Old 09-26-2007, 10:19 AM   #1
D.Lasoski20's Avatar
Default Help: inconsistant idle
i have an rc10gt2 with the stock ae .15 and as i run it longer and longer on the tank of fuel i have to continue to turn the idle up so it will stay running. And the engine still has a lot of compression so i don't think it could be when the engine gets hot. Any help appreciated
D.Lasoski20
D.Lasoski20 is offline   Reply With Quote
Old 09-26-2007, 10:24 AM   #2
OTE_TheMissile's Avatar
Send a message via MSN to OTE_TheMissile
Sure sounds like a worn piston & sleeve. If you don't mind taking it apart try pulling them out and see if you can shove the top of the piston past the top of the sleeve.
I thought my O.S. 12CV had decent compression to it as well when I got the same problem. Not only could I run the piston past the top of the sleeve but I could keep going until it came right out.
Faster Than Factory
On The EDGE Racing, est. 2001 - Home of the 524, the Silverado Slammer E-MAX6X6, and the Sand Dollar prerunner
Mike Budzien | facebook.com/OTE.TheMissile | RIVCO Products | The RC Corral | iRacing.com
OTE_TheMissile is offline   Reply With Quote
Old 09-26-2007, 10:31 AM   #3
it has so much compression though that i cant even turn it over hardly with my finger, you still think it could be worn?
Old 09-26-2007, 10:32 AM   #4
d4man's Avatar
Check for air leaks around the carb neck, the backplate and the front bearing. Your pinch and compression sounds good.
The greatest trick the devil pulled was convincing the world he didn't exist...
I always thought I had a pretty good imagination, but it turned out to be just my imagination.
NOT a member of Team Terribles!
d4man is offline   Reply With Quote
Old 09-26-2007, 10:41 AM   #5
joe of loath's Avatar
this may be irrelevant, but my parents had a car with an air leak in the fuel line, so sitting at a junction the engine would slowly rev up. so +1 on the air leak check. infact, just replace all the fuel line.
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 09-26-2007, 10:43 AM   #6
Has this engine ever been apart before? I know my O.S. engines were built great from the factory, then I'd go inside to do something and whatever part I took off would develop a leak next time I ran it.
Faster Than Factory
Old 09-26-2007, 11:01 AM   #7
no its alomst a brand new engine never been apart i just got the car like 1 month ago and have only ran it probably like 5 tanks + break in. But ill check for air leaks thanks.
Old 09-26-2007, 11:14 AM   #8
Could it be leaking air out of the rubber boot by the low speed, would that cause it to have inconsistant idle?
Old 09-26-2007, 11:18 AM   #9
d4man's Avatar
ANY air leak would cause your engine to run/idle erratic.......
Old 09-26-2007, 11:50 AM   #10
I have an inconsistant love life. Any suggestions?
satoch is offline   Reply With Quote
Old 09-26-2007, 12:31 PM   #11
d4man's Avatar
I have none so your ahead of the game!!
.21 Idle RPM? Mpowerz Nitro Off-Road 0 01-14-2008 12:56 PM
idle screw! t-ray Electric Off-Road 11 01-22-2007 03:23 PM
car during idle tiger266 Nitro On-Road 11 08-03-2005 06:48 PM
Inconsistant Spray Problem Driving Me Nuts Griffin Painting, Designs, Graphics and Photography 12 05-11-2004 10:27 PM
Can't get Car to keep idle Blaze1 Onroad Nitro Engine Zone 6 04-21-2004 09:16 AM
