Old 09-05-2007, 11:19 AM   #1
Exclamation Newbie to t-maxx NEEDS HELP!!!
ok i got ahold of a t-maxx a couple of days ago. it wasnt running because the guy detuned it so bad, i fixed that. but when i got it running and i would give it gas to go instead of smoothly taking off. it jumps violently like the transmission is engaging and disengaging. and then to top it off when i flip the switch on the remote to put it into reverse sometimes it wont go into reverse. or when it does go into reverse it wont come out!?! lol im new to these trannys can someone help me out?
avengeddeville is offline   Reply With Quote
Old 09-05-2007, 11:36 AM   #2
fhm555's Avatar
On the jerking on takeoff, it could be your engine clutch not engaging properly or the forward clutch in the transmission. It could also be a high idle which will also cause it to not shift between forward and reverse like it should.
fhm555 is offline   Reply With Quote
Old 09-05-2007, 11:38 AM   #3
ok i see what you are saying, but the jerking almost seems like what you said but at the same time like the tranny is gone. is there any adjustments that i can make to stop that?
Old 09-05-2007, 12:10 PM   #4
Unless this is the 3.3 transmission, it will do this all the time. Both my buddy and I had the original tranny on our T-maxx and it always did that until we switched to the 3.3 tranny. Same thing with the reverse. You have to play with the switch a little to get the tranny to engage.
_____________________
Sponsored by:
Fusion Motorsports
Bad Dog Rc
www.baddogrc.com
www.speedtechrc.com
My rides
Jammin CRT.5 w/ OS .12 TZP 5
Team Losi 8ight-T w/ Ninja JX .21
stiffler297 is offline   Reply With Quote
Old 09-05-2007, 10:47 PM   #5
fhm555's Avatar
The only way to get a postive forward motion out of the old maxx is to install a forward only conversion. This will replace the internal transmission clutches with a direct drive unit. Of course as the name implies, it also does away with reverse.
Old 09-07-2007, 03:46 PM   #6
jatoman1992's Avatar
Trader Rating: 4 (75%+)
Send a message via Yahoo to jatoman1992
same thing happened to me with my 2.5, it turned out to be the little arm that switches the tranny into reverse,it was too far forward so it would like be in neutral then it would switch into forward(sometimes reverse), just a ??? does the 3.3 tranny bolt right in to the place the old one does?
jatoman1992 is offline   Reply With Quote
Old 09-12-2007, 12:13 PM   #7
Yep! It sure does.
Sponsored by:
Fusion Motorsports
Bad Dog Rc
www.baddogrc.com
www.speedtechrc.com
My rides
Old 09-12-2007, 05:04 PM   #8
fhm555's Avatar
Can you run the 2.5 clutch bells with the 3.3 slipper?
Old 09-12-2007, 05:25 PM   #9
YEP!
Sponsored by:
Fusion Motorsports
Bad Dog Rc
www.baddogrc.com
www.speedtechrc.com
My rides
Solid aluminum fron & rear E-Maxx/T-Maxx bumpers. Brand new! BADAZZPSD R/C Items: For Sale/Trade 4 06-30-2008 08:00 AM
Newbie... I wanna race my Maxx .26!!!! Dyna-Maxx Rookie Zone 1 06-04-2007 09:25 AM
E-Savage vs. E-Maxx for Newbie ZBoater Rookie Zone 1 10-03-2006 11:16 PM
Newbie: Traxxas Stadium Maxx RTR mwm Rookie Zone 3 02-08-2006 09:26 PM
