Old 08-18-2007, 11:15 PM   #1
hyperrex8's Avatar
Default mugen shocks on losi 8 ????
iam getting a little tired og the losi shocks coming apart, even after loctiting the hell out of them, has anyone tried mugen or kyosho shocks on a losi buggy
hyperrex8 is offline   Reply With Quote
Old 08-18-2007, 11:18 PM   #2
Aaron Waldron's Avatar
Whoa, why would you do that?!
What part of the shocks is coming apart? The shock body? Or the screw that holds the piston on the shock shaft?
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 08-18-2007, 11:36 PM   #3
draggindrew's Avatar
I just got threw racing tonight and had 2 shocks come apart on me too. It was the screw on the piston unscrewing itself for some reason. I just rebuilt the shocks last night and used loctite and they came loose. The threads seem fine but I might be wrong.
-Drew
draggindrew is offline   Reply With Quote
Old 08-18-2007, 11:49 PM   #4
It's really important to clean the screw and the inside of the shaft really well with motor spray, so the loctite will stick and hold them together.
When you put the loctite on the screw, spin the screw across your fingertip to wipe the excess off and leave loctite only in the troughs of the threads. Crank the screws down tight, just don't strip the head of the screw!
You can let the shafts sit for a few hours for extra insurance, but you shouldn't really need to wait for the loctite to dry. It's realistic to say that you could make changes at the track and they will stay together.
www.liverc.com
Old 08-19-2007, 08:48 AM   #5
Crim3Wav3's Avatar
lol...change a Losi's oil at the track? i haven't seen it be done with ANY success...they ALWAYS back out. LOL!
Crim3Wav3 is offline   Reply With Quote
Old 08-19-2007, 09:17 AM   #6
What grade of loctite are you using? I've been using a small dab of RED loctite and haven't had a screw back out in a long time.
Stealth_RT is offline   Reply With Quote
Old 08-19-2007, 11:14 AM   #7
sickboy's Avatar
Trader Rating: 72 (100%+)
i have never had a screw back out. i race at least 3 times a month. dont be afraid to crank down those screws tight.
sickboy is offline   Reply With Quote
Old 08-19-2007, 11:14 AM   #8
Blue should be fine. Red is really permanent and you might struggle to get them apart after that.
Crimewave - Changing the shock oil shouldn't have any effect on the piston screw. Though, changing the pistons requires pulling that screw out.
www.liverc.com
Old 08-19-2007, 11:20 AM   #9
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
i change mine at the track all the time and rbuild them there as well
pink_sleeve is offline   Reply With Quote
Old 08-19-2007, 11:33 AM   #10
-Drew
Forget locktite. Use CA there's no need to take them apart. If a shock shaft bends a new screw comes with the new shock shaft. Use a Dremel tool to grind off the head of the old screw so you can reuse the piston. Problem solved. I have multiple shafts with different pistons on them and all of them are CA'd. I never have a problem.
satoch is offline   Reply With Quote
Old 08-19-2007, 02:02 PM   #11
sport10's Avatar
I change my oil all the time and never had one back out. I go one step further and use an xacto to ream the hole in the piston so the screw is a slip fit. This way the piston cannot rotate and back the screw out. I feel this with the use of locktite solves this problem.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 08-19-2007, 02:29 PM   #12
Dougg's Avatar
What about the limit/grub screw? If I let the shock fully extend it would cause the screw to come out. I made sure that the shock is free floating on the top mount by adjusting the grub screw and my problem to go away.
Doug
MBX7r, MBX7R Eco, 22-4 2.0
Dougg is offline   Reply With Quote
Old 08-19-2007, 05:47 PM   #13
Crim3Wav3's Avatar
i'll take my mulligan this time, sir.
Old 08-19-2007, 05:50 PM   #14
KForce's Avatar
Trader Rating: 2 (75%+)
i let locktite sit 10 min and have never had one come apart.
a little thing i do is reem out the shock piston hole a bit with an exacto then stick the screw through the piston and strip it out...ie just keep turning the screw after its all the way in. then put a dab of blue locktite on the end and screw down on the shaft.
i think that people locktite the screw first then put it through the piston which wipes most of the locktite away.
lol just read two post up
yea do that
Team TQ Fuel
OS Speed Engines
Futaba
Panther Tires
CRCRC Raceway Webmaster
FullThrottle Raceway Webmaster
KForce is offline   Reply With Quote
Old 08-19-2007, 09:16 PM   #15
xlgraphicspro's Avatar
I think the losi shock on the 8ight is one of the best when the loctite holds properly.
Hey Aaron, could you suggest a shock shaft that uses a nut to hold the piston on, I think the tiny screw they used isn't the best Idea that losi's cooked up. Even if it stays on, the allen head is so small, that is can strip easily, or even break off the tip to an allen wrench.
Mugen shocks would be a bad idea, plus we'd all ridicule you for doing it!
TeamXray RCAmerica Hudy Xlgraphicspro Paint/ Impulse-Rc Clutch shoes.
Xray XB 808 O.S. Speed Or Ninja JX
xlgraphicspro is offline   Reply With Quote
Mugen X5r,X5t shocks ,frt and rear , NEW rcmike R/C Items: For Sale/Trade 7 02-14-2008 11:09 AM
MUGEN MRX4R SHOCKS. Loveless Nitro On-Road 10 06-18-2007 06:07 AM
mugen shocks and spares patrick lsp R/C Items: For Sale/Trade 2 11-12-2006 10:15 AM
WTB: Mugen shocks for MST-1 karl kobernus R/C Items: Wanted to Buy 2 10-02-2004 11:56 AM
Mugen 1/8 Big Bore shocks SupermaxxRich R/C Items: For Sale/Trade 11 02-13-2004 03:40 PM
