Old 08-29-2007, 12:56 PM   #1
Default i just got a roto start should i replace any thing else
i just got an ofna roto start for my xtm engine. And then i used it and then it started to slip so i replaced the shaft. then i started to use it and it started slipping again. What should i do should i replace the bearings.
jacked up truck is offline   Reply With Quote
Old 08-29-2007, 02:12 PM   #2
jchas26's Avatar
Sounds like the problem I just had. it was the pin and spring in the drive shaft that catches on the backplate of the starter not the shaft or bearing though. Really it was just the spring, I had the problem while breaking in my engine. went through about 3 set before the engine was loose enough to not strip them now everything is fine. hope this helps the part cost about 4 bucks. I could find the part # if you want.
jchas26 is offline   Reply With Quote
Old 08-29-2007, 03:04 PM   #3
Default could you please tell me what the spring does
the spring came with the shaft when i bought it. but i didnt worry too much about it.
Old 08-29-2007, 05:13 PM   #4
Default spring
what does the spring do?
Old 08-30-2007, 07:10 AM   #5
jchas26's Avatar
with the pin, it catches on the rotostart backplate when it is turned Mine got compacted since my engine was so tight during break in and had to be replaced. Does the start turn and turn? take of the rotostart then the back plate. pull the shaft and it is seated in the crank where the piston arm is connected. You will see a little pin. pull it out with needle nosed pliers and the spring is in that hole. you may need a pick to get it out if it is compressed. Hope that helps, it took me a week to figure out that was my problem. It was the last thing I replaced too!
Old 08-30-2007, 12:32 PM   #6
Default thanks
thanks but, i dont think the guy i got it from replaced the spring when he replaced the pull start.
TRX 2.5 w/ pipe, header, Roto Start backplate, Complete EZ Start system milt R/C Items: For Sale/Trade 4 06-29-2006 03:29 PM
Wanted Pull start/roto start for collari .30 seajj2 R/C Items: Wanted to Buy 5 08-31-2005 04:51 PM
WTB: Pinion Gear for the HPI Roto Start unit or Cheap Roto-start (broken or not) nitrorocks R/C Items: Wanted to Buy 1 08-11-2005 04:40 AM
Ofna shaft start / roto start mellow7399 R/C Items: For Sale/Trade 0 04-06-2005 04:30 PM
Pull Start? Roto Start? or Starter Box? jamiekulhanek Electric Off-Road 3 09-09-2004 12:50 AM
