Old 09-12-2007, 02:50 PM   #16
SHIZZILANILLA's Avatar
do you lose alot of traction because the graphite is stiff , or does it still have same flex?
SHIZZILANILLA is offline   Reply With Quote
Old 09-12-2007, 02:55 PM   #17
I think the way the graphite chassis is layed up is the same stiffness as stock or maybe a touch softer....hope this helps
peakman is offline   Reply With Quote
Old 09-12-2007, 03:59 PM   #18
There are very simple deflection tests that should be performed to compare the stiffness of this chassis to the stock one.
satoch is offline   Reply With Quote
Old 09-12-2007, 04:12 PM   #19
Matrix Concepts's Avatar
Trader Rating: 14 (100%+)
Default Carbon Chassis
We are in the process of getting this data together for a direct comparison. We are doing deflection and twist tests of different lay-up schedules.
I don't think we have lost any traction, everyone thinks it actually puts the power down more efficiently than the stock one. We are trying alot of different setups, as the car is so much lighter than stock.
Thanks Robert
Matrix Concepts Inc.
Robert Bartlett
Kalispell, MT. 59901
rb42matrix@gmail.com
Matrix Concepts is offline   Reply With Quote
Old 09-12-2007, 05:47 PM   #20
Trader Rating: 38 (100%+)
What follows are some questions. They are just that. They aren't flames...
1) Why the CF Chassis? What short-comings of the stock chassis (Pro) are you addressing if any?
2) What features did you build in that improve functionality of the chassis?
2a) What makes your chassis better than the stock chassis that makes your chassis more than "bling"?
3) What factors made you decide on the thickness of the chassis material you chose?
4) Wear - I drive on some pretty abrasive tracks that can eat a chassis in half a season, how does the CF wear compared to the stock chassis?
Just curious....
JQ Products "Le Car" - 3 of them. Primary, back-up, and spares car
Bunch of "classic" Schumachers
Tamiya - Leopard 2A6, Tiger 1
HPI - Blitz
bushyar15 is offline   Reply With Quote
Old 09-12-2007, 05:52 PM   #21
There are different types of carbon fiber weeve all of which have different characteristics. Please explain the woven CF material you've chosen and why. I see that it's the less expensive loose weeve. How many plies? Are you using a fiberglass core like some companies do to reduce cost? Is the chassis CNC machined?
Old 09-12-2007, 05:52 PM   #22
gubbs3's Avatar
And one more:
Will the buggy still make minimum weight for sanctioned races? Or will weight have to be added?
gubbs3 is offline   Reply With Quote
Old 09-12-2007, 06:13 PM   #23
Trader Rating: 21 (100%+)
Really cool stuff here!! I need to get my hands on this stuff!!!!
Colin
Time Zone Raceways www.Timezonehobbies.com
www.ColinBranch.com
C Branch is offline   Reply With Quote
Old 09-12-2007, 06:19 PM   #24
bushyar15:
Weight for one and everybody said it wouldn't work. Being able to change the flex characteristics by altering the layup schedule.
Aluminum motor mount insert. the 2nd version will have replaceable front and rear skid plates and droop screw plates
Again weight. Also carbon once molded will flex but always go back to it's original position, not bend and stay bent like aluminum. Also all the loading is spread through the whole chassis not just in the front or rear to say.
We chose the 4mm thickness because we thought that would be a good starting point, and everything would transfer directly over.
Wear was a factor we took into consideration, as I stated above the 2nd generation prototypes will have replaceable skid plates in the front and rear. Which we will be able to make out of an assortment of materials.
The Chassis is 100% carbon fiber. The plain weave is easier to deal with in the process we are using. The chassis is 95% molded with 5% post machining.
The buggy is at minimum weight with no Titanium.
Robert Bartlett
Old 09-12-2007, 06:23 PM   #25
gearheadz80's Avatar
Do you have a website? Or where will they and your other prouducts be available?
gearheadz80 is offline   Reply With Quote
Old 09-12-2007, 06:32 PM   #26
Stop it Robert!!! You are making me drool!!!
Colin
www.ColinBranch.com
Old 09-12-2007, 06:38 PM   #27
Our site is under construction. Give us a call
Robert Bartlett
Old 09-12-2007, 06:43 PM   #28
Thanks for the responses!
HPI - Blitz
Old 09-12-2007, 08:07 PM   #29
No problem, I hope I answered all your questions completely.
Thanks Robert
Robert Bartlett
Old 09-12-2007, 09:31 PM   #30
rallyebmx's Avatar
Any plans for other buggies? Jammin?
rallyebmx is offline   Reply With Quote
TC3 with IRS Carbon FIBER CHASSIS maddog23 R/C Items: For Sale/Trade 5 07-30-2008 01:07 PM
[FS] Xtreme Carbon Fiber Losi JRXS LTO Chassis squarehead R/C Items: For Sale/Trade 4 04-07-2007 05:16 AM
WTB: TC3 Carbon Fiber Chassis mjm R/C Items: Wanted to Buy 2 11-02-2005 06:44 PM
WTB: TC3 Carbon Fiber Chassis mjm R/C Items: For Sale/Trade 0 11-02-2005 09:24 AM
TC3 carbon fiber chassis w/one-way FS sands R/C Items: For Sale/Trade 1 10-10-2003 08:53 AM
