Old 09-12-2007, 12:57 PM   #1
motomanpat's Avatar
Default How to make Buggy/Truggy jump farther and higher?
Both my rides don`t jump as high or as far as needed to make the triple at my local track.Can setup help with this problem?? What are your opinions about this?
motomanpat is offline   Reply With Quote
Old 09-12-2007, 01:11 PM   #2
OTE_TheMissile's Avatar
Send a message via MSN to OTE_TheMissile
Stiffen the suspension a bit, go up a weight or two on your shocks or put on a heavier spring. 'Course, that's gonna change how it handles on the rest of the track.
Also could be you're not hitting the jump with enough speed, not much you can do if the truck doesn't have the motor and/or you don't get it squared up enough coming out of the previous corner.
Faster Than Factory
On The EDGE Racing, est. 2001 - Home of the 524, the Silverado Slammer E-MAX6X6, and the Sand Dollar prerunner
Mike Budzien | facebook.com/OTE.TheMissile | RIVCO Products | The RC Corral | iRacing.com
OTE_TheMissile is offline   Reply With Quote
Old 09-12-2007, 01:50 PM   #3
Z_Schneider's Avatar
I've found that going to a stiffer, and lower setup helps you clear the big jumps, but doesnt take away from the handling on the rest of the track.
~X-ray 808-'10~X-ray XT8-'09~Associated SC10~Kyosho RB5
Sponsors:
~JConcepts~CPR Adrenaline~Shellz custom painting(me)~Team Dirtheaven~
Z_Schneider is offline   Reply With Quote
Old 09-12-2007, 01:57 PM   #4
Tires with better traction, a longer/smoother approach, and a motor/pipe/clutch set up with more low end snap will help more than anything else
satoch is offline   Reply With Quote
Old 09-12-2007, 02:30 PM   #5
David Wall's Avatar
More antisquat will cause the car to jump higher, or not as flat.
Retired!
David Wall is offline   Reply With Quote
Old 09-12-2007, 04:41 PM   #6
wes95_z28's Avatar
MORE SPEED!!!!!!!!!!!!!! Thats solves everything. lol.
Wes
Kyosho 777 WC w/ big bores, RB S5, ACE 1313 s., Air 357 t., JP-3
HPI Savage X SS, Axial .28, Hitec 5645 Steering servo
Nitro TC3, O.S. .18 CV-R
Associated RC18T, Brushless, Lipo
wes95_z28 is offline   Reply With Quote
Old 09-12-2007, 06:14 PM   #7
Rocket42's Avatar
I would check in the clutch are you running alumn. clutch shoes, that will give you more snap. Also you might want to bump the center diff up a little to get more snap. If you just need more pop to clear the jumps you may want to try stiffer springs with smaller pistons.
Rocket42 is offline   Reply With Quote
Old 09-13-2007, 12:04 AM   #8
dirtdustingdavo's Avatar
Trader Rating: 18 (100%+)
Try slightly heavier oil in the front, and experiment with different spring combinations IE; med spring in front light in the rear.
Living the dream
www.chargersrc.com
dirtdustingdavo is offline   Reply With Quote
Old 09-13-2007, 04:37 AM   #9
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
Don't forget it's how you hit the jumps as well....
Preload or no preload.
Tres is offline   Reply With Quote
Old 09-13-2007, 08:52 AM   #10
rabidsquirrel's Avatar
Rig up some model rocket 'booster' engines...
Announcer, "WTH was THAT!?!?"
It's a crowd pleaser fer shur!
rabidsquirrel is offline   Reply With Quote
Old 09-13-2007, 09:43 AM   #11
joe of loath's Avatar
or a nitro boost! if its electric add a pile of li-ion button cells for a 5 second boost at 24 volts
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 09-13-2007, 10:53 AM   #12
RKwaad's Avatar
Remember, the longer your wheels are off the ground, the less foward motion you will have. Unless your on a track with some insane trips, then I would look at clutches or maybe some 50% NITRO
RKwaad is offline   Reply With Quote
Old 09-13-2007, 11:12 AM   #13
Remember, the longer you are off the ground, the more 'cool' or 'style' points you will be rewarded by the judges. It is unclear if this will help you obtain TQ or a podium in the mains, though!
Lithium is cool and all, but I still say that model rocket motors ignited by a third channel controled mod, will gain you the most 'style' points from the judges and/or crowd! As long as you don't maim someone, of course!
Old 09-13-2007, 12:25 PM   #14
i think it would be very likely the car would take off and go through the driver stand! and theres nothing to stop you buying a gallon of nitromethane and putting that in your fuel. extra horsepower
Old 09-13-2007, 12:28 PM   #15
motomanpat's Avatar
Thanks for the input guys,
It is really a tough section of the track.It is a triple double with a short launch.I have a CRT tank and a Hyper 8 and both seem to have the problem.The CRT probably does not have enough motor but I make it every once in awhile with the Hyper 8.It seems that the local Losi guys almost always can make it even without a perfect line into it.I will probably just have to suck it up and do it double,double,single for goodBut this method is slower through that section!
looking to trade a thunder tiger st-1 truggy for an ocm truggy are buggy. DPowers R/C Items: Wanted to Buy 0 03-31-2008 04:49 PM
Method to run-in stock to higher turm motor? or a stock tune to a higher turns? micro80 Malaysian R/C Racers 0 06-16-2007 11:40 AM
can u make the revo look like a truggy rhymster Electric Off-Road 13 07-19-2006 08:24 PM
WTB .21 or higher Buggy engine Verhalas R/C Items: Wanted to Buy 4 06-08-2006 07:45 PM
wanting to make a electric truggy BUMPERCAR Monster Trucks 4 05-23-2004 01:39 PM
