OCM KAOS DOMINATING
#1006
Yeah, the first batch did have issues that OCM resolved and for the customers who had purchased the 1st version, OCM offered a free of charge care pack which included all the parts you mentioned and some.
I don't understand your gripe to be honest.
I'm still running version 1 car with the care pack and it's as good today as it was a year ago.
As for the shocks not being butter smooth, are you running evo shocks?? I ask because the boddies are bigger and don't compress so much on the o-rings, which just happens to make em "butter smooth"
#1007
Razor, if your using the newest bulkheads and shimming your diffs properly, you shouldn't have ANY trouble with the ring/pinion gears.....even the originals. I still have my original 1st run's....they have approx. 14 gallons on them. They are now back ups.
As far as shocks go, the other brands you mentioned do have good shocks. But honestly, our EVO shocks are just as "butter smooth" as any other brand when they are built properly. They may not be the BB's that everyone seems to think is an absolute must have...but they are as smooth and dependable as any other on the market. You should call Alan and go over some things you think we may need to address, he may be able to shed some light on some of your problems.
#1008
#1009
Good stuff Razor,
Glad ya got things sorted.
#1012
Well guys,
I have mixed news. I am happy to say Mike Battaile bumped into the
amain at motorama in only his first race with the car. He then on the
first lap went from 14th - 5th and then got into the lead and battled
with chad Phillips maintaining the lead for almost 20 minutes. He had
some issues that popped up and took him out at 25 minutes while
leading. I will find out and report back
It may have been a broken rear cvd pin.....
man! lol...
man! lol...
#1013
He was fast.I had fun driving with him wish I would have had a luckier weekend but my RC8 just wouldn't hold together and when it did I find a rock to hit my flywheel and cut me off.All in all it was fun cant wait for next year.Alan I am going to email you in a couple of minutes.
#1014
#1015
Well guys,
man! lol...
man! lol...
I feel better, talked with Mike. He said car went through all of
practice, quali's, and a 30 minute main and was perfect. For some
reason the schedule was flipped to adjust for something and gave Mike
only 30 minutes from the 30 minute bmain to his 45 min amain. So he
did not have a chance to go over the rig and it bit him. he has not
had a chance to check but I think his rear cvd set screw came loose
Couple high points he was happy about...
bumped from b and won that by a very nice margin, started 14th in
amain and first lap was in 5th....20 minutes in he had a 22 second
lead on the field. Not bad for the very first run on the ride.
Good job to all of the guys!
#1016
so are the new big bores for the buggy going to be a running change or an option part? If they are going to be included in the new kits I will wait on the kit.
Needing to get a buggy soon. Does it come with a body?
#1017
HEY GUYS NEED A LITTLE HELP
IM TRYING TO RUN ALANS SET UP FROM MIKES FOR INDOOR TRACK
MY KIT CAME WITH ONE SET OF.25 INSERTS AND THEY ARE IN THE MIDDLE POSTION
SET UP SAY RUN.25UP FOR ANTIDIVE
.25DOWN FOR UPPER ARM POSITION
DO I JUST NEED TO ORDER AN INSERT SET
WHAT OTHER INSERTS WILL BE SIMILAIR IN THE MEAN TIME
THANKS LAQUAN
THANKS LAQUAN
#1018
just take a 0.50 or 0 insert
they are just 0.25 mm of center of the 0.25 inserts
that's not much..
that's not much..
#1019
Put a .5 up for antidive and a 0 for the upper arm. That should get you close.
#1020
From Alan Burton at the Nitro Challenge in AZ:
hey guys....
Dustin is super fast and I look for him to make it to the bmain if he
holds together. He honestly had the speed for the main...
He just is learning the pressures of a huge race atmosphere and 30
guys as fast as ryan lutz He was running his mugen for this race. Of
c ourse Mugens dont fall apart but this poor truck is just in bad
shape
Mike had a steering servo go out in his heat(it also was pouring in
his heat). So we got to do it in the last two heats
I had a good run and buggy was pretty good. I was a bit conservative
as always at big races and I think I am 33 or so...
I can pick it up and hope to do that on saturday
I got a loto of pics If anyone can spread this info around the other
forums that would be great and I'll talk to you guys soon!
AB
Of course it rained us out today..lol
hey guys....
shape
AB
