Old 09-04-2007, 01:49 PM   #16
Originally Posted by meon99 View Post
i have the sportwerks .21 very smooth engine,, but not fast....
fast as in a straight line or lap times? two totally different things
mugenlife is offline   Reply With Quote
Old 09-04-2007, 07:59 PM   #17
kevinmajor's Avatar
I don't understand why someone would buy a B3 for $200, spend another $50 to $70 for a carb, spend another $20 for bearings (after the stock ones fail at 2 gallons) when you can buy a high quality race engine like a P-5X, P7-R, S-5, V-Spec or something like that for only $30 to $80 more.
kevinmajor is offline   Reply With Quote
Old 09-04-2007, 09:17 PM   #18
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
Originally Posted by Rocket42 View Post
Well for not much more than these sport engines you can buy a Go tech and get a full bred race engine, which will have all the top of the line features already installed such as good bearings and a top of the line carb.
this is what i would do!!!!!!!! GoTech 5 port .21!!!!!!!!!
Jason Halvorson is offline   Reply With Quote
Old 09-05-2007, 04:58 AM   #19
Davidka's Avatar
Trader Rating: 75 (100%+)
Werks engines have an excellent rep for durability and the carb talk just isn't true. The 1st gen carb (first run of gold heads) were finicky but they are as good as any carb on the market now. The bearings? You must be thinking of OS V-specs.
Old 09-05-2007, 06:01 AM   #20
free2day77's Avatar
the carbs on the b3's are not working right at the moment(have a friend that runs for them confirmed it). I have run RB S3's in the past and love them. RB's last a long time and once they break in (about 2 gallons) they will scream.
free2day77 is offline   Reply With Quote
Old 09-05-2007, 07:01 AM   #21
tex1's Avatar
Send a message via Yahoo to tex1
Thumbs up
The original Works engines had carb issues. The new ones seem to run very well. They are crazy fast.
I'm an RB guy. I can honestly tell you the S3 was not ment to run in the same league as the B3 from Works. Now you do a little modding and use the proper pipe and you you will be right there.
The RBs use Nova carbs and bearings. Nothing but the good stuff.
Sportworks motors ar just as good as any of these. I'll put them to the test with these motors any time. BTW - we do it every week.
JPX - 21 - is a P5 motor. It runs the same and has the same durability.
The S3 is smooth and will not get you in trouble on a small track. It is all about the pipe and header. Later you can cut it if you want more out of it.
The B3 is hotter with more bottom end punch. The new ones are very good.
TEX
tex1 is offline   Reply With Quote
Old 09-05-2007, 09:36 AM   #22
I was very pleased with the b3 until it started the hot starting problem. It seemed to out pull everybody else on the front straight. what is causing it not wanting to start when it is warmed up? I am talking like 200 deg F. I have tried about everything. I use a novarossi plug cold. I tried the next step up plug, retuned the carb. resealed the engine even though the engine has orings through-out. I just gave up and decided to try the rb s3.
Norris is offline   Reply With Quote
Old 09-06-2007, 08:02 AM   #23
killabud's Avatar
I say go with the RB. I just got one of these not long ago and it rips for teh money. Its not the fastest motor out there but its smooth and I think that counts more sometimes. Ive been running it with a JP3 pipe getting 8-9 minutes on a pretty large track (and a heavy trigger finger). All that said plus its an RB so you know it will last. :
killabud is offline   Reply With Quote
Old 09-06-2007, 10:39 AM   #24
Send a message via Yahoo to windellmc
The JPX-.21 is based on the Picco P7R-EVO2 engine. It is supposed to have a little more bottom end than a Nova P5 and a lot more top end. It is probably a steal at the $229 I see it advertised for. I believe you can also get the Picco P7R for that price at Nitrohouse.
windellmc is offline   Reply With Quote
Old 09-06-2007, 04:00 PM   #25
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
not to change the thread but i have the collari b3,what pipes work good i have the jp-1 thats what came with my buggy
Jamie W
*Team Tekin*TLR Racing*DE Racing*92 Zero Design*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 09-06-2007, 04:36 PM   #26
I like the Novarossi 086 on the B3 engine. That engine needs the most help on top end which is what the 086 does. The 053 will smooth out the powerband a little which might be good on a slick track. I would expect the JP-2 to also be good but I have never tried it.
Werks B7 Pro speed metal Onroad Nitro Engine Zone 65 05-24-2012 10:56 AM
++++WERKS B7 PRO & B3+++ David Wall R/C Items: For Sale/Trade 44 08-21-2008 06:20 AM
Werks B7 Pro KDub75 R/C Items: For Sale/Trade 7 06-14-2008 01:46 PM
Werks B3 Pro Nitro$junkie Electric Off-Road 1 05-21-2007 08:59 PM
WERKS B3 icemandolmite Electric Off-Road 4 02-25-2007 12:11 PM
