Old 08-30-2007, 06:54 PM   #1
Default Shock Questions, please help
On my Nitro Rustler the top of my shocks keep popping off. I think my threads are screwed up? Is there any after-market ones with stell threads, and also my tower broke any suggestions on what to get.
thanks.
jmdv is offline   Reply With Quote
Old 08-30-2007, 07:27 PM   #2
go with some aluminum shock caps
vroom88 is offline   Reply With Quote
Old 09-03-2007, 09:02 AM   #3
k, thanks, do i just order them at my local traxxas dealer, what about shock towers should i just get another stock one, thanks alot.
Old 09-03-2007, 01:54 PM   #4
any help????
Old 09-03-2007, 07:45 PM   #5
jatoman1992's Avatar
Trader Rating: 4 (75%+)
Send a message via Yahoo to jatoman1992
yeah you could just get the stock ones(like 2 or 3) or u could get an aluminum shock tower(just not integy), and yes u should be able to get alum. shock caps at ur LHS. any more ???? just ask
jatoman1992 is offline   Reply With Quote
Old 09-05-2007, 06:51 AM   #6
Ya I ll probly just get an aluminum shock tower. As for the shock caps, why would i get aluminum caps there just as liekly to rip through the threads on the shock, causing the same problem over again, right? What r the best (and most affordable) shocks for my nitro rustler, that dont have plastic threads?
Old 09-05-2007, 12:44 PM   #7
Anyone?
Old 09-05-2007, 02:40 PM   #8
no the alum. shock caps wouldn't come off cuz they fit tighter and the problem with your shock caps now is probably just from the cap being stripped not the shock itself. if not these will probably work,
http://cgi.ebay.com/4-Aluminum-threa...QQcmdZViewItem
or this, u have to scroll down to find the shocks they are for the duratrax nitro evader but will fit the nitro rustler:
http://www.duratrax.com/cars/dtxd62e.html
Old 09-05-2007, 04:14 PM   #9
i cant really tell whats the problem, they have just been falling off, the threads are so small on the shock that i cant really tell if the threads are done on it, do u think that it most likely the caps?
thanks
Old 09-07-2007, 04:10 PM   #10
on all the t-maxx shocks i've had(basically identical to the rustler)its always been the shock caps, but if you want to be safe definately get the aluminum duratrax ones i posted or you cold get the aluminum big bore shocks from traxxas but they cost much more, if ur racing the big bores are a great investment
Old 09-07-2007, 08:31 PM   #11
fhm555's Avatar
A lot of shock cap problems can be caused by overtightening the top mount bolts. If they can't move they will deform.
If they are the same as t maxx shocks, here are the best shocks I ever ran on a t maxx. Sell the extra set and you could wind up with a good set of shocks for $30 or so.
http://www2.towerhobbies.com/cgi-bin...?&I=LXVH03&P=7
I got the shocks and optional aluminum caps new and that set of shocks ran on 3 different t maxx race chassis and were still in good shape when I sold them. I rebuilt them once a year and replaced the plastic ends. Other than that and the occasional bent shaft they just worked. I did use trinity aluminum shock standoffs with the delrin balls though.
fhm555 is offline   Reply With Quote
Old 09-08-2007, 06:27 PM   #12
that sounds good, HA i might even get those for my T-Maxx
Old 09-09-2007, 05:35 AM   #13
k thanks, im going to give the stock stuff one more try cause my buddy has the same car and he hasnt had any shock problems. So I dont tighten the actuall bolt that holds the top of the shock on to the tower too tight right?
Old 09-09-2007, 03:48 PM   #14
fhm555's Avatar
Yes the top of the shocks should be able to move a little. Tighten the top mount screw untill it's all the way down, then back it off just enough to let the shock move freely. You don't want too much slop or the mount screws will bend, but too tight will cause you problems with your shock caps.
hyper7 shock questions and other questions buds302 Nitro Off-Road 1 06-10-2008 11:03 PM
RC18T - Shock Questions Cain Micro and Mini Scales 8 11-16-2007 01:38 PM
Shock Questions jmdv Nitro Off-Road 8 08-08-2007 05:45 PM
Shock oiling questions PSiDAWD Rookie Zone 4 03-30-2006 05:53 AM
NTC3 Shock and Team Associated Shock Caps Question jcrouse Nitro On-Road 4 07-13-2003 09:11 PM
