What Glow Plug?
What Glow Plug?
i have the o.s. v-spec with the p3 plug. i want to switch from 20% to 30% nitro. should i use a medium plug or use the p3? if i have to use a medium plug, what do you guys will recommend?
what 30% fuel are you guys using with good performance?
look here http://www.outlawrc.com/glowplugs.htm
maxy fuel,sidewinder,mugen,byrons,odonnell,there all good
http://www.bmainhobbies.com/index.ph...83544c24bdf853
Thats the fuel I use and I love it. Its got a little more oil (11%) than most race fuels but still delivers great performance. For the V-Spec I prefer the P3 plug in most cases. The P4 and P6 plugs are a little colder you might be able to tune a little more top end using them but your going to lose the idle all day quallity the P3 gives you.
I would stick with either the OS P3 or the OD97T as for fuel O'Donell, Werks and Sidewinder are all good. But I would recommend going with one that easily obtainable at your local track or other tracks you visit.
Later,
Later,
Another vote for either the O.S. P3 or O'Donnell 97T. I just tried a 97T after using P3s up to that point, and the plug worked great. Supposed to be more durable than the P3 as well. We'll see what happens if I run out of fuel on the throttle next time. I usually smoke P3s when I run out of fuel, which prompted me to try the 97T.
thanks guys. do you guys put another extra head shim on the o.s. v-spec when you switch from 20% to 30%?
OS P3, OS P4, or OD97T plug. I am currently using the OD97T's in my V spec.
Personally,I am running Byron's. That is strictly based on cost for me though. I get it cheaper than retail because I work in a hobby shop and it doesn't sell what I want to run. If I was paying full price for my fuel and it was more readily available locally, I'd still be running Werks fuel.
i also dont know if i need a new plug or not, i have a 28cxp motor in my buggy, i used to have it on 16% but then had it re-tuned on 20% they did not replace the plug, and i havent tuned it right yet, what plug should be in it..
