Old 10-07-2007, 12:28 AM   #1
Default Starter Box Questions
I have a Losi 8ight-T and a Mugen MBX5T, but one OFNA Universal True Start starter box.
Is it okay to use just one starter box for both truggies? If so, any suggestions on a quick way of adjusting the mounts on the chrome top of starter box to accept both truggies?
BTW, 8T has OS21 Max VZ-B and MBX5T has Werks 28 B7 Pro Comp.
Thanks in advance.
kilana is offline   Reply With Quote
Old 10-08-2007, 12:26 PM   #2
last's Avatar
Check RC Driver out this month I believe it has a universal starterbox mod in inside I'm not sure of the issue month as I have subscription and I am at work. But you use some L bracket aluminum and some screws and viola. Pretty easy mod if you have a dremel.
Someone's got to be Last
***Team Terribles***Answer RC USA/Torco Race fuel
last is offline   Reply With Quote
Old 10-08-2007, 06:50 PM   #3
last's Avatar
Sorry its no RC Driver its Novembers Xtreme RC Cars Issue 144.
Old 10-08-2007, 07:48 PM   #4
Default Thanks!
Thanks...I'll go check it out.
I thought there were people out there that have a similar situation as I have.
I was hoping there would be plate that would attach onto any starter box top. This plate would have at least four short tabs sticking out on the top of it at the four corners. Then, something similar to the TKO quick change plates for all the different r/c's would have four counterbored holes on the bottom of the plate which would fit onto the four tabs of prevoius plate. Height would be adjusted with shims. BAM! There's your adapter plate that accepts plates for different r/c's...i guess I'm crazy.
Old 10-10-2007, 04:44 AM   #5
You have a good idea, why not make plates that would mount to the top of the box for each vehicle?
I mean it doesn't have to be so complicated as for the stacking part, but make different plates out of either thin plastic or wood, with a edging the size of the top of the box so you could just drop them on top of your starter box and go.
rm25x is offline   Reply With Quote
Starter Box questions... Momo5 Nitro Off-Road 8 03-17-2008 11:11 PM
Ofna Chrome Top Starter Box Questions llamont Nitro On-Road 2 04-14-2007 06:55 AM
kanai diff questions and other questions famous182 Electric Off-Road 2 02-25-2006 01:19 PM
Questions on getting a Starter Box J Smith Nitro On-Road 15 07-28-2004 03:50 PM
Starter Box Questions... CRFXXXT Electric Off-Road 3 07-06-2004 04:48 PM
