Old 09-19-2007, 06:04 PM   #1
Default Engine swap
hi all, ist great to ba a part of the forum. anyway i have a HPI Firestorm, bone stock. and i wanted to put in a axial.32 in. so my question is will it fit? and if not how big can i go.
phenixx is offline   Reply With Quote
Old 09-19-2007, 07:56 PM   #2
Scott8ight's Avatar
Ok the G3.0 engine is a .18 cu in engine. Which means that the firestorm is ment for small block applications. A small block is anything under .21 cu in, and a big block is a .21 and larger, so I would stick with anything under a .21 if I were you, hope this helps.
Scott8ight is offline   Reply With Quote
Old 09-19-2007, 09:46 PM   #3
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
just put a OS 18TZ in there and hold on, cause its gonna be faster than you can handle....there is no need for a BB engine in this class of truck...
Jason Halvorson is offline   Reply With Quote
Old 09-19-2007, 11:10 PM   #4
thanx guys, for the info. If it helps my plans were to make a crazy fast nitro truck that i can slap some sand paddles on. So a OS18 would be a crap load of power?
Old 09-19-2007, 11:20 PM   #5
xlgraphicspro's Avatar
Yes, 18 TZ
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 09-20-2007, 04:41 PM   #6
So i think ill do a little more research on the 18TZ but i have one more question. Is there any performance difference between a rotary and slide carb???
Old 09-21-2007, 04:01 AM   #7
joe of loath's Avatar
why do you want to upgrade? the firestorm is no way underpowered stock.
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 09-21-2007, 12:19 PM   #8
Your right. The firestorm is by no means underpowered. But I had on oppertunity to get a axial for cheep, and wanted to know if it would fit. I do want to put a upgraded motor in it . It will see a lot of sand. and some dirt.
Old 09-21-2007, 04:16 PM   #9
jatoman1992's Avatar
Trader Rating: 4 (75%+)
Send a message via Yahoo to jatoman1992
its not underpowered but the 18 TZ will blow every other stock firestorm away, and yeah slide carb is better than rotory
jatoman1992 is offline   Reply With Quote
Old 09-21-2007, 05:15 PM   #10
Nice! thank you all for the good info! If you have any more about this subject keep posting!
Old 09-22-2007, 02:36 PM   #11
i guess so. you may need abit more weight on the front or higher gearing to help with the immense amounts of power. i would say the highest clutch bell known to man?
Old 09-28-2007, 08:18 PM   #12
zJatoRad's Avatar
Trader Rating: 31 (97%+)
Send a message via MSN to zJatoRad
Is there an O.S. .12 that will fit in this truck without mods? thanks.
zJatoRad is offline   Reply With Quote
Old 09-28-2007, 08:47 PM   #13
Body_beater's Avatar
Send a message via MSN to Body_beater
you can make that Axial 32 fit, but it would take some serious machine work
Body_beater is offline   Reply With Quote
XXX-NT Engine Swap slumlord Nitro Off-Road 1 02-24-2011 09:39 PM
need help with a engine swap 2mcgrath Nitro On-Road 3 12-08-2008 04:15 PM
Engine swap for RC10GT fastfad Rookie Zone 2 04-15-2006 09:39 AM
RC10GT engine swap fastfad Australian Racing 0 04-14-2006 12:07 AM
engine swap crash21 Rookie Zone 2 09-19-2005 08:54 PM
