Old 12-23-2007, 02:46 AM   #676
Send a message via MSN to DirtRacer
when will the BB bore shocks be available for the OCM buggy?
RollingDist46
extreme sports and more....
www.myspace.com/m1urathanedist46
www.myspace.com/renegadebearingsdist46
DirtRacer is offline   Reply With Quote
Old 12-23-2007, 06:20 PM   #677
nitrothugg's Avatar
hey A.B.,
thanks for getting back to me and i got it to you!
everyone,
since i didnt put mine together, what are the small plastic pieces shaped like ovals that have the degree digits stamped in them. i see where they capture the hinge pins front/rear, but why would i change the values? i have all of the values from 0 to 1.5 but the 0's are in all four corners.
nitrothugg is offline   Reply With Quote
Old 12-23-2007, 06:24 PM   #678
skeller's Avatar
Send a message via AIM to skeller Send a message via MSN to skeller Send a message via Yahoo to skeller
Originally Posted by nitrothugg View Post
hey A.B.,
everyone,
Those are the toe, anti squat and anti dive inserts. Changing them affects the handeling characteristics of the buggy in many ways. I would advise searching this thread for some setups from other guys to get you started.
skeller is offline   Reply With Quote
Old 12-23-2007, 06:26 PM   #679
DPowers's Avatar
Trader Rating: 79 (100%+)
hope you guys are having a very merry christmas you and your familys.
DPowers is offline   Reply With Quote
Old 12-23-2007, 06:29 PM   #680
skeller's Avatar
The new OCM Rock Crawler......crawling over your cat or your wife's shoe collection soon!!!
Old 12-23-2007, 06:33 PM   #681
DPowers's Avatar
very cool skeller nice.
Old 12-23-2007, 06:39 PM   #682
Trader Rating: 24 (100%+)
here is a setup for you...mine is very good but may be too aggressive for some. It has worked very well for me and begs to be driven hard..
Alan Burton buggy setup:
Front...
front toe insers: 1 deg holes out
upper arm insert: .25 holes up
antidive: .25 holes down
upper arm mount: 2mm shims between mount and upper plate
outer hole on tower
outer hole on arm
kmw big bores w/ blue springs. #1 pistons 450 wt mugen oil
ride height: arms level
width: almost one thread showing on top pillow ball and just over one thread on bottom
steering rack: middle hole, back hole on knuckles
diff: 5k, kyosho orange orings
Center diff: 5k kyo o rings
Rear....
rear toe inserts: .75 holes out
anti squat: 1 hole up
outside hole on tower
outside on arm
rear hub: upper hole(alum hub)
wheelbase: middle
camber link: middle hole inside, middle outside
diff: 3k kyo o rings
kmw bbores w/ blue springs and 400 mugen oil
arms slightly higher than front....slightly
ABURTON is offline   Reply With Quote
Old 12-23-2007, 06:40 PM   #683
Big bores should be available before january is over. We have been working very hard to kick the new year off with a bang!
Old 12-23-2007, 06:45 PM   #684
DPowers's Avatar
what will the price of the shocks be.
Old 12-23-2007, 10:00 PM   #685
KDub75's Avatar
Trader Rating: 14 (100%+)
Other than the big bore shock, what other new/updated parts are going to be available?
KDub75 is offline   Reply With Quote
Old 12-24-2007, 09:51 AM   #686
CHogle's Avatar
Send a message via MSN to CHogle
Default hogle setup for CRCRC/ indoor
buggy ran great this weekend finished fifth in the A in our Ohio points series race ( the car was better than that though). Here's the setup that ive been running for the past few weeks
Cody Hogle's indoor setup:
Front shocks:
37.5 losi oil
OCM blue OR Thunder Tiger RED
7MM front shock spacing
middle hole on the top of the shocks
outer hole on the bottom
.75 toe block in the front
upper arms both shims in back
tie tods are in the firthest back position on both the steering slider and the front hubs
stock sway bar
DIFFS:
5, 6, 4
Gearing:
13 bell, OCM steel 44 sper
Rear Shocks:
35 losi oil
OCM blue
10mm rear spacing
middle hole on top
outside hole on bottom
.75 toe out on the rear
middle inside hole on the upper arm
firthest outside hole on the rear hubs.
little spacer in front of the rear hubs bigger spacer in the back.
wing in lowest position
2 dagrees of camber in front, 1 dagree in the back
Merry Christmas to every one !
CHogle is offline   Reply With Quote
Old 12-24-2007, 09:20 PM   #687
sweet hopefully we ll have them soon over here in Aus. ill definatly grab me some.
RollingDist46
Old 12-24-2007, 09:33 PM   #688
Jason Halvorson's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to Jason Halvorson Send a message via MSN to Jason Halvorson
now that i can get into!!!!!!! where and when??? i want one...
08 Sponsors Thank you for all your support!!!!
TEAM OCM USA
TEAM GO TECH
TEAM PRO TWISTER MODS
TEAM VP PRO TIRES
OCM RACING DT-19 EVO, GO TECH ENGINES PTM'ED
OCM RACING DT-19T PRO, GO TECH ENGINES PTM'ED
Jason Halvorson is offline   Reply With Quote
Old 12-24-2007, 09:46 PM   #689
skeller's Avatar
Jason, I believe they're already here. I think Alan got them in Wed. or Thurs..
Did you ever get his e-mail working?
Old 12-24-2007, 09:52 PM   #690
nope ive tried it a few more times and no luck...i just pmed him again, so hopefully he will see this and check his pm's...
TEAM OCM USA
TEAM GO TECH
TEAM VP PRO TIRES
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 9 04-16-2008 08:46 AM
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 4 04-11-2008 02:38 PM
~~~~~~~/~~/~ OCM Kaos EVO ~/~~/~~~~~~~ Brandon Powell R/C Items: For Sale/Trade 4 02-27-2008 07:08 AM
OCM KAOS!!! nik77356 R/C Items: For Sale/Trade 8 11-11-2007 04:30 PM
so whatever happened to the IP cells dominating the electric market hype? UCHEATULOSE Electric On-Road 34 05-06-2006 02:22 AM
