Old 08-22-2007, 09:30 AM   #1
Default werks clutch spring
what will be the difference between the springs assuming that you tune the clutch to engage at same rpm (but different spring)?
dotan23 is offline   Reply With Quote
Old 08-22-2007, 11:08 AM   #2
I think that if you tighten the spring to get a later engagement, there will be a point that the nut is too far in and the front plate can not move forward far enough to let the shoes touch the clutchbell. In this case you will move to a harder spring to get the same engagement without the adjustment nut being too far in. Hope that made sense.
g26er is offline   Reply With Quote
Old 08-22-2007, 08:08 PM   #3
AzBobby's Avatar
as g26 said, it all comes done to the feel you want from your clutch. this is also affected by the type of shoes you choose, and if you mix them up to get even more feels from the clutch. if you find your self tightening the clutch nut in alot then yes go to a heavier spring. but this same feel can also be affected by your diffs and the fluids you use in them. then again also your gearing will affect feel too. along with motor tuning and pipe you choose for your motor.
what car and motor and pipe are you running?
GO TECH
AzBobby is offline   Reply With Quote
Old 08-23-2007, 01:10 AM   #4
i'm running 8ight with go 7p / v-spec. accually the cluth start to tighten itself and slip latly and i think the gold spring became weak, maybe because i did tighten it more than it should be.
New Werks Clutch BRETTMASTERJ Nitro Off-Road 6 02-12-2008 12:32 AM
my new werks clutch spudly12 Nitro Off-Road 4 01-04-2008 02:39 AM
werks clutch fs grd4spd25 R/C Items: For Sale/Trade 3 05-06-2007 06:43 PM
$$$$3 werks clutchs used all have spring and shoes $50 each shipped $$$$$ HECTICRACER R/C Items: For Sale/Trade 24 02-02-2007 02:28 AM
WERKS CLUTCH RANDY SMOOTH Monster Trucks 4 01-05-2006 02:11 AM
