How to remove a connecting rod?
I just blew a connecting rod in my V-Spec and cant seem to get the broken one off (from the pistion). Any help on this issue would be greatly appreciated.
Alex
Alex
also becarefull when removing the tiny little clip thay will fly away and its like tring to find an eyelash in a soccerfield aint gonna happen..
Take the tires off youre car, then fire up the engine. hold it full throtle for about 30 seconds. The con rod will come out all by its self.
if you remove the clip and goes "ping", don't bother finding it. it is never recommended to put used ones back. use a new clip instead.
when my conrod gave up on me, it chipped the piston that i had to replace the whole P/S/conrod set.
Yeah i ported out my sleeve and didnt replace the ROD that was worn, bad move and here was the result, Sleeve, Piston and Backing plate all got hammered.
It actualy blew up on the starter box at low revs too.
Picture = http://www.users.on.net/~danzig/Meh.jpg
What type of tool do you guys use to get the little clip off?
use cable tie
I use needle point non magnetic tweezer. remove the G-clip from the part that wrist pin is hollow.
You don't need to take it out because the piston and sleeve are damaged. I would look carefully at the crank case & main bearing as well.
That motor in the picture is done.
