Old 10-05-2007, 11:26 AM   #16
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
This makes me think to go and get those quick release removable fuel tank mounts.
Do they have any type of quick release for the radio tray. THAT WOULD BE NICE!!!!
As many RC vendors has pretty much mastered the (Tr)Buggies in terms of handling and durability, I think they need to start looking at ways to make the cars easier to clean.
teeforb is offline   Reply With Quote
Old 10-05-2007, 11:34 AM   #17
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
Originally Posted by jkirkwood View Post
Here's what is working for me.
After Every race weekend:
  1. Remove Radio Tray, Fuel Tank and Engine
  2. Soak the kit down with deluted simple green, and let set for about 3-5 min.
  3. With the water hose I rinse the car off, I don't power wash or hold the car under the hose for a long period of time.
  4. I hang the car up by it's wing so it's hanging down and air compressor off the excess water.
  5. Oil every bearing with a quality bearing oil
  6. Oil with a dry lube the CVDs and hinge pin joints.
  7. Spray DW40 on a brush and brush down the kit.
  8. I clean the radio tray, fuel tank and engine by hand with a rag and brush.
This process takes me about 20-25 min. I've done it between heats at big races where there was a bunch of mud or the track was really blown out.
Every other race day
  • I follow the steps above
  • Tear down the car all the way to the diffs.
  • Polish the hinge pins and shock shafts, realm out the arms if needed.
  • replace anything that is worn.
This process takes longer and depends really how focused I am. I might spread that out between multiple evenings or might knock it out in about 2 hours depending on what needs to be done.
I've never seen residue from the water left around after I started dry lubing the joins and cvds after cleaning. But if you don't dry it well and don't lube the bearings afterwards.
this is the same method i use........nice to know i am not the only one doing it this way....
Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 10-05-2007, 11:41 AM   #18
joe of loath's Avatar
yes, the radio box on the hpi firestorm comes out on a couple of R clips.
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 10-05-2007, 12:01 PM   #19
teeforb's Avatar
anything for Mugen?
Old 10-05-2007, 12:33 PM   #20
Originally Posted by pitdog View Post
air blast what you can and them simple green for your stuborn dirt after removing radio tray and then multi purpose silicon spray over the hole lot,fortunatly for me i have a magic and takes 2 seconds to break down job done
Can you upload a quick 2 second video of that breakdown? Just kidding.
grantt is offline   Reply With Quote
Old 10-05-2007, 12:35 PM   #21
anything for Mugen?
probably not
actually, looking now you need to get the top deck off to get it off anyway. thats what annoys me about the firestorm, the top deck is a bugger to remove and you have to remove it to do anything.
Old 10-05-2007, 12:49 PM   #22
FWIW, this has been my setup to clean my 8th scale buggy. After this picture was made, I started to add a little denatured alcohal into the mix.
Old 10-05-2007, 12:53 PM   #23
teeforb's Avatar
Liquid/Air mixture nozzle. I never knew they had a such thing. Seriously...
Hey, where can I get one of those? I think thats the key to cleaning...
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
Old 10-05-2007, 02:00 PM   #24
jkirkwood's Avatar
http://www.finishlineusa.com/product...-plus-lube.htm
This is what I use for a dry lube. You can get it at a local bike store. There is other similar products on the market. Some will agrue another brand is better or worst. I really don't know. I do know since I've been using this I've noticed a noticeable difference in the wear rates of my cvds on my 8ight. I've also been using it on center gears.
Only negative thing I seen with it is I accidentally got a drop on the front brake disk which then caused it to glaze over and thus not much brake until I refurbished the disks.
jkirkwood is offline   Reply With Quote
Old 10-05-2007, 05:26 PM   #25
I bought mine at my local Harbor Freight Tools store. I could not find it on their website just now, and if you want to search around, I don't think "Liquid/Air Mixture nozzle" is really the right name for it. I tried "power washer", or "pressure washer" but came out with nothing. It does exist though.
Old 10-05-2007, 06:17 PM   #26
slaytanic's Avatar
Trader Rating: 20 (95%+)
I use 50/50 simple green and denatured alcohol with a capfull of wd40. Spray the car down and let it soak for a few minutes. Then scrub away with a tooth brush. Spray it down again and blow of with a compressor. Then lube your bearings. I usually take out the radio tray before hand just in case.
slaytanic is offline   Reply With Quote
Old 10-06-2007, 12:50 AM   #27
teeforb's Avatar
I found one at home depot today. Now all I need is a wide container to spray it down in. Hopefully the high pressure of liquid will clear my cars more thoroughly.
Old 10-06-2007, 01:26 AM   #28
So what is the danger of stuff corroding?
Does this apply to oil or oilless compressors? Has anyone else experienced their parts corroding?
D_o_S is offline   Reply With Quote
Old 10-06-2007, 05:41 AM   #29
Try tyre foam cleaner,like RALLY NO-HANDS works great.I use it on the whole car even the radio tray,it doesnt affect the bearings or electronics, just spray it on and it will foam the dirt off,then blow it with air.Hard to remove dirt like on the rear A-arms,just use a brush.The plastic will be nice and black,but somehow the dirt doesnt stick as much to it as before!Takes me about 10 min to clean my stuff!
Mater is offline   Reply With Quote
Old 10-07-2007, 09:15 AM   #30
can someone please elaborate on "re-lube the bearings" please? what are you using and how are you doing it? (newbie!)
Thrashin Bashin is offline   Reply With Quote
cleaning your gas car bigemike Nitro On-Road 5 03-22-2008 06:07 AM
SoCal Offroad RACERS!! Weekly offroad 10th and 12th scale racing! Syber Serulean Track Locator Forum 14 01-15-2008 12:30 PM
Offroad Nitro cleaning question... eziduzit Electric Off-Road 5 05-15-2007 09:25 AM
One Way Cleaning new92 Electric On-Road 3 02-20-2005 07:43 AM
Cleaning Out My Box trinityguy21 R/C Items: For Sale/Trade 12 05-04-2004 08:29 AM
