Old 09-27-2007, 03:15 PM   #1
jatoman1992's Avatar
Trader Rating: 4 (75%+)
Send a message via Yahoo to jatoman1992
Default what is the highest revving Big Block engine
does anyone know i heard that there was a .21 motor that has a 48000 rpm limit
jatoman1992 is offline   Reply With Quote
Old 09-27-2007, 04:25 PM   #2
RKwaad's Avatar
OS 21 Speed, But I don't think it's 48k.
RKwaad is offline   Reply With Quote
Old 09-27-2007, 05:10 PM   #3
does anyone know what the rev limit is for the Trinity .21 Adam Drake edition
Old 09-27-2007, 09:56 PM   #4
MiamizFinest's Avatar
Trader Rating: 37 (100%+)
the OS speed is a 40K motor...... rember its a offroad motor even tho its a 500 something dollar motor the basic ninja spanks its like no problem......plus the ninja 21 offorad actually pushes out 43,000 RPM
RPM isnt everything but since the thread is asknig about the highest RPMS motor i would have to say the ninja 21 ONROAD its a 7 PORT 47K RPM motor.....but offroad its GARGABE (im asumeing u want it for a jato)
another huge RPM motor is the NVOAROSSI 35 plus 21 i 4got the numbers but i rember the price tag of 600 dollars
also if u can still find it (used on ebay) the highest RPM motor ever built (as far as i know i could be wrong) was the AXE ROSSI MERANELLO motor it rated in at 52K RPM....it had a chome egg shaped head and a red caseing it was a ONROAD MOTOR.....AXE rossi also made a offroad version of this motor called the BLACK MAGIC but i 4got how many RPM it had but it was FREAKING FAST
the black magic turns up on ebay alot sometiems even new but the meranello is one SUPER HARD FIND in fact im check ebay right now to see if i find one
-= Made In Dade =-
MiamizFinest is offline   Reply With Quote
Old 09-27-2007, 10:14 PM   #5
My RB C6BB showed 45300rpm according to spektrum rpm sensor. I guess the new C6 BB T7 would show even more, because of the new turbo head.
I also had the Black Magic engine, but it was very hard to tune and finally the rod broke. Not very good memories about it.
Taurius is offline   Reply With Quote
Old 09-27-2007, 10:31 PM   #6
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
^^^ Actually, the WS7III is slightly higher revving than the C6BB engine, but the C6BB gets to its top revs quicker. Also, I would assume that the RPM sensor on the spektrum is not quite accurate enough to measure those rpms. If someone has more insight into that, I would gladly listen.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 09-28-2007, 01:51 PM   #7
Hey MIAMIZFINEST i saw that you have a jato with a ninja .21, how did that work and how is it working out for you
Old 09-28-2007, 04:33 PM   #8
Steve Walters's Avatar
The AXE Rossi Cobra "VP" Modded is highest Off-road engine I've seen at 51,000 rpm @ 3.87 hp for a 3.5cc motor..
Here are the spec:
AXE Motor Rossi COBRA VP Modified Engine specs are:
DISPLACEMENT: 3.5cc
HORSE POWER: 3.87 HP
RPM: 51000
BORE: 16.00 mm
STROKE: 17.40 mm
PORTS: 7 + 2 BUSTER EXHAUST SYSTEM
CRANKSHAFT & TYPE: 14 SG
GLOW PLUG: STANDARD
WEIGHT: 340 gr
"CVR" Central Valley Raceway (Madera, CA)
Team "WTF" Racing member
TEAM BCE (Product/Field Tester)
X-Ray 808 (Active Diff)
BCE 8X8 Pro Chassis
OS Speed (XCustoms Head Mod)
Hitec 5995TG (S&T)
M11 & Spectrum.
Steve Walters is offline   Reply With Quote
Old 09-28-2007, 04:35 PM   #9
schmelme's Avatar
a 2005 6bolt 421b is the highest i've "heard" at the track.
schmelme is offline   Reply With Quote
Old 09-28-2007, 04:44 PM   #10
how about this AXE ROSSI .21 MAMBA "VP" HOT MODS
DISPLACEMENT: 3.5cc
HORSE POWER: 3.67 HP
RPM: 51500
BORE: 16.44 mm
STROKE: 16.48 mm
GLOW PLUG: STANDARD
WEIGHT: 340 gr
if only i had the money
http://cgi.ebay.com/NEW-AXE-ROSSI-21...QQcmdZViewItem
Old 02-27-2009, 03:23 AM   #11
opficon's Avatar
Send a message via Yahoo to opficon
i used the axe rossi black magic off road 21.. it fast.. but not "that fast",, i read the specification of that engine, but it says that this engine just had a 37000 rpm.. check this out.. http://hobbytech.gr/proionta_engines_axe_rossi.htm
Team C racing | Airtronics | Speedpassion | Gens Ace
opficon is offline   Reply With Quote
Old 02-27-2009, 06:21 AM   #12
slaytanic's Avatar
Trader Rating: 20 (95%+)
THe Trininty Extech 2.0 FM has a "useable" RPM range up to 45K. Not to say it won't wind out higher. I know when mine is on the pipe it was scary when it wound up.
It doesn't matter if your engine will hit 50k if it isn't laying down any torque.
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 02-27-2009, 06:30 AM   #13
xlgraphicspro's Avatar
You know something. I don't trust the printed RPM rating on any motor. Some say the Xdyno is the best way to get results. The testing conditions much change from one motor to another, because it's not accurate.
I was looking at an Rc Extreme magazine from 2005 when they were testing the Thunder tiger EB S3. and they used an O.S. V-spec. the claimed number on the dyno sheet was some 40,000++ # and a top speed of 50++. and then a recent RC Xtreme magazine tested a vehicle with a V-spec again, and the rpm's were significantly lower, and it turned a top speed of about 41 MPH.
I don't know about you, but I'm pretty sure O.S. motors are getting better not worse. This is just my thoughts, and I was recalling all my facts from memory, so don't grill me if my numbers are off slightly.
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 02-27-2009, 06:52 AM   #14
Zerodefect's Avatar
One dyno deos not equal another. Its impossible to calibrate both equally. Even the same dyno for two engine tests will give different #'s. As tiny as RC engines are, any slight variance has huge results in #'s. Outside temp, bearing temp, humidity,etc.
Dynos are for tuneing an engine so that engine has the best powerband its going to have. Its a tool to get the most out of an engine. It is NOT a tool used to compare engines. Such comparison can only be made on the track. Sometimes its obvious, but thats not the dynos purpose. Its a shame that its used that way.
Zerodefect is offline   Reply With Quote
Old 02-27-2009, 12:45 PM   #15
Echelon's Avatar
GRP Tuned .21 Rally version..
Echelon is offline   Reply With Quote
Engine empty revving Michael_90 Rookie Zone 2 11-21-2006 08:17 PM
Highest RPM engine for Savage sharkonwheels Monster Trucks 21 06-03-2006 12:38 AM
Engine Revving Flatout on startup dfwcomputer Electric Off-Road 2 01-23-2006 01:08 AM
Looking for a Big Block .15 RB Engine smartlp@cox.net R/C Items: Wanted to Buy 1 06-25-2004 01:21 PM
P5 Engine Block TonyWest R/C Items: Wanted to Buy 1 06-22-2004 02:32 PM
