Old 09-16-2007, 12:58 AM   #1
Default CLUTCH SPRING TUNING
I am curious about this:
using:3- shoe clutch setup,with standard weight aluminum shoes
With the thought of clutch spring rating/engagement(highter number=thicker spring=later engagement=more snap),and the dyno numbers an engine data archive.It seems as if a lot of engines make their peak hp and trq at a lower rpm than the engines peak rpm.Does this mean you need to tune your clutch springs to engage at an earlier rpm rather than at a later rpm(lower number clutch springs),so you are in that lower peak hp/trq rpm area?
I understand grip also comes into play,but mainly curious about this aspect of the tuning.
Any help would be greatly appreciated.Thank you.
tsanc10 is offline   Reply With Quote
Old 09-16-2007, 03:02 AM   #2
GenReaper's Avatar
Send a message via MSN to GenReaper
Yeah what you said is correct.
Its the same principle with real cars, even stall convertors.
Trade off is it can be twitchy to drive in its engagement because it will transfer lots of power straight away.
I see a few people that over clutch their engines and do well but it can come down to driving style and smoothness as well.
I would generaly tone down a clutch on a 5 port on a slippery track making it more drivable with softer springs as with having heavier springs the engagement will be higher in the rev range and will cause wheelspin.
If it was a 7 port i would run heavier springs so its up where its making good power.
Comes down to personal preference, driving skill, and controller setup so "each to their own" to say
Having heavier springs will make it very "Snappy" but if traction is good this can be well utilised.
The heavier the springs, the less RPM range you have in your power band and will take some drivablity out of the car.
Hope it helps :}
Trex 700E 12S Scorpion 4035 560kv
Trex 600E
HPI Baja 5B SS
My videos : http://www.youtube.com/profile?user=genreaper
GenReaper is offline   Reply With Quote
I need a clutch spring how to salteen Nitro Off-Road 3 11-10-2007 04:00 AM
Clutch Spring BREAKING!!!! Djballen Nitro Off-Road 2 09-30-2007 04:37 AM
Mbx5r clutch spring help newbie2006 Nitro Off-Road 3 07-22-2007 12:24 AM
NIP Spring Tuning Set - Pro-Touring (6 prs)schumacher BIG DADDY8 R/C Items: For Sale/Trade 4 05-12-2007 06:49 AM
Clutch spring tool kahuna2793 Electric Off-Road 6 04-29-2006 06:12 PM
