Old 04-22-2008, 02:08 PM   #1261
Trader Rating: 24 (100%+)
Send a message via AIM to pistolpete
So what and how much did you have to shim the rear diff? Also is anyone havin trouble with dirt getting in the bulkheads that house the front and rear diff's?
pistolpete is offline   Reply With Quote
Old 04-22-2008, 02:35 PM   #1262
speedy2's Avatar
shimming of the differentials
just add a 13.2 to 14 x16 x 0.38 mm shim of any other brand
kyosho, mayhem, ofna...like
http://www.amainhobbies.com/product_...ducts_id/23221
to the gear side, between bulkhead and bearing
to push the teeths together
also if necessary, a litttle kyosho shim ( comes in set)
to the 12T pinion gear at the front side to eliminate to much a play
at the center driveshaft
http://www.amainhobbies.com/product_...oducts_id/4067
don't shim to much either though
just feel the gears moving with your fingers
there must still be just a little play
with new gears check after 1/2 gallon and redo till perfect
as for the inner shims of the differentials
better just use the OCM shims as they have specs not like any other brand
having 0.12 for older models, to 0.20 mm(latest) for the small spidershims
and
especially 0.38 mm of thickness for the big shims
against usually 0.20 / 0.20 - 0.30 range
the old, very thick black diffgaskets, had to be used with 2x 0.12 mm shims at the spidergears
latest set-up is 1x 0.20 mm shims at the spidergears and paperthin gaskets
//JQ The Car forever/ Soar //Protek-Ace-JR
speedy2 is offline   Reply With Quote
Old 04-22-2008, 02:49 PM   #1263
speedy2's Avatar
as for the dust getting in the bulkheads
a serie of bulkheads form a little cone at the 2 halves
connecting space
and dust could get in, especialy in the ones at the rear
you can put some grease or silicone at the edges
or grind the cone level
just use a little file and grind off material... in the middle only!
and again not to much, just enough ..to make sides +- equal
5 minutes work is all it takes..but take it slow and check
every dozen strokes of the file
(see images)
you can also dremel the arms U-way
at the points where the outdrives hit them when using much antisquat..
the new bulkheads coming will have all issues fixed ..
Old 04-22-2008, 03:28 PM   #1264
awesome gigi! Great pics
Peterson....how is the new ride going otherwise?
ABURTON is offline   Reply With Quote
Old 04-22-2008, 04:43 PM   #1265
It's going good. Made some changes from the initial shake down setup and the car is really fast. I'm just gettin used to a little heavier car right now. Don't get me wrong I like the feel of a heavier car. I've been used to a RC8. The heavier car is more forgiving and I'm just getting used to that again. A.B. they still don't show those wings yet at amain.
Old 04-22-2008, 09:04 PM   #1266
Leikam's Avatar
It's important to note that after talking with many people who have been using spiral cut gears for some time that they recomend a small amount of grease on the ring and pinnion. Spiral gears have a little more friction than standard cut gears and grease is important to keep wear down.
I think grease works the best on the bottom of the bulkheads to seal out dust. if you have to open up the case and remove the diff you can easily apply grease to seal the half that is removed. I use yamaha waterproof grease. i'ts inexpensive and you get a ton of it.
good idea about shaving down the case gigi. I will take a closer look at mine.
I installed a couple of 2mm thick shims on the ring side between the bearing and ring gear and one 1mm on the pinnion in the rear. the mesh was a little tight at first but after a couple of tanks it broke in and is very smooth. after break in i would take it apart, clean the ring and pinnion and re-lube. should be good to go after that.
Leikam is offline   Reply With Quote
Old 04-22-2008, 09:11 PM   #1267
skeller's Avatar
Send a message via AIM to skeller Send a message via MSN to skeller Send a message via Yahoo to skeller
I put 15-18 gallons on a set of our diffs...all were shimmed and broken in as described above then re-checked and re-shimmed after about a half a gallon. Shimming properly is an absolute must.
skeller is offline   Reply With Quote
Old 04-22-2008, 10:37 PM   #1268
pinbuster's Avatar
+1 Shane... Shim it properly and you shouldn't have any problems.
pinbuster is offline   Reply With Quote
Old 04-24-2008, 06:10 AM   #1269
Guys, we are headed to Arkansas this weekend for a series race. I hope everyone is able to get some good racing in as well!
I'll report back monday!
AB
Old 04-24-2008, 01:31 PM   #1270
CHogle's Avatar
Send a message via MSN to CHogle
ive ran about 14 gallons on mine i only sharted shimming them in the last gallon of fuel. opening weekend outside is this week, cant wait
C.HOGLE
Serpent America, Novarossi, O'Donnnell fuel, PT Racing Oils, SMC, H-bomb Designs, Stick it 1 racing, Motor Savor Filters, Fastraxx Hobbies
CHogle is offline   Reply With Quote
Old 04-25-2008, 09:30 AM   #1271
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
well everyone the ocms didnt sell ill race the mugen for a couple of times till i can get a setup on the ocm once i get a setup i might switch back to the ocm and use the mugen as the backup.
cheesecake is offline   Reply With Quote
Old 04-25-2008, 11:22 AM   #1272
Send a message via MSN to Adim_X
I dont understand how switching cars is going to help you with a setup.
Its not like one that suits you is going to magically appear in the next three weeks.
There are many posted on this site, and there are drivers in your area that could help you.
If its a matter of you just wanting to drive the mugen, its all good. I know how it is.
But if you are seriously that far off on a setup, come to Jtec Sunday,
and we can help you get somewhere reasonable that works for you and your car.
90 percent of this things Jay and I would change on the car are in the rear.
We dont even touch the front ends. Its all about playing with camber links, hub spacing, toe, and antisquat.
Jay has his car working really well.
Adim_X is offline   Reply With Quote
Old 04-25-2008, 05:10 PM   #1273
the thing is i run the computer at the local club races and dont have time to deal with setup change. the car was undriveable off power it pushed like a 2wd buggy at wot going through a turn wich means it doesnt turn..... on power it turns all day but indoors at leisure i cant stay onpower and outdoors on a blown out track i cant stay on power the whole time. i know the buggy can be great but i dont have the time to currently make it great. the mooo i have driven before and it seems to not have so many issues to me right now thats the big thing. im going to work on the setup whenever i get time but thats going to be hard to do while running the computer
Old 04-25-2008, 06:29 PM   #1274
Trader Rating: 42 (92%+)
cheesecake what kind of tracks are you running on, Ive fine tuned two setups one for big track,and one for small
icemandolmite is offline   Reply With Quote
Old 04-25-2008, 06:33 PM   #1275
skeller's Avatar
How much do you want for both of your cars?
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 9 04-16-2008 08:46 AM
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 4 04-11-2008 02:38 PM
~~~~~~~/~~/~ OCM Kaos EVO ~/~~/~~~~~~~ Brandon Powell R/C Items: For Sale/Trade 4 02-27-2008 07:08 AM
OCM KAOS!!! nik77356 R/C Items: For Sale/Trade 8 11-11-2007 04:30 PM
so whatever happened to the IP cells dominating the electric market hype? UCHEATULOSE Electric On-Road 34 05-06-2006 02:22 AM
