Old 10-26-2007, 04:08 AM   #391
speedy2's Avatar
insert table of the rear toe-in
insert : .1.5 .... 1.25 .....1.0 ......0.75 .......0.50 .......0.25 ........ 0 .........out
degrees 4.00 ...3.75 ...3.50 ....3.25 ......3.0 .......2.75 .....2.50
inserts: ...0.25 .....0.50 ......0.75 .......1.0 .......1.25 .......1.5 ..............in
degrees : .2.25 ....2.00 ....1.75 .....1.50 .....1.25 ......1.0
insert table of the rear antisquat
insert : ...1.5 .....1.25 .......1.0 .......0.75 ........0.50 ........0.25 ........0 .............down
degrees ...0 ......0.25 ......0.50 .....0.75 ......1.0 ......1.25 ......1.50
inserts: ....0.25 .......0.50 .......0.75 ........1.0 ........1.25 ........1.5 ..............up
degrees : ...1.75 .....2.00 ......2.25 ......2.50 ......2.75 ......3.0
insert table of the front kick-up
insert : ..1.5 .....1.25 ......1.0 .......0.75 .......0.50 .........0.25 ........ 0 ................down
degrees .10 .... 9.75 .....9.50 .....9.25 ......9.0 .......8.75 ......8.50
inserts: ....0.25 .......0.50 .......0.75 .. .....1.0 . ......1.25 ..........1.50 ...............up
degrees : ..8.25 ......8.00 .....7.75 .....7.50 .......7.25 .........7.0
insert table of the front toe-in 0-2 block
insert : .......1.5 .......1.25 ...... 1.0.......0.75....... 0.50......... 0.25........0........ . ......... in
degrees ....-0.50..... -0.25..... 0..... +0.25..... +0.50..... +0.75.... +1...
inserts: ........0.25 ....... 0.50 ...... 0.75........ 1.0........ 1.25......... 1.5..............out
degrees : ....+1.25..... +1.50..... +1.75..... +2...... +2.25..... +2.50......
speedy2 is offline   Reply With Quote
Old 10-26-2007, 07:03 PM   #392
DPowers's Avatar
Trader Rating: 79 (100%+)
After the first round of qualifying A.B. sit's in 10th place maybe the track will try out for tommorrow's rounds but good luck A.B. and to the rest of the guys.
DPowers is offline   Reply With Quote
Old 10-26-2007, 07:07 PM   #393
insaneracin2003's Avatar
Send a message via Yahoo to insaneracin2003
definately good luck out there Team OCM!!!! So far AB is sitting 10th......
Paul Schulz
Team Insaneracin
Very Special Thanks to my Sponsors:
Mugen Seiki USA / Mikes Hobby Shop / Byrons Fuels / Gulf Coast Raceway / Insaneracin Designs / Paint by "Smiley"
insaneracin2003 is offline   Reply With Quote
Old 10-26-2007, 09:49 PM   #394
annie_himself's Avatar
Send a message via AIM to annie_himself
At the Pre-Worlds? What class?
annie_himself is offline   Reply With Quote
Old 10-27-2007, 06:54 AM   #395
DPowers's Avatar
pro buggy,
Old 10-27-2007, 07:54 PM   #396
Trader Rating: 24 (100%+)
hey guys.....after all the rounds OCM sits 15th overall! Got a little work to do on sunday but buggy is good Some fast guys are waiting in the semi final race...lol....
Buggy has been flawless in these harsh conditions. It has been a challenge to even finish a 10 minute run. But we did!
later...AB
ABURTON is offline   Reply With Quote
Old 10-27-2007, 07:59 PM   #397
DPowers's Avatar
congrates A.B. good to here your doing good.
Old 10-28-2007, 08:14 PM   #398
jbmccoy205's Avatar
Trader Rating: 47 (100%+)
Default toe-in with #1 insert
In your chart this says to be at 0' but my wheels seem to pretty extreme in left and to the right? is this normal......I'm new so give me a little help.....
jbmccoy205 is offline   Reply With Quote
Old 10-28-2007, 08:58 PM   #399
Jbm, can you tell us which insert you have and at which end of the car you are refering too??
Kev Lewis,
I'd like to thank my personal Sponsors :-AKA Tyres Australia, Ryper Hobbies and Just Hobbies
The Gear :- Associated RC8 B3 powered by OS Engines
Soapy is offline   Reply With Quote
Old 10-28-2007, 09:15 PM   #400
jbmccoy205's Avatar
#1 insert and the front soapy thanks
Old 10-29-2007, 12:55 AM   #401
Okay Number 1 insert facing in towards the chassis will make the lower suspension arms run parralel to bulkheads.
This will change where the wheels are slightly if you've made a huge number change i.e 1.5 facing out to 1.5 facing in.
On the steering links there are turnbuckles (steering tie rods). Rotate these to get your desired toe at the actual wheels.
If your new I would compress car and let go. And where the car ends up settling, this is what's known as ride height.
At ride height adjust the steering tie rods until there is no toe in or no toe out, wheels nice and straight, or give yourself a slight toe in.
This will help make the car track straight and won't have as much aggresive turn in.
There are chapters upon chapters of setup, which I won't go into, but the above should help you do what you intended.
Kev Lewis,
Old 10-29-2007, 04:44 AM   #402
speedy2's Avatar
at the front toe-in plates
you create inboard toe-in/out best neutral or 0, to 0.25 out
at the steering links you create outboard toe-in/out
best 1 to max. 2 out
so 2 different systems
Old 10-29-2007, 05:52 PM   #403
Trader Rating: 61 (100%+)
Congratulations alan on a great run for team OCM .....have a safe trip home brother
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 10-29-2007, 06:36 PM   #404
DPowers's Avatar
cancrats A.B.
Old 10-30-2007, 04:26 PM   #405
Send a message via MSN to DirtRacer
Fantastic work AB keep the momentum.
RollingDist46
extreme sports and more....
www.myspace.com/m1urathanedist46
www.myspace.com/renegadebearingsdist46
DirtRacer is offline   Reply With Quote
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 9 04-16-2008 08:46 AM
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 4 04-11-2008 02:38 PM
~~~~~~~/~~/~ OCM Kaos EVO ~/~~/~~~~~~~ Brandon Powell R/C Items: For Sale/Trade 4 02-27-2008 07:08 AM
OCM KAOS!!! nik77356 R/C Items: For Sale/Trade 8 11-11-2007 04:30 PM
so whatever happened to the IP cells dominating the electric market hype? UCHEATULOSE Electric On-Road 34 05-06-2006 02:22 AM
