Old 08-28-2008, 06:15 AM   #1966
thecman26's Avatar
Trader Rating: 98 (100%+)
Originally Posted by OCMACE94 View Post
Hey speedy, what did you use to mask that checkered look on the yellow/orange section of your body? It looks great!!
It looks like he might have used drywall joint tape.
Thats what a lotta people use...
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 08-28-2008, 06:46 AM   #1967
rstnboy
You have to use the entire diff assmebly if you use mugen stuff. As you found out the diameter or the outdrive shaft is different. To me it would be worth it to get them as I am really digging the different gearing. Small tracks I use a 16t and use 17t clutch bells on bigger layouts. One of our US drivers used to use the OCM truggy gears but they stripped easy, and now are just about impossible to get. I never ran them in the EVO but I think you will like it.
I just put some mugen bulkheads into my OCM truggy and they seem to work well. It took some time but they fit pretty good. They do change the feel a little bit but not enough to really slow you down. I had them lying around and figured they would be a better fit with the mugen truggy diffs I was already running.
Someone posted about using the TQ bigbores, I will agree that a different set of good quality shocks will make a big difference. I use the mugen shocks which are not super big bores but they work really well and the fluid stays clean.
katjim00 is offline   Reply With Quote
Old 08-28-2008, 07:04 AM   #1968
Trader Rating: 36 (100%+)
Thanks for the info. Did you use the Mugen diffs at all with the OCM bulkheads? Based on my test fit, I can tell I need to do some light dremel work to the chassis and inside of the OCM bulkheads. Are there any more problem areas I might encounter?
rstnboy is offline   Reply With Quote
Old 08-28-2008, 07:48 AM   #1969
Send a message via MSN to Adim_X
Anyone interested in KMW big bores for the OCM. They have machined brass pistons, and the insides of the shock are honed for smoothness. They were about 130 new. I will sell for 65 shipped.
Adim_X is online now   Reply With Quote
Old 08-28-2008, 12:36 PM   #1970
Trader Rating: 19 (100%+)
I used ocm bulkheads[truggy] and the moo diff is a direct fit. Had to put 1 shim on non ring gear side and one shim on pinion. I thought the hole spacing on moo bulkhead was different than ocm, I bought a moo skidplate and it wouldn't line up boltholes.
Dirt's for racing,asphalt's for getting there!
pooldoc is offline   Reply With Quote
Old 08-28-2008, 01:53 PM   #1971
I did use the mugen diff assemblies in the OCM bulkhead on the truggy. The bearing holes are never the same on the ocm bulkheads and wear out quickly because of it. I did not want to ruin good moog diffs so I used the moog bulkheads.
They are not a direct bolt in, you do have to do some dremel work on the ocm metals as well as 2 chassis holes. I even had to take just a little off the shock towers and I mean just a little.
Old 08-28-2008, 02:05 PM   #1972
vnmsgt's Avatar
You might have different shock towers. My OCM Truggy and Pooldocs OCM have different shock towers on them then each other. They are really similar but different.
Check out www.holeshothobbies.com
Now offering support for: Agama, Caster, Serpent, Mugen, HotBodies,VP PRO, Answer-RC and much more.
vnmsgt is offline   Reply With Quote
Old 08-31-2008, 04:27 PM   #1973
Originally Posted by speedy2 View Post
is it the 10.000/7000/2500 diff combination
yes sure is something...
all steering
smokes mbxr and losi now...
I just tried that setup today and it is truly amazing how much steering it has. I actually think I need to tone it down some or at least settle the rear end down. Any suggestions?
Old 08-31-2008, 11:29 PM   #1974
speedy2's Avatar
yes got to work on it, but I busted my tank last we.
and I just gave my spare tank away..
did you use 3.75 rear toe and 2.5 front rollbar?
you could try 7000/7000/2000 and lighter shock oils 500/400
and just 0 insert at front inboard toe
my friend Vman uses 12000/8000/5000 and says
it locks the buggy more in...
gonna test 7000/7000/2000, even 7000/3000/3000
7000/10000/5000
//JQ The Car forever/ Soar //Protek-Ace-JR
speedy2 is offline   Reply With Quote
Old 09-01-2008, 07:24 AM   #1975
I used this exactly as printed:
I think I might also try dropping the rear camber link on the shock tower and possibly add more front caster (move caster spacers to the front of the arms.
Old 09-01-2008, 10:52 AM   #1976
speedy2's Avatar
going softer in the shocks helps too
550/500 or 500/400
Old 09-01-2008, 01:59 PM   #1977
Thanks, I'll give those a shot as well. I didn't mention but I am using the stock rollbars.
Old 09-01-2008, 04:23 PM   #1978
vnmsgt's Avatar
Well from what I can see on my OCM truggy, this is the setup that Alan Burton was running last right before he left as this was his race truggy.
Upper arm position- 1.5 Lower hole
Upper arm spacer- 2 thick ones on rear of arm
Steering knuckle- inner hole
Rear upper arm- center hole on tower, middle hole on upright.
Rear upright pin- upper hole
Rear anti-dive- upper hole
Diffs I do not know.
My shock positions you can see in the pics. He did not have shock mounts so I do not know where he had them
BTW THOSE ARE THE TQ RACING 16MM BIG BORE SHOCKS ON THE TRUGGY. PERFECT FIT AND I HAVE THEM IN STOCK. MADE A HUGE DIFFERENCE COMPARED TO A STOCK SET I PUT ON IT.
THESE SHOCKS ALSO FIT THE EVO BUGGY TOO.
Old 09-02-2008, 07:13 AM   #1979
Trader Rating: 26 (100%+)
Send a message via MSN to BermyDomRepRC Send a message via Yahoo to BermyDomRepRC Send a message via Skype™ to BermyDomRepRC
Default WOW
Hey guys Im not going to lie I had giving up on the OCM untill i tried gi gi or speedys set up.
i got some 16 mm jammin big bores of the swapmeet got new diff housings from hole shot hobbies and tried speedys set up of 10 7 3
55 front shock oil with blue srings and 5o wt shock oil and silver springs in the rear and got to test on sunday
all i can say is WOW
wat a difference the car was great turned great the back was a bit twitchy but it was great im really liking the car now ill practice some more this weekend
but i might go higher on antisguat because the track insnt to rough and maybe move the fron inserts in the front higher right now they are in the middle
damn i want to try 15000 up front but im very impressed this car is easy to drive i gave it to my friend who drives jyosho and he was surpirised howm much steering the car had
thanks gi gi
BermyDomRepRC is offline   Reply With Quote
Old 09-02-2008, 09:37 AM   #1980
speedy2's Avatar
ok, let's work on this to get it even better
putting in 3.75 rear toesettles the rear
but in fact, we own a lot to Vman of France
he just loves this buggy and all the time tries a lot of things
he was at the origine of this set-up...
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 9 04-16-2008 08:46 AM
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 4 04-11-2008 02:38 PM
~~~~~~~/~~/~ OCM Kaos EVO ~/~~/~~~~~~~ Brandon Powell R/C Items: For Sale/Trade 4 02-27-2008 07:08 AM
OCM KAOS!!! nik77356 R/C Items: For Sale/Trade 8 11-11-2007 04:30 PM
so whatever happened to the IP cells dominating the electric market hype? UCHEATULOSE Electric On-Road 34 05-06-2006 02:22 AM
