultra LX Pro- Axial .28 1S w/ JP-2 Pipe, Hitec HS5645MG(steering) and Hitec HS625MG(Throttle/Brake)
Electric:
Losi Micro-T- stock
Coming soon: Associated FT B4- stock
Ofna LX Pro as a roller w/ extras- $150
Starter box(1/8 buggy) w/12V battery- $70
micro T- $50 OBO
Axial .28 1S- 6 gal. thru- $50 OBO
jatoman1992 is offline   Reply With Quote
Old 10-08-2007, 06:54 PM   #2
sickboy's Avatar
Trader Rating: 72 (100%+)
heat it up first.
sickboy is offline   Reply With Quote
Old 10-08-2007, 07:38 PM   #3
hmmm .......didnt work does anyone else do it another way
Pre-mix:
Nitro:
Electric:
Losi Micro-T- stock
micro T- $50 OBO
Old 10-08-2007, 08:31 PM   #4
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Throw it in the garbage . Just kidding . I had to use a screw driver through the exhaust to free it up a little and then the zip ties worked .
Briguy is offline   Reply With Quote
Old 10-08-2007, 09:20 PM   #5
Turbine_au's Avatar
Have you got any of the sleeve above the top of the crankcase. If you have, wrap a clean rag around a set of pliers and gently pull the sleeve out.
Heating will help. Also, please tell me you've taken the conrod off of the crank first if you're trying to remove both.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 10-08-2007, 09:22 PM   #6
Briguy's Avatar
Have to remove the sleeve before taking the conrod of the crank .
Old 10-08-2007, 10:16 PM   #7
Rocket42's Avatar
Heat the crankcase up with the flywheel on the engine then use as many zip ties as you need (the large ones work best) use big pliers to turn the flywheel. once you get the sleeve up high enough to get a screwdriver underneath the side just keep prying it out.
Rocket42 is offline   Reply With Quote
New piston/sleeve. David Day Nitro Off-Road 9 03-17-2008 04:59 PM
FS: NIB AE .15 Piston & Sleeve Set SteveM R/C Items: For Sale/Trade 0 05-23-2006 02:30 PM
wtb: xtm 24.7 pro piston and sleeve lp1066 R/C Items: Wanted to Buy 1 03-13-2006 11:13 AM
ABC sleeve and piston??? JInaba Nitro On-Road 2 12-12-2004 11:26 PM
piston/sleeve nitromike Nitro On-Road 1 03-14-2004 10:02 PM
