Old 09-19-2007, 10:35 AM   #61
Turbine_au's Avatar
Hi, im doing mechanical engineering at uni and we're covering composites at the moment so I have a couple of questions:
1. Are you using pre-impregnated sheets or is the entire moulding done with fibres and resin by hand?
2. Are you using a woven sheet or unidirectional fibres? If so, have you experimented with the opposite?
3. Once they are available to the public, have you considered offering chassis with varying degrees of flex? Ie. a stiff chassis for smooth, hard packed tracks and a more forgiving chassis for rougher tracks?
4. How many layers are you using?
Thanks.
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 09-19-2007, 04:26 PM   #62
Matrix Concepts's Avatar
Trader Rating: 14 (100%+)
Default Carbon Chassis
Turbine_au- thanks for the reply. We are using all prepreg, and both uni and woven. yes we have talked about the possibilty of different chassis but that isn't in the plans at this time. On the question of how many layers are we using lets just say the chassis is 4mm.
Thanks again for the reply.
Matrix Concepts Inc.
Robert Bartlett
Kalispell, MT. 59901
rb42matrix@gmail.com
Matrix Concepts is offline   Reply With Quote
Old 09-19-2007, 06:33 PM   #63
Looks good, but I got 3 words for you.
Air cooled engine
Themajorhobby is offline   Reply With Quote
Old 09-19-2007, 10:04 PM   #64
Turbine_au's Avatar
Fair enough then.
Old 09-19-2007, 10:29 PM   #65
xlgraphicspro's Avatar
Air cooled engine
Huh?
I hope your only point isn't that the stock chassis helps to dissapate heat better. If you feel the bottom of the chassis after a 15 minute race, it's only warm around the engine. That's about the same size as the aluminum insert on this chassis. There may be a minimal difference in heat retention, but nothing that will affect performance.
I'm willing to do some product testing to prove that !
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 09-20-2007, 07:14 AM   #66
themajorhobby.....heat is not an issue and I am testing in probably the hottest place there is to test as far as heat and humitidy goes and I have not had any issues........
peakman is offline   Reply With Quote
Old 09-20-2007, 08:17 AM   #67
xlgraphicspro-
I think you are a little off, the chassis gets hot under the engine and warm throughout the rest of the plate. If the rest of the plate were not there, the area directly under the engine would be that much hotter. Just thermodynamics. Don't be narrowminded enough to think that it will not affect things such as long run tune and so on... for a 5 minute race...maybe not..for a 30 min race...of course it will come into play...start lean and you're done, start a little on the rich side, prolly not a big deal. Just something to think about.
peakman, thats good news.
Old 09-20-2007, 12:35 PM   #68
Race-Wright's Avatar
how is that alum plate inserted? is it pressed or bolted together?
what had been done to prevent it from poping out under a hard hit?
Race-Wright is offline   Reply With Quote
Old 09-20-2007, 12:44 PM   #69
captain america's Avatar
It looks to be fixed to the carbon with screws and locknuts.
Peakman, I wonder if it might be possible to get a few photos of the underside of the chassis/car that you've been testing? I'm curious to see how it's affected by abraision and wear.
captain america is offline   Reply With Quote
Old 09-20-2007, 12:52 PM   #70
The aluminum plate is secured in the chassis with nuts and bolts as well as the motor mount.....there is now way that plate will ever come out......
CA...pics will be up shortly.
Old 09-20-2007, 01:09 PM   #71
Here ya go Captain
Losi 8ight Carbon Fiber Chassis-front.jpg   Losi 8ight Carbon Fiber Chassis-middle.jpg   Losi 8ight Carbon Fiber Chassis-backjpg.jpg
Old 09-20-2007, 02:33 PM   #72
Thanks peakman. The chassis looks like it's held up well overall, just the longitudinal extremities that take the brunt of the hits with the rear in particular. Steel skidplates front and rear should cure that, especially if they cover right up to the edges of the chassis
I realise that this might be asking a bit much, but I think it would probably put many peoples' minds at ease if you could describe the type of circuit you're doing the testing on (or better yet--pics!) Also, how many hours do you reckon that you've logged with the carbon chassis to date?
Ultimately, it would be interesting if a local 8ight owner/racer could do some side-by-side comparisons with a conventional kit to see how one performs versus the other... Maybe even enter it in a race to see how it flies
Old 09-20-2007, 03:15 PM   #73
Captain America- here are a few pics of the 1st prototype to compare to Peakmans.
The tracks we have been running on are here in So Cal. The Palomar track is super rough, Thunder Alley, Sun Valley Motorsports in Los Angeles, Full Throttle Hobbies in Bakersfield, last weekend at Revelation Raceway in Ontario, and of course our private test track where we come up with these parts and test them.
This chassis has 5 rounds of the JBRL series on it and about 8 gallons of fuel through it so far.
We will be looking to do a comparrison in the near future.
Hope this helps
Robert Bartlett
Old 09-20-2007, 03:18 PM   #74
Sorry forgot to load the pictures.
Losi 8ight Carbon Fiber Chassis-pdr_0054.jpg   Losi 8ight Carbon Fiber Chassis-pdr_0055.jpg   Losi 8ight Carbon Fiber Chassis-pdr_0056.jpg
Robert Bartlett
Old 09-20-2007, 03:19 PM   #75
Captain America- I forgot to say that we are just about half way through thickness.
Robert Bartlett
TC3 with IRS Carbon FIBER CHASSIS maddog23 R/C Items: For Sale/Trade 5 07-30-2008 01:07 PM
[FS] Xtreme Carbon Fiber Losi JRXS LTO Chassis squarehead R/C Items: For Sale/Trade 4 04-07-2007 05:16 AM
WTB: TC3 Carbon Fiber Chassis mjm R/C Items: Wanted to Buy 2 11-02-2005 06:44 PM
WTB: TC3 Carbon Fiber Chassis mjm R/C Items: For Sale/Trade 0 11-02-2005 09:24 AM
TC3 carbon fiber chassis w/one-way FS sands R/C Items: For Sale/Trade 1 10-10-2003 08:53 AM
