OCM KAOS DOMINATING
#511
Shane Keller's OCM Kaos EVO Setup
Revised on 1-4-08
Front...
Upper arm insert..... .5 up
Lower arm position(anti-dive).....0.0
Front inboard toe-in position.....0.25 out
Steering knuckle position.....lower hole
Anti-roll bar(sway bar).....Stock
Upper arm Spacer.....All shims behind arms
Camber angle.....-1 deg.
Toe angle.....+1 1/2 deg.
Steering Ackerman Location.....Center Hole
Shock Locations.....Outside Hole at Tower and Arms
Shock Oil.....Trinity 45wt
Shock Pistons.....1.6x2
Springs.....OCM Blue
Rear.....
Toe Block.....Stock
Toe-in Angle.....1.5 Out
Anti-Squat.....0.5 Up
Upper Arm Location at Upright.... Center Hole
Upper Arm Location at Tower.....Inside center Hole
Upright Pin Position.....Lower Hole
Wheelbase....Small Shim in Front, Big Shim in Rear
Camber.....-1.5 deg.
Shock Oil.....Trinity 40wt
Shock Piston.....1.6x2
I run just enough droop to take the pressure off of the shock caps.
2-5 mm pre-load clips.......according to track conditions.
Revised on 1-4-08
Front...
Rear.....
Toe Block.....Stock
#512
http://www.flickr.com/gp/14800045@N03/inRX26
Pics from a money race this past weekend!
Had a lot of southeasts top talent running. OCM TQ'd and won the 30 minute a main leading start to finish!
Buggy was great and really fast, I am very happy as this was def. not a easy field!
Ryan Lopez of Team XRAY finished 2nd with Shane ogden in 3rd....
#514
sweet azz *Thumbs Up*
#516
Shane
set-up not complete..
what diff oils are you using on EVO ?
#518
guys...
when emailing me please use [email protected].
This is the address I use for all OCM related business
Also my phone got left at Taco bell a bit ago and I have a new one coming. Number is still 205.542.8948
Thanks!
Thanks!
#519
WWW.TRESLEONARD.COM
guys check out this link
http://www.tresleonard.com/
His name is Tres and he can do some good work! He needs about two weeks as he is pretty busy. He is going to be making OCM's new sticker sheets for the kits, and also can make custom wraps, wing wraps, etc....
Send him some business
#520
Great Job Alan and Team OCM!!!!! Put on a clinic out there in the Al. race for the people that can't make it like me!!! And we want PICS!!!!!!
