Old 09-17-2007, 02:31 PM   #1
Default jammin x1 rtr questions
I've been slowly upgrading my x1 rtr but I need some further advice. I just added a JP-3 pipe and a proline body. The stock pipe didnt interfere with the body while the manifold on the JP-3 melted clear through it on one tank. Is this a common problem?
I have an OS VG 21 on order but not sure what flywheel, clutch setup to use. It will be on OFNA starter box #10250. I know I will need non pullstart mounts and a nonpullstart flywheel also.
Is there any difference in companies (king heads, dragon racing, or factory) aluminum upgrades that would make a big difference or is it just in pricing?
Forgot, still have the Force 28 engine on it.
MJ86GT is offline   Reply With Quote
Old 09-17-2007, 07:14 PM   #2
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
i run a proline body with a jp3 pipe and have only a lil rubbing....as far as the clutch, your stock flywheel and bell gear will work just fine, and you can even use your stock engine mounts for now...
i have bought alot of king heads parts for my jammin buggy, and there fit and finish is great, really strong too...
Jason Halvorson is offline   Reply With Quote
Old 09-17-2007, 10:04 PM   #3
Iv never tried the king headz but i havent heard of any complaints. I have no complaints with the original jammin/hongnor aluminum upgrades, all I can really say is that they are pretty good quality parts. for the RTR I would suggest that you get the aluminum braces and z brace if you don't have them yet.
Genius is offline   Reply With Quote
Old 09-18-2007, 01:26 PM   #4
-R2-'s Avatar
here are Ofna/Jammin part no. that you would need if you want to up-grade for your new engine
40573-35mm flywheel for non-pullstart engine
40623-cnc engine mount 3-pc. mount
and if you need alum. clutch shoes
10011-blue shoes 1.8grams
10012-purple shoes 2.0grams
10013-silver shoes 1.7grams
clutch bells
10430-13tooth
10431-14tooth
10432-15tooth
these clutch bells come with bearings
shim kit
10099
-R2- is offline   Reply With Quote
hyper7 shock questions and other questions buds302 Nitro Off-Road 1 06-10-2008 11:03 PM
Jammin CRT Alum Chassis Braces & Jammin CR Carbon Fiber Towers racer34v R/C Items: For Sale/Trade 3 07-19-2007 07:01 AM
Ongoing thread of Newbie Questions about a Jammin X1 CR RTR.... Ofna_Driver_777 Electric Off-Road 43 02-26-2007 04:17 PM
Jammin FTE:Clutch questions.need some answers wcairsoft3r Electric Off-Road 8 01-10-2007 11:47 PM
kanai diff questions and other questions famous182 Electric Off-Road 2 02-25-2006 01:19 PM
