Old 09-14-2007, 08:11 PM   #1
Trader Rating: 14 (100%+)
Default Nova Plus 21-5K
I just purchased one of these engines. Does anyone running one have any special tips for break in, plugs, fuel etc.? I'm running Byron's 30%, any special shimming needed?
sdmlsu1 is offline   Reply With Quote
Old 09-14-2007, 08:20 PM   #2
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
the stock shimming is fine for 30%....ive found that McCoy MC9 cold plugs are the best plugs for novarossi engines...as far as break in goes just make sure you heat the engine up to around 200F with a heat gun or atleast a hair dryer, cause novarossi's have tons of mechanical pinch....good luck and enjoy your new engine its a great mill....
Jason,
Jason Halvorson is offline   Reply With Quote
Old 09-14-2007, 08:34 PM   #3
Also anyone tried a JP3 pipe with this engine? If so how was the performance and run time? I have a 9886 on order but I want to try my JP3 also.
Old 09-14-2007, 08:37 PM   #4
i run a JP3 on mine and its great....runtimes are around 9 to 10 minutes running at around 220, tons of low end with great top end...
Old 09-14-2007, 08:41 PM   #5
I appreciate the input and quick respone Jason.
Old 09-15-2007, 01:18 AM   #6
I've been running this motor for about 3mo. now. Of all the pipes I've been through I've had the best luck with the Nova 9901 use a long header for moderate to high traction and medium header for loose conditions. In my 8ight if I'm really pushing hard it makes about 8 min. a little smoother on the throttle I' gotten as much as 9 min. between pits. IMHO, This is one of the best motors available out there today. I've yet to be on a track were I couldn't get enough bottom end out of it and the top end is all you'll likely ever need.
One thing though I've noticed the 9901 is a very quiet pipe which takes a little getting used to when tuning by sound.
blindRacer is offline   Reply With Quote
Old 09-15-2007, 06:45 AM   #7
ive gone threw two rear nova bearings in 10 litres on my nova plus 21-7bt put tko or boca in these engines straight away
www.pinehillsdirtracing.com...MUGEN MBX7R with TEKNO V4 conversion.....TEKIN RX8 GEN2 esc HOBBYWING motor 2200kv.....
pitdog is offline   Reply With Quote
Old 09-15-2007, 09:28 AM   #8
how are you getting 9-10 minutes with a jp3 and running at only 220?
I have a jp3 on my 21-7 and get 7:30-8 min with the temp at 260.
Everyone I've talked to who runs a jp3 gets only decent mileage (7-8:30min) and agrees their mileage takes a dump from the previous pipe they were using. Except for v-specs, they still average 8-9min or a little longer.
o.s. power is offline   Reply With Quote
Old 09-15-2007, 09:33 AM   #9
most of it has to do with the trigger fingure....and you also said 21-7, the 21-5 is known for better run times than the 21-7...also i have my carb set to open just a lil past 3/4 open this makes a 30 sec. or more difference in run times per tank....also i may be running more fuel tubing and i run dual empty fuel filters all making a few more seconds here and there....
Con Rod for Nova plus 21-7 NEMESIS44 Nitro Off-Road 11 06-04-2008 10:11 PM
Nova P5-K 175.00 JP-3 50.00 MercyRev R/C Items: For Sale/Trade 8 12-23-2007 09:33 PM
Funny Mega Nova>Picco>Nova and Picco ioxqq Onroad Nitro Engine Zone 14 09-10-2007 02:02 PM
F/S: Serpent 835 with Big Block Nova Mega SX15 Engine and Nova Mega exhaust system Solara R/C Items: For Sale/Trade 0 07-26-2007 08:54 AM
Nova Mega / Nova Rossi .12 side Exhaust engine centax error! Nitro On-Road 3 08-21-2005 07:33 PM
