Old 10-23-2007, 06:52 AM   #376
Trader Rating: 38 (100%+)
Cool, then you'll probably want to use some type of separator to indicate the break between Spain and the "General" section otherwise it appears to be part of the "Spain" section...
JQ Products "Le Car" - 3 of them. Primary, back-up, and spares car
Bunch of "classic" Schumachers
Tamiya - Leopard 2A6, Tiger 1
HPI - Blitz
bushyar15 is offline   Reply With Quote
Old 10-23-2007, 09:07 PM   #377
Send a message via MSN to DaRaceMasta
(VOID TO BE FILLED SOON)-6MIK Racing- REDS 5TE2-Ninja JX21 BO2-REDs Quattro Clutch C&Alu shoes - Highest DT1100- Airtronics mt4
HIPEX 2108 M Manifold - Podified Race Blend Fuel
DaRaceMasta is offline   Reply With Quote
Old 10-23-2007, 09:11 PM   #378
Send a message via MSN to DirtRacer
all has been finalised and ironed through.
the official name for our forum is "OCMRacers-Forum" feel welcomed and join and enjoy.
http://www.freeforum101.com/ocmracing/
RollingDist46
extreme sports and more....
www.myspace.com/m1urathanedist46
www.myspace.com/renegadebearingsdist46
DirtRacer is offline   Reply With Quote
Old 10-23-2007, 09:41 PM   #379
skeller's Avatar
Send a message via AIM to skeller Send a message via MSN to skeller Send a message via Yahoo to skeller
I signed up yesterday but never recieved a conformation e-mail.
skeller is offline   Reply With Quote
Old 10-24-2007, 07:32 AM   #380
speedy2's Avatar
Soapy
can we have your full set-up of your EVO, please....
speedy2 is offline   Reply With Quote
Old 10-24-2007, 03:39 PM   #381
Default Soapy's EVO Setup
My set-up fella's
Motor ....Sirio
Clutch.....OCM New Carbon shoes with OCM Black 1mm Springs
Tires ......Bow Ties
Front suspension
Blue OCM springs
450 Mugen oil with 1.5mm 2 hole pistons
toe out 1.0 deg at ride height
camber -1. deg at ride height
shock hole location upper middle,lower outside hole
0.75 in insert on front toe plate = 0.25 Deg Actual toe out on arms
0 deg upper arm insert
1.5 Insert down for Anti Dive
Upper arms all the way rearward all spacers in front of arms
Stock Sway Bar 2.3mm
Rear suspension set-up
0.5 Insert in on rear toe plate
.5 down insert on anti-squat plate
-3 camber
roll center middle inside hole on the tower ,middle hole on upright
Upright position when using alloy, use top hole position
shock hole location upper middle hole lower outside hole
blue OCM springs
450wt Mugen oil
Droop with evo kit all the way out on bumpy tracks.
2.8mm Stock Sway bar
Diffs
4 Front.......6 Centre......2 Rear.
If the car needs more steering, I play with front toe insert, Upper arm position and caster angle, but be carefull that you don't start picking the inside rear wheel up in corners if excesive on board toe is applied as this tends to shorten wheel base as weight is applied to front end during cornering.
Kev Lewis,
I'd like to thank my personal Sponsors :-AKA Tyres Australia, Ryper Hobbies and Just Hobbies
The Gear :- Associated RC8 B3 powered by OS Engines
Soapy is offline   Reply With Quote
Old 10-24-2007, 07:13 PM   #382
Trader Rating: 24 (100%+)
hey guys....after the timed practice (seeding process) ocm is in the top 30 at the worlds warmup! Buggy felt great...hopefully I can get a 10 minute run in mistake free. Thats what its gonna take. We got 4 qualis to go thursday and friday. Should be in the top 2 fastest groups....
AB
ABURTON is offline   Reply With Quote
Old 10-24-2007, 10:32 PM   #383
Thats awsum! to hear, well done.
RollingDist46
Old 10-25-2007, 01:22 AM   #384
speedy2's Avatar
soapy
nice but I'm puzzled..
you run front toe plate in toe-out position then ?
but checking my charts
insert 1 out, is o or neutral toe
only 1.25 and 1.50 inset create toe-out....
so 0.75 in insert is - 1.75 negative toe-in....?
Old 10-25-2007, 01:35 AM   #385
speedy2's Avatar
Old 10-25-2007, 05:23 AM   #386
skeller's Avatar
Still haven't recieved a confirmation e-mail for the new OCM site.
Old 10-25-2007, 03:47 PM   #387
Thumbs up
Speedy . Toe plate with a Number Zero insert will give 1 degree actual toe out on arms. So therefore Number 1 degree insert IN will give a Zero Degree actual toe on arms.
I know it sounds confusing. But put a Number 1 insert IN and you can see the arms run parralel to bulkhead.
Hope that helps
Kev Lewis,
Old 10-26-2007, 12:35 AM   #388
speedy2's Avatar
ok got confused because xb8
only allows toe-in applied
I check that out...
Old 10-26-2007, 02:53 AM   #389
speedy2's Avatar
insert table of the front toe-in 0-2 block
insert : .......1.5 .......1.25 ....... 1.0....... 0.75....... 0.50........ 0.25....... 0........ ........... IN
degrees ....-0.50..... -0.25..... 0..... +0.25..... +0.50..... +0.75.... +1...
inserts: ........0.25 ........ 0.50 ....... 0.75........ 1.0........ 1.25....... 1.5....... ....... ... OUT
degrees : ....+1.25..... +1.50..... +1.75..... +2...... +2.25..... +2.50......
Old 10-26-2007, 03:31 AM   #390
That's the one mate, as you can see Numero uno insert gives zero toe.
Good Stuff. I was at work 2day and didn't have a manual to check. Ya got me thinking I'd stuffed up there for a bit..lol
Kev Lewis,
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 9 04-16-2008 08:46 AM
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 4 04-11-2008 02:38 PM
~~~~~~~/~~/~ OCM Kaos EVO ~/~~/~~~~~~~ Brandon Powell R/C Items: For Sale/Trade 4 02-27-2008 07:08 AM
OCM KAOS!!! nik77356 R/C Items: For Sale/Trade 8 11-11-2007 04:30 PM
so whatever happened to the IP cells dominating the electric market hype? UCHEATULOSE Electric On-Road 34 05-06-2006 02:22 AM
