Old 08-28-2007, 06:20 AM   #1
aussies1129's Avatar
Trader Rating: 74 (100%+)
Default KYOSHO GXR.28 REMOVE FLYWHEEL PROBLEM?
hi whats the best way to remove the flywheel on my gxr28 engine I thought it would just slide off but after taking off the flywheel nut the flywheel is stuck on tight? any suggestions would be appreciated?
thanks
Michael
aussies1129 is offline   Reply With Quote
Old 08-28-2007, 06:34 AM   #2
khoo's Avatar
thanks
Michael
Michael,
just knock it out from the back. knock it at 90 deg intervals. It should pop out
khoo is offline   Reply With Quote
Old 08-28-2007, 10:13 AM   #3
killer89's Avatar
Trader Rating: 41 (100%+)
Send a message via AIM to killer89
If you really can't get it off by knocking (don't try a screwdriver, bad idea), then theres one sure way of getting it off.
I only do this for flywheels that are REALLY stuck. Basically, remove the p/s/r assembly and the backplate. Then insert a screw in the end of the crank, so it doesn't chip, then knock it on a piece of wood until the flywheel pops off.
killer89 is offline   Reply With Quote
Old 08-28-2007, 01:58 PM   #4
thanks guys I was hitting the wheel with the hard plastic end of a screwdriver but it is very stubborn but I will keep trying !
cheers!
Old 08-30-2008, 06:39 AM   #5
Default easy fix :)
Buy a 5 dollar battery terminal puller at any parts store...the flywheel will come off in about two seconds with no damage to the crank. You'll be glad you got one!
wsurockclimber is offline   Reply With Quote
How do you remove flywheel? deskwarmer Nitro Off-Road 9 05-22-2008 07:28 AM
how do you remove a flywheel from a nitro engine TeamFast Rookie Zone 6 04-26-2008 10:47 PM
HOW DO I REMOVE A FLYWHEEL??? HELP PLZ paul73rc Nitro On-Road 15 06-23-2007 07:33 AM
how to remove nut that attached to flywheel?? bigboss Nitro On-Road 11 10-03-2006 07:42 PM
how do i remove my flywheel? downunder23 Nitro On-Road 5 08-26-2006 03:18 PM
