Old 03-24-2008, 09:59 PM   #1126
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
Originally Posted by Adim_X View Post
This setup is for indoor tracks such as planet rc and leisure hours. These are high bite clay tracks where switch 2.0C and Pink Losi tapers are the tire of choice. The setup is not perfect and I tune each day I am at the track, however it is a good starting point for a really aggressive car. I also run 2mm of washers between the rear upper arm plate and upper plate. I run mugen gray springs up front and mugen blues in the rear. If you are using KMWs i run #2 pistons all around, and 30 wt losi oil with jammin silver springs in front and 27.5 losi with jammin silvers in rear. This is only a recommendation. It gets my car around the track pretty well. However this weekend I am gonna try 4-5-4 in the diffs.
thanks for the setup ill have to get a copy of this when i get home.
cheesecake is offline   Reply With Quote
Old 03-25-2008, 08:14 AM   #1127
Trader Rating: 24 (100%+)
ok guys...talked to the factory last night and everything is ready
now! We apologize for the delays but we really wanted to make sure the
product was ready and improve a few things as well.
Amain Hobbies will be restocked up soon as they should have one of the
orders by the end of the week.
We will also be catching up on any back orders and some left over team
orders.
Thanks for your patience!
Alan Burton
Team OCM USA
ABURTON is offline   Reply With Quote
Old 03-25-2008, 11:17 PM   #1128
thedestroyer's Avatar
thedestroyer is offline   Reply With Quote
Old 03-26-2008, 06:19 PM   #1129
Default Redline .21 engine report....
I to have finished break in getting ready for this weekends regional
race in Florida. I took it out of the box, inspected the internals
(everything was clean and ready), installed it and started the break
in. I chose the heat cycle method which has you running from the
start in 3-4 min cycles. Or once it is up to temp you cut off and let
cool to outside temps. I did this for a tank(4 cycles). I'll also add
the carb was very close for break in from the factory. I then went to
running it a tank at a time letting fuel run through the engine. I did
this 5-6 tanks letting it cool down in between tanks. Each time I
increased the trigger a bit more, at all times being very easy and not
blurping the throttle. So after that I have it at about 75% and I'll
do the rest on the track. Of course do it how you feel comfy and take
your time!
Report so far....
motor has a great sound, feels strong with a smooth range of power. It
looks like it will have plenty of top yet maintaining a good smooth
bottom and mid range. It was easy to run in as and I say use a heat
gun to get the engine over 200 for starts. I sued a OS p3 turbo plug
and tilted 30% nitro. Brad will also be running his this weekend and
we will keep a close eye on runtimes, temps, power, and lifespan and
report back along the way.
Thanks!
Alan Burton
Team OCM USA
Old 03-27-2008, 07:26 AM   #1130
tmperformance1's Avatar
Send a message via Yahoo to tmperformance1
look forward to aggrevating you all weekend. have a safe trip see you sat.
Mugen Seiki,Sidewinder Fuels,Airtronics,O.S.Engines,AKA Products,Ascendency Racing clutches,Fastlane Graphix,TKO,IDRC,M2C RACING
tmperformance1 is offline   Reply With Quote
Old 03-28-2008, 03:17 AM   #1131
thanks for the blue groove setups guys. next time i head to leisure hours ill run 1 of those setups. i really like the team support from all the team drivers if ocm keeps this up they will have a customer forever....
Old 03-28-2008, 03:26 AM   #1132
speedy2's Avatar
//JQ The Car forever/ Soar //Protek-Ace-JR
speedy2 is offline   Reply With Quote
Old 03-28-2008, 03:29 AM   #1133
speedy2's Avatar
the other wing with more Kaos-style wingtips
Old 03-28-2008, 04:14 AM   #1134
DPowers's Avatar
Trader Rating: 79 (100%+)
nice looking body speedy. has any got the truggy yet.
DPowers is offline   Reply With Quote
Old 03-29-2008, 09:16 AM   #1135
Default Best place to buy replacement parts?
Diff rebuild parts,shock rebuild,etc
dragonman is offline   Reply With Quote
Old 03-29-2008, 04:50 PM   #1136
CHogle's Avatar
Send a message via MSN to CHogle
you can look around at the online hobby shops, example Amainhobbies,
Bmainhobbies, or Caralinas R/C, one of those should have it
C.HOGLE
Serpent America, Novarossi, O'Donnnell fuel, PT Racing Oils, SMC, H-bomb Designs, Stick it 1 racing, Motor Savor Filters, Fastraxx Hobbies
CHogle is offline   Reply With Quote
Old 03-31-2008, 10:53 AM   #1137
rdc
Default MARTIN ROCA 4º IN SPAIN
www.netcomrc.com
rdc is offline   Reply With Quote
Old 03-31-2008, 12:18 PM   #1138
speedy2's Avatar
Martin ROCA 4th place at first race Spanish Champships
1. ROBERT BATLLE - HoBao/GRP 82/45:23.039
2. BORJA HERNÁNDEZ - HoBao/GRP 82/45:29.748
3. ANTONIO GOMEZ SALMERON - Nanda/Siim 80/45:07.936
4. MARTIN ROCA - OCM Kaos -80/45:31.491
5. JUANMA VERA 80/45:32.230
6. DANI VEGA - Mugen/Ninja 79/45:10.569
7. ADRIAN PEREZ MAYORAL 79/45:17.048
8. SERGIO MUÑOZ PEREZ (JUN) 79/45:26.631
9. ANGEL ROQUE GAMBERO 78/45:17.770
10. IGNACIO JOSE OLIVA ALVAREZ 77/45:01.795
11. FELIX ZAMORANO 77/45:10.336
12. CARLOS PINEDA VIDAL 75/45:16.388
Old 03-31-2008, 03:39 PM   #1139
Leikam's Avatar
Ran the car this weekend and made the A in The 8 state shootout in Kentucky. I was pumped to put the OCM in the A. There were around 70 pro buggys there so that says a lot about the pace of the car. Had some rear diff issues in the race but thats OK, learned a lot about the weaknesses and how to make the car better.
I spoke with Alan this morning and we talked about the diffs. From the factory the pinnion and crown gears are not shimmed. Make sure you look at both the front and rear diffs and shim it properly. I had an issue with the rear pinnion and crown in the rear end this past weekend and it was due to the play the crown gear had left to right. I did shim the pinnion in 1 shim but you must also move the crown gear in towards the pinnion 1 or 2 shims (whatever you can get in there). The bulkhead allows to much play so shimming is very important. Once done you should be good to go.
Also, I noticed some bearing movement on the outside of the rear bulkhead on the pinnion gear. Keep a close eye on that and replace the bulkhead when movement is noticed.
The front diff seems to be great with no shims. very smooth and quiet--no issues, but i will shim it tonight just to be sure.
I also boiled the rear hubs for 20 minutes prior to the race. I have broken several in the past with one being in the A main in Savannah two weekends ago.:/ I think that helped as I did not break one this weekend. I believe OCM knows of the issue and is reworking the plastic for the future. I plan on installing aluminum ones when i get them.
Had a couple guys ask me about the new wing this past weekend. They saw it on neo-buggy. Sounds like people think its a nice design. I have not recieved one yet, wish i could have advertised it.
Hope this helps ya, --Dave
Leikam is offline   Reply With Quote
Old 03-31-2008, 04:34 PM   #1140
DPowers's Avatar
good to hear you done well with the car and nice report, and are they anymore news on the truggys.
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 9 04-16-2008 08:46 AM
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 4 04-11-2008 02:38 PM
~~~~~~~/~~/~ OCM Kaos EVO ~/~~/~~~~~~~ Brandon Powell R/C Items: For Sale/Trade 4 02-27-2008 07:08 AM
OCM KAOS!!! nik77356 R/C Items: For Sale/Trade 8 11-11-2007 04:30 PM
so whatever happened to the IP cells dominating the electric market hype? UCHEATULOSE Electric On-Road 34 05-06-2006 02:22 AM
