Old 08-19-2007, 03:23 PM   #1
Default Can't get buggy to idle without engaging clutch
I can't get my Sportwerks mayhem to idle without engaging the clutch. If I set it too low, it will die. Is there any clutch adjustment or something? I read the manual and you can set the clutch shoes 2 ways and I set it the way where it won't engage as hard ( trailing ).
bambooi is offline   Reply With Quote
Old 08-19-2007, 09:24 PM   #2
xlgraphicspro's Avatar
Your clutch bearings might be ceased up, or your clutch springs might have a problem. Whatever the case, your clutch is dragging when it shouldn't be!
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Old 08-19-2007, 10:24 PM   #3
looper's Avatar
Trader Rating: 19 (100%+)
Send a message via Yahoo to looper
+1 on that replace the bearings and clutch springs,, the springs can weaken over time
looper is offline   Reply With Quote
Old 08-20-2007, 02:39 AM   #4
asw7576's Avatar
you need harder springs.
try mugen seiki springs 1.0mm thickness if you are using plastic clutch shoes, or 1.1 if you are using mugen seiki alluminium clutch shoes.
Old 08-20-2007, 01:56 PM   #5
How do install the clutch because I can move the clutch shoes in and out when installing them. Should the clutch shoes be inplace until enough centrifugal force pushes them out?
Old 08-20-2007, 02:09 PM   #6
X1 Hybrid T1's Avatar
The spring has a long, and a short leg. The long goes on top of the shoe, and the short has to be forced behind the clutch nut as you put the shoe over the flywheel post. If you don't have a clutch spring tool, it can be difficult, but you can do it.
We don't stop playing because we grow old;
We grow old because we stop playing!
Dave Steen ROAR #5692
Serpent 720,710,9020, Xray T1-05
Jammin X1-CR,CRT,CRT.5,Asc T4,Losi XXX4
X1 Hybrid T1 is offline   Reply With Quote
Old 08-20-2007, 03:04 PM   #7
or you could buy a losi clutch and then it's super easy, plus with a 4 shoe clutch, you can experiment with different combinations of shoes and springs
Also, you could buy the mugen clutch shoes and spring, it's set up kindof like a 1/10th scale truck clutch. the kind with 3 shoes and a wrap around spring.
Old 08-20-2007, 03:13 PM   #8
BEHIND the clutch nut or in the clutch nut groove?
Old 08-20-2007, 03:26 PM   #9
clutch nut grove, but make sure it's on the side of the nut so it applies pressure to keep the shoes compressed against the nut. It should be pretty hard to pry them up by hand. the force produced by the engines RPM's should fling them out when your on the gas.
It's like one of those rides at a theme park that looks like a huge circular drum, you get inside it and it starts to spin really fast, causing you to fling to the side of the wall making it hard to lift your arms/legs or head. This is kind of how a clutch works, when it stops spinning really fast it's easier to peel your self off the wall, that's what the springs in a clutch do, they retract the shoes to the center when it's spinning slowly.
does this help?
Old 08-20-2007, 03:48 PM   #10
hmm, hopefully it helps, i'll give it a go and let you know, thanks
Shawner85 is offline   Reply With Quote
Old 08-20-2007, 04:21 PM   #11
I just ordered some new clutch springs. I think my clutch springs are messed up or something because I can swing the clutch shoes in or out when installing them. What you guys are saying is that the springs should hold the clutch shoes in place until enough centrifugal force causes them to swing out to grab the clutch bell right?
Old 08-20-2007, 09:17 PM   #12
yes!
clutch not engaging g4s aussies1129 Nitro On-Road 3 07-27-2007 05:44 PM
V One RRR Clutch not engaging theBUZZ Nitro On-Road 1 04-01-2007 03:36 AM
Nitro RTR3 RS4 Clutch Bell not engaging dopex Nitro On-Road 14 07-17-2006 09:53 AM
Nitro buggy won't Idle dan_allen_1 Electric Off-Road 3 02-25-2006 12:55 PM
brakes engaging when on full throttle Illusion-Lighti Oval, Larger Scales and More 1 07-16-2005 05:21 PM
