Old 10-01-2007, 05:01 PM   #1
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Default Pico .28 9 port P3 vs. Jammin .28 Off-Road
I am looking for an inexpensive .28 Truggy motor. Any pro's con's for these two motors. Which will you guys choose and why?
Also, how does these motors compared to the .28 Ninja?
teeforb is offline   Reply With Quote
Old 10-01-2007, 05:45 PM   #2
Maximo's Avatar
The jammin 28 is 100% identical to the Picco 28... the only difference is the jamin has a 8 mm carb venturi and the Picco has a 9 mm venturi...other then that they are identical motors.....
the Picco's make more low end power then the Ninja, but the Ninja makes more top end and has a broder power curve..... the Picco's are long stroke engines made for tourque, and the NInja is a short stroke mill favoring high RPM......
Maximo is offline   Reply With Quote
Old 10-01-2007, 05:58 PM   #3
macnkitty2002's Avatar
exactly correct. i had a Picco .27 and it was a torque powerhouse, but coupled with a JP-2 pipe it was very well rounded. i personally think you should go with a torquey engine, since that's when most racer's need the power. only if your track has a long or a lot of straights would i go with a high RPM engine. i would go with a torque engine; it will get you scooting around the short sections and up the jumps in a hurry.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 10-01-2007, 06:40 PM   #4
teeforb's Avatar
thanks for the responses!!! I'll go with the Picco P3.
-Tavares
Old 10-01-2007, 06:49 PM   #5
AZRCaddict's Avatar
The Jammin motors are made by Picco but they have differnt timing and a few things.
Team EMB
AZRCaddict is offline   Reply With Quote
Old 10-01-2007, 07:17 PM   #6
teeforb's Avatar
but overall, these two motors will do me well in a truggy for racing, right?
Old 10-01-2007, 07:19 PM   #7
Maximo's Avatar
they are actualy 100% the same.. I have personaly modified and timed both motors, the only difference is the venturi's, other then that the differences are just cosmetic....
IMHO the P3 28 has too much bottom end and results in alot of wheelspin...... if you have the $$$ the Ninja 28 is a better track motor.....
Old 10-01-2007, 07:28 PM   #8
do you think this could be counteracted with a top-end pipe?
Losi Rock Rey
Old 10-01-2007, 07:34 PM   #9
jatoman1992's Avatar
Trader Rating: 4 (75%+)
Send a message via Yahoo to jatoman1992
you cant counteract wheelspin but you can help increase topend.
Pre-mix:
Kawisaki KX125-bored out to a 134cc, VForce reed valves, FMF gold series pipe and shorty silencer, phathead racing cyl head w/ interchangeable domes, and wiseco flat to piston
Nitro:
Ofna Ultra LX Pro- Axial .28 1S w/ JP-2 Pipe, Hitec HS5645MG(steering) and Hitec HS625MG(Throttle/Brake)
Electric:
Losi Micro-T- stock
Coming soon: Associated FT B4- stock
Ofna LX Pro as a roller w/ extras- $150
Starter box(1/8 buggy) w/12V battery- $70
micro T- $50 OBO
Axial .28 1S- 6 gal. thru- $50 OBO
jatoman1992 is offline   Reply With Quote
Old 10-01-2007, 07:51 PM   #10
teeforb's Avatar
can you counter act by going up a tooth on the pinion? that will reduce the bottom and increase the top, right?
Old 10-01-2007, 08:08 PM   #11
Maximo's Avatar
you can, but the feel is not the same as a revvy motor with lower gearing....its much easier to modulate an engine on lower gearing... As well you will find that geared up with a 28 that you will start smoking clutches and CB bearings.. on a modded 28 we couldnt finish a race with anything but stock gearing...... The Picco is a fantastic motor, and extremely powerful, the modded Picco 28's can be ballistic.. But regardless the Ninja is a better track motor, the power is smoother, the powerband is broader, and the power is very strong in the top end, where the Picco will fall off the Ninja will keep pulling..... As well even though the Ninja has great top end it also has very good bottom end, it pulls evenly from idle to 40 000 RPM...... But for sheer power the Picco is superior, but for a motor that will give you razor control and endless top the Ninja is my weapon of choice.......
Old 10-01-2007, 08:25 PM   #12
teeforb's Avatar
Good info Maximo!!! Thanks...
Old 10-01-2007, 10:09 PM   #13
AZRCaddict's Avatar
Hmm I guess misunderstood Jay Halsey?
Team EMB
Old 10-01-2007, 10:26 PM   #14
SKOT's Avatar
This turned into a huge debate on OFNA's own web site already. Sure enough, it didn't last long before getting deleted. No one could make a case for what specifically is different between the two other than quoting the advertising.
SKOT is offline   Reply With Quote
Old 10-01-2007, 10:57 PM   #15
AZRCaddict's Avatar
Not trying to argue at all, just stating what I was told. I could be wrong though.
Originally Posted by Steve Dunn from SGrid
it is made by Picco to Jammin specs.....differant timing and stuff.....so it will have a differant power band and look.
both great engines and the cost is what makes it really good.....and they last long time...
Team EMB
Go Tech 5 port Turbo or Jammin .21? LosiMadMan Nitro Off-Road 22 04-10-2008 06:19 AM
NIB JAMMIN CRT.5 W/ PICO 7PORT .12 ENGINE slow supra R/C Items: For Sale/Trade 29 02-12-2008 12:46 AM
Jammin CRT and Novarossi Rex 28, 8 port Tmachine R/C Items: For Sale/Trade 16 06-06-2006 10:26 PM
jammin x-1cr + hyper .21 8 port race Rocket42 R/C Items: For Sale/Trade 17 05-19-2006 03:12 PM
Ofna/Pico 7 port... Any good? ottoman Nitro On-Road 18 06-14-2003 09:12 AM
