Mixing diff oils
Mixing diff oils
Sometimes, there isn't enough diff oil available with the thickness you want or need.
Therefore, you want to mix several oil (with the same brand) to create the desired thickness.
For example, you want to have the thickness of 7000 WT by mixing 5000 with 10000 WT.
The question is, how many % of each thickness do you need to mix with the other?
60% of 5000 WT and 40% of 10000 WT will create 7000 WT???
Do you guys know any link where more info on this can be found?
I've found a link in the past at the internet where the calculation is available. Some how I just can't find it anymore.
If someone knows it, please share the detail.
This could also be usefull for the others!!
