Old 10-05-2007, 07:01 AM   #16
Originally Posted by JeremyS View Post
check your clutch set up. What clutch are you running??
if a spring is broke or a shoe is stuck it can cause the motor to sound like it is lean bogging.
I'm using the Ofna carbon shoes with 1.1 spings as stated at the top. All brand new when I got the motor. I'm just going to put it away for now and wait till I get my buggy and try it again. I think the other thing is it's not enough torque in the motor to push my truggy. At least that's my opinion. But I'll give it another shot here in a few weeks.
Thanks for all the feedback.
_____________________
Sponsored by:
Fusion Motorsports
Bad Dog Rc
www.baddogrc.com
www.speedtechrc.com
My rides
Jammin CRT.5 w/ OS .12 TZP 5
Team Losi 8ight-T w/ Ninja JX .21
stiffler297 is offline   Reply With Quote
Old 10-05-2007, 11:00 AM   #17
rltanner's Avatar
Originally Posted by motomanpat View Post
Houston is the Man
Yes houston does give good answers to our problems he has helped me out alot thankx dude
Mugen MBX6
Mugen MBX6 Truggy
rltanner is offline   Reply With Quote
Old 10-05-2007, 04:24 PM   #18
houston's Avatar
Trader Rating: 91 (100%+)
Talking
gee thanks guys , just trying to share some of my knowledge to grow this hobby/sport/fun/etc.,etc. i know like one or two things about engines and rc cars in general
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 10-05-2007, 06:45 PM   #19
hendocap's Avatar
Thumbs up Air leaks check next!
the pinch test is a good method to check mixture, but I've had this type of problem before and it turned out to be an air leak on either the carb or back plate, I change both o-rings so not sure which it was but solved the problem.
hendocap is offline   Reply With Quote
Old 10-07-2007, 08:09 PM   #20
houston's Avatar
Talking
if your car will not tune right and is way hotter than normal with no power , check for air leaks !! never had a problem with novarossi engines needing any airseal
Old 10-14-2007, 12:22 AM   #21
D.Lasoski20's Avatar
I have the gt2 with the stock ae .15 in it and have the high speed needle and low speed set to factory setting(high speed 2 1/2 turns out and low speed 1/16 out from flush) but the engine heats up to about 320 degrees but it runs like it is rich, like it should with those settings. Why is it running that hot with these settings.
D.Lasoski20
D.Lasoski20 is offline   Reply With Quote
Old 10-14-2007, 01:11 PM   #22
and i just replaced all the gaskets and seals so there are no air leaks.
Old 10-14-2007, 01:54 PM   #23
gubbs3's Avatar
Originally Posted by g26er View Post
When you say it revs up for a few seconds, are you saying that after a few seconds the idle will drop?
EDIT: Nevermind I reread your post and I see the idle eventually drops. I'm going to go against the grain here and say that I think your too rich on the lsn and the idle screw set too hight to compensate for the overly rich bottom.
Get your car out and run it around to get the engine warmed up (200+). Assuming you have your hsn is set, I'll usually just throw it back on the starter box or car stand and rev it a bit to "clear it out". Now WOT to rev it (don't hold it or go crazy and blow your motor) then nail the brake and listen to the motor. If the idle stays high and then slowly drops, lean your lsn (you'll probably have to lower your idle after you lean it). If you do this and your idle drops when you hit the brake and slowly raises, the you need to richen your lsn. Your goal is to get it to almost immediately return to the same idle as before you did the wot. When done you may need to adjust your idle screw. This is how I've always done it and it works great for me. Once I do this I rarely have to touch the lsn, usually just the hsn.
This is the best method I have found. The pinch test just isn't very consistent which makes it hard to know exactly which way you need to go.
gubbs3 is offline   Reply With Quote
Old 10-15-2007, 01:22 PM   #24
DR ZAIRUS's Avatar
Default motor
Hey stiffler!! motors can get on your nerves sometimes, so have patience !!
I had the same problem with my motor after I broke it in: The LSN was too rich and the IDLE was too high, but I couldn't figure it out. I tried every combination possible. ("heal, I command you!!" heheh) I was going nuts.
A guy that was passing by the pit area saw me pulling hair and just casualy says "lean out the LSN", so I kept working on it...After a while, he came by again and as casualy as the first time he said: "I said lean it out..." "I did"-I answer. "I mean a lot!!" he says. So I did , and little by little the motor transformed before my eyes!!!
There's usually a lot of wise-cracks at the tracks and you should be weary of unsolicited advice, but this guy saved my life. So don't dispair...and lean out the LSN, for pete's sake!!! heheheheheh
Hong Nor/Jammin' X2
Picco P7 Evo3+JP3
Futaba+KO Propo.
TEAM www.fisio-sport.com
(Valencia, Spain)
DR ZAIRUS is offline   Reply With Quote
Old 10-16-2007, 07:04 AM   #25
I was so frustrated with it I gave it to a friend of mine. Ended up buying the Picco .28T for my truggy instead. Much more responsive to tuning and runs like a champ. Thanks all for the advice.
Sponsored by:
Fusion Motorsports
Bad Dog Rc
www.baddogrc.com
www.speedtechrc.com
My rides
Old 10-16-2007, 01:47 PM   #26
DR ZAIRUS's Avatar
Default p7
Hmmmm!! Maybe he'll fix it's wagon!! You should feel a difference between a 0.21 compared to a 0-28!!!!!
Hong Nor/Jammin' X2
Picco P7 Evo3+JP3
Futaba+KO Propo.
(Valencia, Spain)
Old 10-16-2007, 02:23 PM   #27
KThatcher's Avatar
Trader Rating: 64 (100%+)
sounds like u got an air leak. get some soap and apply to al needles and around the carb see if it dissapears real fast.. if it does then yoiu got an air leak... also check the back plate and.. if all of that fials it might be ur front bearing..;...
- Picco - Triton RC - 818 Designs - Team-CRP - RCRenew.com -
Pro Motion T-shirts -
KThatcher is offline   Reply With Quote
Need help tuning my OS 28 engine! BQFTW Nitro Off-Road 5 07-15-2008 01:22 PM
Tuning Class..any SIFU (klang valley) offer engine tuning class??.. azmin Malaysian R/C Racers 17 06-20-2008 09:42 PM
Engine tuning KJT4 Nitro Off-Road 27 04-25-2008 01:06 PM
Engine Tuning paul73rc Nitro On-Road 3 11-28-2007 01:38 PM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 06:04 PM
