Old 10-06-2007, 09:56 PM   #1
Default sliper clutch problems
Hey i have a traxxes nitro rustler with the 2.5 engine and i have been having a problem with my slipper clutch it keeps melting and i asked the guy at the hobby shop and he claimed to have fixed the problem but it happend again any sugestions?
motoxguy47 is offline   Reply With Quote
Old 10-07-2007, 08:36 AM   #2
jatoman1992's Avatar
Trader Rating: 4 (75%+)
Send a message via Yahoo to jatoman1992
slipper clutch melted???? do u mean spur gear.
Pre-mix:
Kawisaki KX125-bored out to a 134cc, VForce reed valves, FMF gold series pipe and shorty silencer, phathead racing cyl head w/ interchangeable domes, and wiseco flat to piston
Nitro:
Ofna Ultra LX Pro- Axial .28 1S w/ JP-2 Pipe, Hitec HS5645MG(steering) and Hitec HS625MG(Throttle/Brake)
Electric:
Losi Micro-T- stock
Coming soon: Associated FT B4- stock
Ofna LX Pro as a roller w/ extras- $150
Starter box(1/8 buggy) w/12V battery- $70
micro T- $50 OBO
Axial .28 1S- 6 gal. thru- $50 OBO
jatoman1992 is offline   Reply With Quote
Old 10-07-2007, 02:41 PM   #3
maybe spur gear the big gear thats made of plastic the teeth keep wering down and the sides get melted kinda
Old 10-07-2007, 03:32 PM   #4
air8's Avatar
does your truck have the Revo spec slipper or is it the older style? Not too sure about the older style but with the Revo slipper tighten the nut all the way and then back it off till there is about 1/8" of thread showing on the input shaft. You don't want it so loose the truck is sluggish to accelerate. This will lead to melted parts. Also if you tighten it all the way down this can bind stuff up and cause tons of friction/heat, leading to melted parts. There is plenty of adjustability with slippers. If you find the slipper is loose after setting it then tighten slightly till you feel its' good.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 10-07-2007, 03:42 PM   #5
so 1/8 inch of thread between the gear beetween the gear?
Old 10-07-2007, 03:44 PM   #6
air8's Avatar
1/8" from adjusting nut to the end of the shaft.
--"U Ain't Fast!!"
Chris Pearce
Old 10-07-2007, 03:55 PM   #7
alright ill look at that then when i get the new parts also if i got an aluminum gear instead would that be good? the guy at the hobby shop said no because instead of melting somthing would go wrong with my engine instead
Old 10-07-2007, 04:03 PM   #8
air8's Avatar
I'm not sure. Aluminum and steel (clutchbell) are different metals and they might not go good together. I run a GT2 and the platic spur gear is light, durable, and low friction. friction from the teeth to the CB teeth. I suggest sticking with the stock parts and just get it set correctly. Just cause something fails once in a while doesn't mean it's a bad design. Some stuff is made to give out before other parts. The spur and slipper pads should take most of the abuse over the life of the truck. They should last many, many bashings or races. But keep in mind they will wear out cause they are designed to fail before the engine/tranny fails. Check out the forums/community on Traxxas' web. It has more info than you could use in a lifetime. LOL. JK-the forums there are very large though.
--"U Ain't Fast!!"
Chris Pearce
clutch problems Mugen MBX-5 Nitro Off-Road 5 10-19-2007 12:10 PM
Problems with clutch! Hampe Electric Off-Road 2 01-18-2006 09:52 AM
Clutch problems?? chilionastick Monster Trucks 6 09-16-2005 03:56 PM
Clutch Problems Tazman6789 Electric Off-Road 3 08-28-2005 01:08 PM
clutch problems!! B3boy Racing Forum 3 08-22-2001 04:36 PM
