Old 09-12-2007, 09:58 PM   #1
Tech Legend
Cain's Avatar
Trader Rating: 233 (100%+)
Default Mugen MBX5, MBX5 Pro Spec, MBX5R Differences
What are the differences between the different versions? Also, what handling differences will I notice between the versions?
< Tekno SCT410.3 x 2 |HB Racing D413 x 2 | Tekno EB48SL x 2 | Yokomo YZ-2 DTM x 2>
Old 09-12-2007, 10:49 PM   #2
mbx5 to a pro spec- beefier parts like shock towers , alloy rear uprights, steering arm, front rear chassis braces and titanium turn buckles
MBX5R is like the pro spec but has a milled chassis so the suspension arms can have more travel, longer shocks front and back, 1 peice engine mount, different front end parts to allow more steering travel.
mugenlife is offline   Reply With Quote
Old 09-13-2007, 05:32 PM   #3
TonysScrews's Avatar
Also, Mugen has made about three dozen running changes since the first MBX5 standard kit was sold. Within each kit (standard MBX5, ProSpec and MBX5R) these running changes have been made. So a standard MBX5 kit bought in May of 2004 will not be the same as one sold in May of 2006.
Best regards,
Tony P.
Tonys Screws LLC
http://www.tonysscrews.com
High Grade Alloy Steel Screws, Screw Kits and Mugen Parts
TonysScrews is offline   Reply With Quote
Old 09-27-2007, 06:01 PM   #4
Tech Legend
Cain's Avatar
Do you know what the different front end parts are that allow more steering travel?
Old 09-27-2007, 07:14 PM   #5
wrightcs77's Avatar
Trader Rating: 517 (100%+)
Front uprights and front lower arms and the outer rod ends, I think. I know they changed the ackerman plate, but that just moved the holes slightly.
wrightcs77 is offline   Reply With Quote
Old 09-27-2007, 11:33 PM   #6
nobike's Avatar
Trader Rating: 147 (100%+)
The mbx5 is fast, the mbx5 prospec is faster, the mbx5r is the fastest....
nobike is offline   Reply With Quote
Old 09-28-2007, 12:43 AM   #7
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
mbx6 will be even faster lol.... no bike i like the way you put that lol...
Ultraspeed84 is offline   Reply With Quote
Old 09-28-2007, 08:04 AM   #8
Tech Legend
Cain's Avatar
Great. I'll take a look at it when I get the chance.
Old 09-30-2007, 12:00 PM   #9
I've got a 5R coming and was wondering what you guys are running for diff fluids and shock oils. Was thinking of the Ninja motor as well with either a JP2 or 3 pipe.
_____________________
Sponsored by:
Fusion Motorsports
Bad Dog Rc
www.baddogrc.com
www.speedtechrc.com
My rides
Jammin CRT.5 w/ OS .12 TZP 5
Team Losi 8ight-T w/ Ninja JX .21
stiffler297 is offline   Reply With Quote
Old 10-01-2007, 07:08 AM   #10
Send a message via Yahoo to windellmc
5,7,5 f,c,r diffs. 400 fr shocks and 350 rear.
windellmc is offline   Reply With Quote
Old 10-01-2007, 07:16 AM   #11
Tech Legend
Cain's Avatar
I shot a message over to mugen USA to get the specific part numbers on what is different between the MBX5 and MBX5R.
The little I did drive my MBX5 I was quite happy with it. Turned excellent on the track and tracked straight and true.
Old 10-01-2007, 09:04 AM   #12
Trader Rating: 96 (100%+)
THe 5r has better shocks ( bottom threads in vs. circlips ) more down travel and stiffer plastic arms.
With the added down travel comes problems like cvd chatter and reduced steering throw ( knuckles bind on pivot balls, check your throw at full droop and at ride height).
K.Copeland is offline   Reply With Quote
Old 10-01-2007, 10:35 AM   #13
I think the car works better without using all the extra down travel you get from the new shocks. I limit mine about to where an older MBX5 would be. The major changes for the R are the shocks and towers, front lower hinge pin plate gives 1 degree less kickup, the ackerman plate moves the holes back a bit. They did modify the arms and chassis for more down travel also. The steering knuckles were also modified for more steering throw although you can dremel the old ones and get to the same place. If you get the shocks and towers you will be running basically the same car that Scott Hughes used to take 2nd at the World's.
The shocks are a huge upgrade over the old ones. The oil stays clear and the shocks stay consistent for a long time. The car is better in the rough even though the old car was pretty good.
FS Mugen MBX5-T Prospec & MBX5-R Both less than 3 gallons! V-Spec Less than 1 gallon! ffpm46 R/C Items: For Sale/Trade 20 08-01-2008 06:27 PM
Mugen MBX5 Electric Conversion, MBX5 and MBX5R Spare Parts! Cain R/C Items: For Sale/Trade 18 04-10-2008 03:16 PM
mbx5r mbx5 prospec or mbx5 PARTS johndayo101 R/C Items: Wanted to Buy 2 01-14-2008 12:52 PM
MUGEN MBX5 AND MBX5R rcpilot_971 Nitro Off-Road 6 11-15-2007 04:00 PM
MBX5 or MBX5 PROSPEC? Realworld differences? Jeel Electric Off-Road 5 12-05-2004 07:46 AM
