Old 11-15-2007, 02:08 PM   #496
CHogle's Avatar
Send a message via MSN to CHogle
Will do Alan, my setup is simular to the one posted on this form but i do have some things differant.
right now the buggy is hooked up the only place where im gitting beat is in the center of the corners, it has a mid corner push, i was thinking about switching the front swat bar to try to correct this. every other place on the track the car is hooked. ive tried to switch oils and shock positioning and i have as good as its been. I just need a tenth or two an i will be winning races.
CHogle is offline   Reply With Quote
Old 11-15-2007, 02:49 PM   #497
CHogle's Avatar
ive gone to 7000 in the center and droped the back oil from 3000 to 2000 i have 5000 in the front, Alan your setup is now in the car.
Old 11-15-2007, 03:27 PM   #498
speedy2's Avatar
Zixxer
at fr/fr toe insert
is that 0 insert which makes 1 toe out
or insert 1 IN to make 0 or neutral ?
speedy2 is offline   Reply With Quote
Old 11-15-2007, 03:31 PM   #499
speedy2's Avatar
if 1 toe out
that could cause the mid corner push
kevin from australia team said:
If you go from zero toe on arms to 1 degree toe out on arms, it will provide more turn in on turns but will reduce the mid to exit steering.
It's very good where you need quick reacting steering, but the downside is it can make the car a little wandery down the straight and can be a little aggresive.
so stay with insert 1, or 0.75 In "
Old 11-15-2007, 05:50 PM   #500
Trader Rating: 19 (100%+)
. . . so you are at 5ooo Front, 7ooo Center, 2000 Rear .
2000 in the rear should help rotation. I would post you hole set up. What wheel base are you running?
Brandon Powell is offline   Reply With Quote
Old 11-16-2007, 12:54 AM   #501
speedy2's Avatar
Alan
with your set-up starer for evo too
is that 1 insert in : 0
...or insert 1 out : 2 ?? like stted
which is plenty..
Old 11-16-2007, 02:50 AM   #502
speedy2's Avatar
from Vman France
I use 10.000/10.000/3000 diff oils
insert 1 IN fr/fr
and the EVO is dialed
good front traction on exit, good rotation too
Old 11-16-2007, 06:22 AM   #503
speedy2's Avatar
OCM Kaos EVO set-up Gigi 11/2007
Shocks:
Front:
600 wt Oil
1.4mm x 4 hole pistons
Blue OCM Springs
Rear:
750 wt Oil
1.4mm x 6 hole pistons
Blue OCM Springs
550 wt with 1.4 x4 hole pistons
Diffs:
Front 3,500
Center 5,000
Rear 1,000
Fioroni slita MK I clutch carbon shoes
main gear 13/44
+2 mm hubextentions all around
Sway Bars:
2.3 Front/2.8 rear (stock)
adjust the sway bar mounts so they are straight up
and down when the arms are parallel with the ground.
Front End:
Shock location: outside hole on tower, outer hole on arm.
Caster: all the clips in back of the arm.
1 camber
1 toe out at ride height
Upper arm tower insert 0.25 up
kick-up insert (front lower rear insert) 0.50 up
Front lower toe insert 0.75 in. : 0.25 toe out
Ackerman plate position: center hole
Steering block arm: rear hole
Rear End:
Shock Location: outside hole on tower, outside on the arm.
Camber link: inside, middle hole on tower and middle hole on the hub.
Wheelbase: shortest, all washers at back of uprights
Anti Squat: 1.0 up.or 2.50
Rear toe in: 0.50 in. or 3
-3 camber
Old 11-16-2007, 12:58 PM   #504
CHogle's Avatar
yeah, that means that i have 5,000 7,000 2,000 in my buggy
Old 11-16-2007, 01:02 PM   #505
CHogle's Avatar
the weel base is large spacer in the back of the hub and a small spacer in the front .
the hole place ment is the same that alan had posted a few pages back.
Old 11-16-2007, 01:53 PM   #506
Send a message via MSN to DirtRacer
Thats GOOD News
RollingDist46
extreme sports and more....
www.myspace.com/m1urathanedist46
www.myspace.com/renegadebearingsdist46
DirtRacer is offline   Reply With Quote
Old 11-16-2007, 02:13 PM   #507
Originally Posted by bushyar15 View Post
Hmmmm....
Wonder what happened.... I'm pretty certain Alan didn't mis-understand anything. I think OCM ltd got a flood of e-mail, and changed their mind...
I think with the first e-mail/post its pretty clear. I don't think anyone would publish words like that unless their intent was clear. As a business owner, you aren't going to do something to scare away business, especially accidentally by "minced" words...
While this is good news, It makes me very suspicious. It makes it clear to me that OCM ltd could pull the plug at any time.
So, I'm not sure I want to continue with OCM at this point.
Again, I hold nothing against Alan, he's done nothing but a great job!
OCM will never pull the pin on the US Market, the business that you guys have created is just too large to throw away.
I think the biggest thing for you guys in the US, is the fact that Didian (Owner) is moving over there.
That's gotta show OCM's Commitment to the US Market, plus I secretly think he's looking forward to trying out some proper US style tracks...lol
Kev Lewis,
I'd like to thank my personal Sponsors :-AKA Tyres Australia, Ryper Hobbies and Just Hobbies
The Gear :- Associated RC8 B3 powered by OS Engines
Soapy is offline   Reply With Quote
Old 11-16-2007, 03:20 PM   #508
You might test a longer wheel base, should help center - off. It will not feel as responsive on turn in. I am running large spacer in front of hub and small spacer in rear.
BP
Old 11-16-2007, 03:33 PM   #509
Soapy, 2008 should be good. The Evo is just a great car for the money.
Old 11-16-2007, 06:49 PM   #510
damn right it is
RollingDist46
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 9 04-16-2008 08:46 AM
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 4 04-11-2008 02:38 PM
~~~~~~~/~~/~ OCM Kaos EVO ~/~~/~~~~~~~ Brandon Powell R/C Items: For Sale/Trade 4 02-27-2008 07:08 AM
OCM KAOS!!! nik77356 R/C Items: For Sale/Trade 8 11-11-2007 04:30 PM
so whatever happened to the IP cells dominating the electric market hype? UCHEATULOSE Electric On-Road 34 05-06-2006 02:22 AM
