Old 09-25-2007, 11:57 AM   #1
RKwaad's Avatar
Default OS .28XZ
I am having trouble tuning this motor. Top end is unreal, bottom to 1/4 is a little fat. If I stab the gas it leaps. If I run 1/2 for more than 30sec than stab it, it looks like the bug man going down the track. I know it has a mid adjustment but every one says leave it at factory setting. What to do?
RKwaad is offline   Reply With Quote
Old 09-25-2007, 04:10 PM   #2
Trader Rating: 38 (100%+)
An OS engines, I almost never touch the mid....
Did you do the pinch test on the fuel line to determine bottom-end? Usually after I adjust the high-speed then bottom, I'm usually good to go...
JQ Products "Le Car" - 3 of them. Primary, back-up, and spares car
Bunch of "classic" Schumachers
Tamiya - Leopard 2A6, Tiger 1
HPI - Blitz
bushyar15 is offline   Reply With Quote
Old 09-25-2007, 07:56 PM   #3
RKwaad's Avatar
How far away from the carb should I pinch?
Old 09-26-2007, 08:07 AM   #4
gijoe64's Avatar
Trader Rating: 30 (100%+)
I would recomend that you replace the carb restrictor with 7mm OS Speed restrictor, T2060 pipe to smooth out the bottom and if your running a Mugen or Kyosho ST-R use the Hyper heavy flywheel. We are haveing alot of luck with this setup our temps are at 200-220 deg and we are getting about 8-10 min runtimes.
gijoe64 is offline   Reply With Quote
Old 09-26-2007, 03:15 PM   #5
Trader Rating: 14 (100%+)
where can i find this hyper heavy flywheel, i had heard that a heavier flywheel would calm it down alittle, mine runs great. ran it at the futaba nitro challenge, finished 7th in amain.
jlo
jlo8864 is offline   Reply With Quote
Old 09-26-2007, 03:51 PM   #6
gijoe64's Avatar
jlo
You can buy the Hyper flywheels at Tower Hobbies
Old 09-28-2007, 07:21 AM   #7
RKwaad's Avatar
So if nobody uses the mid setting, why did OS put it on the carb?
Old 10-01-2007, 12:30 PM   #8
RKwaad's Avatar
Diito
Jammin x1 CRT Pro w/ OS .28xz dr_gonzo R/C Items: For Sale/Trade 25 09-16-2008 01:06 PM
OS 28xz fs sharkman R/C Items: For Sale/Trade 1 09-02-2008 05:04 PM
OS.28XZ anf0 Australia For Sale/Trade 2 04-15-2008 04:39 PM
O.S. 28XZ xsandmanx R/C Items: For Sale/Trade 10 03-08-2008 07:42 AM
