Old 08-20-2007, 03:31 PM   #1
Default Truggy wont Idle Without Ignitor On
Hey guys just got a crt.5, with the picco 7 port, Iran it a few times and the thing kept dieing randomly, the glow plug then died so i attributed the problems to the glow plug, i just replaced the glow plug and the truggy drove fine for a few minutes and then died, ever since i cant get the ctruggy to idle without the ignitor in, if i give the truggy some gas it will idle and rev properly however if i give it 3/4 to full throttle it ides again, any ideas???
Shawner85 is offline   Reply With Quote
Old 08-20-2007, 03:35 PM   #2
It sounds like it's running too rich and flooding out. Lean the high speed needle. Watch the temps with a temp gun.
satoch is offline   Reply With Quote
Old 08-20-2007, 03:36 PM   #3
Oh sorry forgot to mention i'v tried leaning and richen it out and i reset the needles to stock setting and on and on with no luck
Old 08-20-2007, 03:52 PM   #4
xlgraphicspro's Avatar
pull your glow plug out and put it on the ignitor to see if it works properly, sometimes the top coil doesn't light up, and causes it to only fire when the ignitor is attached. Then try a new plug, if that doesn't help, then it's a tuning issue. make sure your idle screw is in enough so their is a 1mm gap when the carb is closed. then tune the engine based on that. your gap might be too big!
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 08-20-2007, 04:36 PM   #5
fhm555's Avatar
Sounds like you have a bad glo plug.
fhm555 is offline   Reply With Quote
Old 08-20-2007, 04:55 PM   #6
hmm sounds possible, luckly i grabbed two so i'll try the 2nd one and go from there
Old 08-20-2007, 07:40 PM   #7
ollie 45's Avatar
Trader Rating: 18 (100%+)
I had the same problem a few weeks ago with my buggy. Come to find out the glow plug was bad. I put a new one in and it was fine. Good luck!
ollie 45 is offline   Reply With Quote
Old 08-20-2007, 10:14 PM   #8
is it possible buddy sold me the wrong plug? Its a racers edge turbo plug and it has a number 7 in the corner
Old 08-21-2007, 03:58 AM   #9
joe of loath's Avatar
does the engine take turbo plugs? i think they are longer...
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 08-21-2007, 11:39 AM   #10
Yeah im using turbo plugs i tried new plugs doesnt change anything, still dies as soon as the igniter off?
Old 08-22-2007, 11:22 AM   #11
Alright, so i'v pretty, much had enough of this thing, the clutch seems fine, i tried running the motor without anything on it and it still dies, i must have gotten a couple of defective glow plugs... any other idea? I replaced my fuel lines and tried running it off another fuel tank, i cleaned the esxaust pipe and made sure nothings blocking it.... its gotta be the plugs eh? Is it possible the plugs the guy sold me are too cold? He said they are hot plugs but i have no idea at this point... help! lol
Old 08-22-2007, 05:29 PM   #12
TeeKuang's Avatar
You should try OS P3 plug
TeeKuang is offline   Reply With Quote
Old 08-25-2007, 11:55 PM   #13
bcane98's Avatar
Trader Rating: 21 (100%+)
Give the motor once over... make sure all screws are tight.
Not sure of your RC knowledge level, but are you sure you should be running Turbo Plugs? You need a turbo under head in order to run turbo plugs.
bcane98 is offline   Reply With Quote
Old 08-26-2007, 12:04 AM   #14
ericspainter's Avatar
Default re
check clutch shoes and bearings.if they are bad it wont idle.it will only run at full trigger.i have whacked some good tunes out by not checking the obvious many times.
ericspainter is offline   Reply With Quote
Old 08-26-2007, 12:11 AM   #15
Send a message via Yahoo to infanterene
Try the P3. Eversince I switched to that plug my motors can idle forever. By the way Racers edge plugs stink. I have used atleast 7 or 8 and not onehas lasted more than a few tanks. I still have like 5 and just give them away at the track when people need them.
RC America - Team X-Ray - Maxys Fuel
infanterene is offline   Reply With Quote
F/S F/T Ignitor & Horent Roller MUST GO! InsaneRC R/C Items: For Sale/Trade 8 12-03-2007 06:05 AM
Ignitor/buggy InsaneRC R/C Items: For Sale/Trade 12 11-30-2007 08:18 AM
Best glow plug ignitor?... Vyrus Onroad Nitro Engine Zone 9 03-02-2005 12:51 AM
HPI glow ignitor F/S roadrunnerspeed R/C Items: For Sale/Trade 2 04-03-2002 09:45 PM
Glow Ignitor Wanted roadrunnerspeed R/C Items: Wanted to Buy 3 03-14-2002 04:18 AM
