Old 10-05-2007, 07:14 PM   #1
monsaas's Avatar
Default crankshaft/flywheel shims werks engine
Can anyone tell me what size I would need or a link to show me where I can get shims to shim my flywheel further from the main bearing on my werks .21 engine so that my flywheel don't rub on the carb/engine? *note* I'm not looking for clutch bell shims, but the shim that will fit behind the collet on the shaft.
Thanks for the help.
monsaas is offline   Reply With Quote
Old 10-05-2007, 07:40 PM   #2
SKOT's Avatar
This pack has all you will ever need.
http://www.amainhobbies.com/product_...oducts_id/5428
Don't let the name throw you off. These shims will fit behind the collet.
SKOT is offline   Reply With Quote
Old 10-05-2007, 07:53 PM   #3
slaytanic's Avatar
Trader Rating: 20 (95%+)
+1. I ALWAYS have this bag in my box.
slaytanic is offline   Reply With Quote
Old 10-05-2007, 08:20 PM   #4
monsaas's Avatar
are this only for shimming the clutch bell? or is there also ones in there with a big enough inside circumference to fit the shafts biggest part against the bearing of the engine? I have clutch bell shims but not ones big enough on the inside to fit the crankshaft against the bearing, between the collet and bearing.
Old 10-05-2007, 08:42 PM   #5
SKOT's Avatar
Yes. It's a mixed bag with parts for both. The brass washers you see pictured will do exactly what you need. There are also thinner zinc plated washers as well.
Old 10-05-2007, 08:55 PM   #6
monsaas's Avatar
Ok thanks SKOT! I need to make a order from amain anyways so i will give them i try.
OS engine crankshaft *Cheap* skengines R/C Items: For Sale/Trade 0 03-02-2008 09:46 PM
Bought GX-15 engine with short crankshaft! Please help! silacomalley Onroad Nitro Engine Zone 0 07-26-2005 12:21 AM
Bought GX-15 engine with short crankshaft! Please help! silacomalley Nitro On-Road 0 07-24-2005 02:57 AM
where to buy engine shims? The Sleeper Onroad Nitro Engine Zone 2 03-09-2004 01:42 AM
Engine Temperatures for Break-In and Normal Use for XTM 24.7 Engine. Head Shims? racer rich Nitro On-Road 0 12-13-2002 10:49 PM
