Old 08-20-2007, 06:39 PM   #1
dsl
dsl's Avatar
Default What do I use to plug 3PK antenna?
What is everyone using to plug up the original antenna on the 3PK? I'm using FASST and want to remove the original one.
THanks!
dsl is offline   Reply With Quote
Old 08-20-2007, 06:42 PM   #2
I used a rubber end that some use for putting over the carb or exhaust port. I think mine came off of a heater core from a car.
Tanner
Tannerb is offline   Reply With Quote
Old 08-20-2007, 07:42 PM   #3
sickboy's Avatar
Trader Rating: 72 (100%+)
http://www.amainhobbies.com/product_...ducts_id/12821
sickboy is offline   Reply With Quote
Old 08-20-2007, 07:47 PM   #4
I just use an old ball point pen barrel with a wrap of electrical tape around it to plug the hole. It looks good and is cheap.
AreCee is offline   Reply With Quote
Old 08-21-2007, 06:22 AM   #5
wlfgnggtr's Avatar
I use a plastic hole plug I picked up at Lowes for 50 cents... Perfect fit, and looks stock...They are located in the section with all the bolts and nuts... look in the drawers, they are labeled as a hole plug...
wlfgnggtr is offline   Reply With Quote
Old 08-21-2007, 04:55 PM   #6
I use the plug from Lowe's too and they look the best.
dhickman is offline   Reply With Quote
Old 08-21-2007, 05:02 PM   #7
I use the KMW plug. I have 3 in stock.
[email protected]
VP-Pro USA - www.raceVPpro.com
Agama USA - www.AgamaUSA.com
Maxy's Fuel - www.Maxysfuel.com
Machine's R/C H is offline   Reply With Quote
Old 08-21-2007, 05:45 PM   #8
SkeeryJones's Avatar
u guys got pics?
SkeeryJones is offline   Reply With Quote
Old 08-21-2007, 07:05 PM   #9
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
That stand-off for the stock antenna bothered me for some reason. Out came the trusty dremel and a sticker to cover the hole and problem solved. I'll never sell the radio as is, so it's not a problem as far as the next owner is concerned. In an emergency, I can still install a stock antenna. fyi
TeamCarnage is offline   Reply With Quote
Old 08-21-2007, 10:14 PM   #10
wlfgnggtr's Avatar
Originally Posted by SkeeryJones View Post
u guys got pics?
Here you go...
Old 08-22-2007, 08:22 AM   #11
gearheadz80's Avatar
I use the cap off a fuel bottle, push it down in then put the black ring back on
gearheadz80 is offline   Reply With Quote
Old 08-22-2007, 09:01 AM   #12
trebor's Avatar
Originally Posted by wlfgnggtr View Post
Here you go...
WOW! That looks sweet! It looks as if its suppose to be there. I use the plug from AMAIN but I think I might take a trip to LOWES.
Feedback
[url]http://rctech.net/forum/showthread.php?t=153173&highlight=trebor[/url]
trebor is offline   Reply With Quote
Losi/GRP Non-Tuned (Standard Plug) .21 vs the Tuned (Turbo Plug) .21 jsmax Nitro Off-Road 0 07-07-2008 08:17 PM
Antenna Plug 3PKS last Radio and Electronics 4 11-14-2007 09:37 PM
Turbo plug Vs Standard plug mrhenning11 Electric Off-Road 1 04-16-2007 09:20 AM
Acratech Antenna Plug for Airtronics M11 MasterBlaster Electric On-Road 5 01-15-2006 05:44 PM
Turbo plug vs standard plug shortygy Onroad Nitro Engine Zone 5 08-13-2004 04:10 AM
