Old 08-08-2008, 09:14 AM   #1921
I have to admit that using wider hex in Buggy really helps on the corners. What I've done is I used the Truggy hexes on the back. Only one issue is that you need to dremel a bit on the hex pin in the middle so that the fastening screw goes a bit deeper and prevents the pin from backing out as the buggy wheel does not cover the pin hole. Also I put truggy hexes in front but I removed 1mm as I'm running pretty wide wheel base anyway.
Worth trying in both ends
Poinas2 is offline   Reply With Quote
Old 08-08-2008, 12:46 PM   #1922
Hey Shane
I am running the Mugen MBX5R buggy and the OCM truggy. All is working pretty well after fixing some issues with the truggy, it is fast. Poor Mark is now playing catchup to me in truggy lol.
How are things going with you and the family, all is good I hope.
katjim00 is offline   Reply With Quote
Old 08-08-2008, 12:55 PM   #1923
skeller's Avatar
Send a message via AIM to skeller Send a message via MSN to skeller Send a message via Yahoo to skeller
Originally Posted by katjim00 View Post
Hey Shane
We're doin' fine Jim....thanks.
How's Jose treatin' ya?
skeller is offline   Reply With Quote
Old 08-08-2008, 02:47 PM   #1924
Don Julio is my friend, I am down to maybe 3 shots left. I bet Burton never even drank that bottle did he, I bet I wasted it on him
Old 08-08-2008, 03:10 PM   #1925
speedy2's Avatar
you can use mbxR or xb8
+1/+2 mm hubs....
//JQ The Car forever/ Soar //Protek-Ace-JR
speedy2 is offline   Reply With Quote
Old 08-10-2008, 05:57 AM   #1926
speedy2's Avatar
set-up of Theo Assa
Old 08-10-2008, 05:58 AM   #1927
speedy2's Avatar
set-up of asian factory driver Lai Kok Heng
Old 08-10-2008, 06:01 AM   #1928
speedy2's Avatar
set-up of French driver metalking72
Old 08-11-2008, 03:12 PM   #1929
speedy2's Avatar
the kits have for a while now, 1.5 to 3 rear toe plates
instead of to 3.5 degrees
so we had to discount 0.25
in the rear toe-in insert table
Old 08-11-2008, 04:05 PM   #1930
Trader Rating: 19 (100%+)
Might be a stupid question but how do you change caster on this buggy. Seems to me the upper arm spacer as well as the front inbard tor in postion change it. What does the upper arm position do? Thanks
Dirt's for racing,asphalt's for getting there!
pooldoc is offline   Reply With Quote
Old 08-12-2008, 02:29 AM   #1931
speedy2's Avatar
with the pillowball system
if you put the shims in front at the upper arms
you give definitely more caster...
shims at the rear of the arms gives less
more caster means generally less off-power steering
and a bit more on-power
front inboard toeing out can induce a little less caster
and also a shorter wheelbase
due to the arms getting angled more to the rear
so it creates more steeringpower..
as to the upperarm position:
basicely, lower position induces more lowspeed steering
higher more on-power
if you go up at the front insert, you get a bit more caster too
Old 08-12-2008, 03:40 AM   #1932
Thanks speedy2, this is my first pillowball truggy, still chasing the setup. Out track is tight with a lot of hairpins, usually loose. Depending how I take the corner it wants to pudh wide in center or if I take corner tight it wants to swap ends coming out.
Old 08-12-2008, 04:06 AM   #1933
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
pooldoc do you like to drive onpower or off power? that has alot to do with making the truggy turn let me know and i might be able to give you some setup ideas. i learned alot trying alans setups when i had the buggy
cheesecake is offline   Reply With Quote
Old 08-12-2008, 04:21 PM   #1934
Yhis is the setup I used:
OCM Truggy setup 8-10
Front:
Mugen diff and pinion - they don't strip
7000 wt oil
upper arm mount 0*
caster shims 1 thick in back
lower are mount 0* front
lower are mount 0* rear
steering ackerman - middle hole
sway bar - stock strait up and down at ride height
camber -1.5
toe -1
springs - ocm blue
pistons - 1.5
oil - trinity55
top location - 1 in from outer most
bottom location - center
center diff
Kyosho orings in diffs
spur - stock 46 tooth
brakes -advantage disks
7000 weight
rear
mugen diff
3000 weight oil
anti squat - 0.5 up
aluminum rear hubs
camber link - hub location - middle hole
shock tower location - middle hole middle row
hub pin location on arm - upper hole
sway bar - stock - strait up at ride height
rear toe - 1* out
oil - trinity55
piston - 1.5
springs ocm blue
mount location - middle hole in tower and arm
camber -1.5
OS vspecw with fls 2053
fiorini turgo slider 1 hard spring, 2 soft
caster 3 piece mount
2500 mah nimh pack
tires - crimefighter lpr, proline wheels, stock foams 0 offset, dace 6mm adapter
track- lake park
dry clay, loose, sand on top
Truck seems to wash out on entrance to corners,on exit when back on power it wanted to swap ends
Old 08-12-2008, 06:02 PM   #1935
skeller's Avatar
Hey guys, I need to get rid of my OCM stuff. I've got 2 EVO rollers and enough new and used(but still good) stuff to maybe build 1 more.
PM me for details.
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 9 04-16-2008 08:46 AM
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 4 04-11-2008 02:38 PM
~~~~~~~/~~/~ OCM Kaos EVO ~/~~/~~~~~~~ Brandon Powell R/C Items: For Sale/Trade 4 02-27-2008 07:08 AM
OCM KAOS!!! nik77356 R/C Items: For Sale/Trade 8 11-11-2007 04:30 PM
so whatever happened to the IP cells dominating the electric market hype? UCHEATULOSE Electric On-Road 34 05-06-2006 02:22 AM
