Old 06-22-2010, 06:38 PM   #196
cordarrow's Avatar
Trader Rating: 17 (100%+)
Tuning for smoke is not suggested with this fuel.
That alone will keep me and most others I know run screaming like a little girl away from this fuel...
So...............you care to tune with a heat gun????
cordarrow is offline   Reply With Quote
Old 06-24-2010, 02:10 PM   #197
The correct quote in context is below, and is correct. I tune to performance, smoke and heat temps are only refferences.
"Some people make an error and tune for only smoke coming from the pipe, I have been able to get 350 head temps and it still smoke like a motor than was running 150. Tuning for smoke is not suggested with this fuel. I run a Jammin .21 plus, that is on its 9th gallon, and get about 10 minute runtimes avg. with head temps about 210, depending on weather and such.
That being said, I have had a few people that tune strictly on smoke and have worn out the piston and sleeve because of it being to lean. They were really lean 12-18 hours leaner from the previous fuel they used. Castor and Synthetic oil have a flashpoint within a few degrees of each other, it is just the type of oil difference that causes the smoke difference."
Try this and you will see the reasoning behind it, take 3 tbsp of castor oil and 3 tbsp of a synthetic oil. Both have a similar flashpoint, but the synthetic will take longer to burn and have a thicker, richer smoke. I am sure this being RCTech this will be taken out of context as well, but I try.
PS You can make that 10 1/2 gallons now.
WWW.TRJPERFORMANCE.COM
WHOLESALE RETAILER FOR BYRONS, SIDEWINDER AND AMSOIL
(980) 721-5943
thabiuk is offline   Reply With Quote
Old 07-22-2010, 08:44 PM   #198
Visit TRJPERFORMANCE.COM and receive 15% off your total order by using code, SUMMER15.
TRJPERFORMANCE.COM is the leading southeast retailer for Torco Race Fuels, Oils and Lubricants, and VSR Race Products. TRJPERFORMANCE.COM also offers the lowest advertised prices on the internet.
Discount applies to all in stock and order items, same day local delivery is available on warehoused items.
Call 980-721-5943 for any more information.
(980) 721-5943
Old 07-25-2010, 08:16 PM   #199
Just to let everyone know,
I have the following Torco and VSR Products in house that have been tried by local racers with great results.
Torco Air Filter oil - super tacky, cleans very well
Torco Moto Prep - a polymer coating, that protects chassis and components, makes for easy clean up and does not evaporate from the surface or wash of with water.
Torco Chain Lube - Great for CVD's and ring and pinions in RC cars. Power Slide® Chain Lube is an MPZ® formulated lubricant with extreme wear and rust protection chemistry. Quickly penetrates deep into bushings, pins, bearings and rollers then sets to a stable grease that will not fling off or melt under high temperature conditions. Designed to exceed the demands of high performance and racing conditions.
Torco MPZ Lube - an all round lube, great for hinge pins etc...
Torco Brake and Contact cleaner - A Non-Chlorinated cleaner, plastic safe and will not damage radio trays, plastics etc... More economical and a better value than Nitro Cleaners.
VSR Screw kits, 1/8 Metric, 1/8 Standard, 1/10 Metric, 1/10 Standard --- great all purpose kits, that include more of what you need and a bottle of VSR screw glue. ON SALE --- $20.00 PER KIT
VSR Wheel Nuts - premium 1/8 scale wheel nuts, anodized in red, blue or black. Available in Ofna thread and Losi, Assoc, HB etc thread. ON SALE --- $10.00 PER SET.
All of this stuff is in stock and ready for local delivery or shipment, Case order discounts available.
(980) 721-5943
Old 07-26-2010, 07:33 PM   #200
For orders of 12 or more cases, I will give you Jobber pricing.
That is almost 35% in some cases off of retail.
Wether it is RC fuel, motor oil, transmission fluid, gear oil or any of the sprays. This is a huge savings.
(980) 721-5943
Old 07-29-2010, 12:47 PM   #201
All orders that were placed the last few days have been filled and have been shipped.
(980) 721-5943
Old 07-29-2010, 05:39 PM   #202
What's the higest nitro content I can get, Boat racer>>>>>
MBX6/Techno MMM-2200/MBX6-Nova Plus-4C/ MBX5R-Werks B7
MBX5R-Nova Plus-4C/Mini Inferno brushless/ 14yr Daughter's rigs.
Losi XXXNT Phantom/Few MBX5Pro spares
MST-1 Nova/MST-1 soon to be brushless
/About a dozen Nitro boats .12-.90/
153stars is offline   Reply With Quote
Old 07-29-2010, 06:18 PM   #203
I can get any percentage nitro mixture you would like. It would be a case minimum order.
(980) 721-5943
nitrotane fuel from VP racing YANMAN Nitro On-Road 3 07-26-2008 06:06 PM
O'Donnell Racing Fuel vs. R2R Fuel SKOT Nitro Off-Road 4 12-28-2007 06:34 PM
AT Racing Fuel for Sale ::TEAM SRGS:: Australia For Sale/Trade 0 06-20-2007 02:56 AM
Where to by AT Racing fuel shiston Australian Racing 5 08-28-2006 03:54 PM
<NEW> MONSTER TRUCK FUEL FROM MAXY'S PRO RACING FUEL !!!! <Maxy's> Nelson Racing Forum 0 11-08-2005 09:13 AM
