Old 09-27-2007, 09:28 AM   #1
D.Lasoski20's Avatar
Default beginner: need help again
i have the gt2rs and i finally got it to idle descent but now when i hit the brakes it stalls. How do i fix that?
Thanks in advance
D.Lasoski20
D.Lasoski20 is offline   Reply With Quote
Old 09-27-2007, 10:15 AM   #2
joe of loath's Avatar
so, when you are braking it is closign the throttle too much. hold the brake closed and adjust the idle screw to a 1mm gap. then set the throttle trim so it is the same sized gap at neutral.
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 09-27-2007, 11:38 AM   #3
salteen's Avatar
Trader Rating: 90 (98%+)
how did you break the engine in without knowing these things?
salteen is offline   Reply With Quote
Old 09-27-2007, 11:58 AM   #4
factory settings!
Old 09-27-2007, 12:37 PM   #5
Send a message via AIM to GroffBall
Not sure how the GT2 clutch works but it could be the clutch bearings or the clutch could be holding up.
GroffBall is offline   Reply With Quote
Old 09-27-2007, 05:33 PM   #6
i broke it in by doing what the manual said and the manual didnt say anything about adjusting o the idle screw during break in, only the low and high speed needles
Old 09-28-2007, 12:56 AM   #7
air8's Avatar
Check your throttle linkage. When the Tx is at neutral the carb should be closed. If you start applying brake and the carb goes closed more, you need to adjust the linkage. This is what the spring is for between the carb and the adjustment collar. Move the collar slightly until the carb is fully closed at neutral. You can do this adjustment with out the engine running. Then you can set your idle gap, adjust the idle mix, and start tuning. I've seen several people have their vehicles sitting there idling away, and then push on the brakes...and Unnnkkk. Engine dies. So check this also.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 09-28-2007, 01:28 AM   #8
wd40prerunner's Avatar
Trader Rating: 8 (79%+)
i would check the clutch out
wd40prerunner is offline   Reply With Quote
Old 09-28-2007, 02:30 AM   #9
tkhoo's Avatar
Trader Rating: 45 (98%+)
Send a message via MSN to tkhoo
Yes, me too. Will check the clutch spring
1/8 scale buggy: HB D8, Truggy: 1/12 Jammin CRT.5
Radio: Sanwa M8 power by Sanyo Eneloop, Charger: Hot Power 6016
http://pgrcclub.blogspot.com/
tkhoo is offline   Reply With Quote
Old 09-28-2007, 04:34 AM   #10
yeah sometimes the springs get stretched and go soft.
Old 09-28-2007, 04:49 AM   #11
way2fast4u's Avatar
set the idle screw, if it idles sitting on the ground fine, then you hit the brakes and it quits, you have an idle screw problem. turn it out a little at a time till you can hit the brakes with out moving the carb back in. you can do this with the engine not running. if the clutch is bad the engine would quit as soon as the rear wheels touch the ground.
way2fast4u is offline   Reply With Quote
beginner in rc meckbeckk Malaysian R/C Racers 0 08-03-2008 10:52 AM
TC3 Beginner help... surjer Nitro On-Road 9 05-21-2008 07:31 PM
What Car For a Beginner?? Gav_XXXS Australian Racing 10 05-14-2006 04:31 AM
Beginner jonto100 Painting, Designs, Graphics and Photography 3 04-04-2005 02:23 PM
Beginner - What do you think? kcarron Florida Racing 2 12-09-2002 09:23 AM
