Old 09-03-2007, 06:39 AM   #1
Default how to replace the clutch bell
i stripped out my clutch bell gear when m motor shifted to the right and i cant get it off. it is an xtm 24.7 if that helps any.
jacked up truck is offline   Reply With Quote
Old 09-03-2007, 06:56 AM   #2
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
Remove your motor from the truck, hold the flywheel with a rag and a pair of channel locks.
Remove the screw from the end of the crank, you should then be able to pull the clutchbell off.
Inspect your clutch shoes and bearings while you have it apart.
Dayton
Serpent,Sanwa,Fantom Racing
92zero.com,Lunsford Racing,AKA Racing
TXD Snake Skin Graphix
1armed1 is offline   Reply With Quote
How often do you replace Clutch Shoes? Don Duct Nitro Off-Road 3 05-09-2008 12:08 PM
Shim between inner clutch bell and clutch shoes razor_clawzz Nitro Off-Road 8 02-03-2008 09:24 PM
New kyosho flywheel and clutch bell plus 2 unopend clutch shooes tlxxx4driver R/C Items: For Sale/Trade 0 07-17-2007 02:54 AM
WANTED:Savage parts-clutch bell, clutch shoes, rear driveshaft,etc..Orlando, Fl. 10gter Florida Racing 0 01-26-2004 08:54 AM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 04:01 PM
