Old 07-05-2008, 09:17 AM   #1846
Smile
Anyone have for sale or know where I could get hardened milled chassis?Thanks Lance
lance is offline   Reply With Quote
Old 07-05-2008, 09:36 AM   #1847
vnmsgt's Avatar
You got a pm.
Check out www.holeshothobbies.com
Now offering support for: Agama, Caster, Serpent, Mugen, HotBodies,VP PRO, Answer-RC and much more.
vnmsgt is offline   Reply With Quote
Old 07-08-2008, 08:02 PM   #1848
Trader Rating: 38 (91%+)
Default Kaos DT-19 EVO ARR Wanted
I'm looking for another DT-19 EVO ARR if anyone has a spare to sell. Ever since I started to run a couple, more and more guys are wanting them. I sold 2 of mine and would now like another to setup for a friend and probably another just to have for myself. Pleased so far with the durability and consistent run times that these produce. PM with any rollers or information please. Thanks in advance...
LOSI, AE, Mugen, Kyosho
manynitros is offline   Reply With Quote
Old 07-08-2008, 08:32 PM   #1849
Trader Rating: 24 (100%+)
Send a message via AIM to pistolpete
You have P.M. manynitros.
pistolpete is online now   Reply With Quote
Old 07-08-2008, 08:39 PM   #1850
Default Kaos Pics Please
PM Sent... thanks for the fast response...I'll await some pics...
Old 07-08-2008, 08:49 PM   #1851
Trader Rating: 19 (100%+)
www.Holeshothobbies.com - I received my OCM parts order from them and everything went smooth. All newest version parts, prompt shipping and arrived as promised.
Brandon Powell is offline   Reply With Quote
Old 07-09-2008, 03:44 AM   #1852
Chris at holeshot is the man! Great guy to deal with.
Dirt's for racing,asphalt's for getting there!
pooldoc is offline   Reply With Quote
Old 07-09-2008, 04:31 AM   #1853
vnmsgt's Avatar
Thanks guys. Manynitros you got a PM.
Old 07-10-2008, 07:35 PM   #1854
Trader Rating: 36 (100%+)
I have three different Novarossi engines I have installed in my Kao EVO and all three put the clutchbell too far forward. It is far enough back I can get it to work but it absolutely will not center on the spur. I have used 4 different collets and kyosho and hyper flywheels as well as the OCM one and all line up the same way. I have also tried a Mugen one piece mount and still no difference. Is it just the Novarossi engines or do others do the same thing?
rstnboy is offline   Reply With Quote
Old 07-10-2008, 07:53 PM   #1855
vnmsgt's Avatar
Well I just put a OS .21 VG in my Kaos and it is centered. I think it might be the motor. You said you tried 3 different collets but were they different thicknesses? A thinner one will move everything backwards.
Old 07-10-2008, 08:00 PM   #1856
Default Kaos Mounts
Haven't run into any probs with my GO's. Sounds like you might be drilling and tapping some new threads.
Old 07-10-2008, 08:05 PM   #1857
Default Good Information
Appreciate the info, thanks.
Old 07-10-2008, 10:11 PM   #1858
s porter's Avatar
I've run three Novas in my buggy and haven't had any issues. Doesn't have to be perfectly centered. I like my spur to ride a little further down the clutch bell than centered. Not sure what you have going on there...What clutch setup are you using? Any shims behind the collet?
s porter is offline   Reply With Quote
Old 07-10-2008, 10:20 PM   #1859
yep i have the same problem except with my GO.
it only happened when i installed the hard milled chassis though.
cm27456 is offline   Reply With Quote
Old 07-11-2008, 04:48 AM   #1860
I do have the hard milled chassis as well so maybe that is the problem. As I said, it isn't so far back that it doesn't work, I would just prefer it was more centered. This is the first time it has been an issue.
The collets were if different thicknesses and there was some improvement just not as much as I would like. The thinnest one was actually too thin and the flywheel rubbed against the block.
I thought about drilling and tapping new holes but there wouldn't be enough material to support the threads due to being so close to the old holes.
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 9 04-16-2008 08:46 AM
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 4 04-11-2008 02:38 PM
~~~~~~~/~~/~ OCM Kaos EVO ~/~~/~~~~~~~ Brandon Powell R/C Items: For Sale/Trade 4 02-27-2008 07:08 AM
OCM KAOS!!! nik77356 R/C Items: For Sale/Trade 8 11-11-2007 04:30 PM
so whatever happened to the IP cells dominating the electric market hype? UCHEATULOSE Electric On-Road 34 05-06-2006 02:22 AM
