Old 08-25-2007, 11:13 PM   #1
ericspainter's Avatar
Default Novarossi S821B 8 port nitro % ?
what im wondering is can you use 30% in these engines.it says only 25% but i cant see a race motor not being able to use 30%.so any input would be helpful and does anybody else use this motor.thanks a .bunch
ericspainter is offline   Reply With Quote
Old 08-25-2007, 11:46 PM   #2
freefallmarine's Avatar
30% is perfect for this motor. That's what it comes shimmed for is 30%. Youll love it.
freefallmarine is offline   Reply With Quote
Old 08-25-2007, 11:59 PM   #3
Default re
cool im putting it in my 8T.so pay no attintion to the manual 30 ic ok
Old 08-26-2007, 12:04 AM   #4
30% will be fine. 25% is big in europe where the engine is made. But 30% is the standard here in the US. Before you bolt the motor on the truggy, be sure to count the turn's on the high end needle and the low end needle. You can do this by turning the needle all the way in and counting the turn's, this help's you find the factory setting if you should ever get out of tune.
Old 08-26-2007, 12:42 AM   #5
Default re
cool man no nead toadd shims then right.
Old 08-26-2007, 07:45 AM   #6
GHETTOTEACHER's Avatar
If that engine is shimmed for 30%, there is no problem.
(Me) I would check the speck sheet then double check the shims with calipers. Most big blocks are shimmed at .60mm. I would shim at .75 for 30%.
The motor will run fine with set factory shims with 30%. Retune and just watch your temps.
GHETTOTEACHER is offline   Reply With Quote
Old 08-26-2007, 12:32 PM   #7
Default update
got her all broke in today and man what a beast of a motor.thanks for the help guys
****BRAND NEW IN THE BOX NOVAROSSI S821B**** jz113 R/C Items: For Sale/Trade 18 08-21-2008 09:18 AM
Novarossi 21+5, 21BF 3-port, & GO Tech .21 7-port Turbo!!! $110 shipped!! HoustonAreaRC R/C Items: For Sale/Trade 5 08-05-2008 09:30 AM
<<<<<<hot mods s821b novarossi>>>>>>> thesavagekiller R/C Items: For Sale/Trade 8 04-05-2007 06:41 PM
Looking for maual for novarossi s821b Tony Rivas Electric Off-Road 1 02-21-2007 05:14 PM
