Old 06-04-2008, 07:07 AM   #1696
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
to use the jammin super big bores you just have to use the jammin standoffs that come with them
cheesecake is offline   Reply With Quote
Old 06-04-2008, 07:16 AM   #1697
speedy2's Avatar
for the jammin BB shocks
I use the OCM evo (or MBXR) shockrods fr/rr
or even jammin up front, and the longer truggy rodends/balls
and standoffs that come with in the set
rest is a direct fit ....use silver springs most
the IDRC steeringballs are very light 22 grs. and strong
feature steel rods with teflon coated cnc alu balls..
dremeling of the frontarms is not that much effective
but still every little bit helps ...
//JQ The Car forever/ Soar //Protek-Ace-JR
speedy2 is offline   Reply With Quote
Old 06-04-2008, 03:17 PM   #1698
pantera nitro's Avatar
AWESOME looking buggy Speedy2!!!
pantera nitro is offline   Reply With Quote
Old 06-05-2008, 06:53 AM   #1699
Word to the wise: Be very carefull using the Jammin shocks on the OCM! The up travel must be limited in the rear (check the front also) to keep the rear drive shafts (CVD's)from getting hung up in the rear diff outdrive cup slots upon landing. If allowed to hang up in the slots, your car WILL break the rear drive shaft close to the diff. Saw it happen 2x on the same race day with the same friend.
toolmbx6 is offline   Reply With Quote
Old 06-05-2008, 01:37 PM   #1700
Leikam's Avatar
+1 on that. poor guy! Gigi, looks good man. Looks nice and clean and ready for Ebay.
Leikam is offline   Reply With Quote
Old 06-05-2008, 03:13 PM   #1701
skeller's Avatar
Send a message via AIM to skeller Send a message via MSN to skeller Send a message via Yahoo to skeller
David..would you call me please?
205-281-3089
skeller is offline   Reply With Quote
Old 06-05-2008, 03:37 PM   #1702
Leikam's Avatar
calling you now.
Old 06-05-2008, 05:28 PM   #1703
Trader Rating: 19 (100%+)
Originally Posted by speedy2 View Post
still using first PRO diffs (except front diff), driveshafts, bell, gear and outdrives
What diff are you running?
Dirt's for racing,asphalt's for getting there!
pooldoc is offline   Reply With Quote
Old 06-06-2008, 01:50 AM   #1704
speedy2's Avatar
front : evo with evo long driveshafts
center/rear: Pro version with Pro driveshafts
if you mean oils 5000/5000/2500
Old 06-08-2008, 06:18 PM   #1705
vnmsgt's Avatar
Well I saw my first OCM Kaos Truggy today (pooldoc's)! It looks sweet. Ran my Caster K8T with him on my track today and was alot of fun. Looks very well built and accelerates like MAD! For you guys that have truggies we did find out today that the Caster K8T lower suspension arms will fit the OCM and are ALOT CHEAPER than Mugen arms. Cannot wait to get my truggy hopefully next week.
Check out www.holeshothobbies.com
Now offering support for: Agama, Caster, Serpent, Mugen, HotBodies,VP PRO, Answer-RC and much more.
vnmsgt is offline   Reply With Quote
Old 06-08-2008, 06:23 PM   #1706
Jeff Werner's Avatar
Trader Rating: 14 (100%+)
Send a message via Yahoo to Jeff Werner
What if any are the difference of the arms?
Jeff Werner is offline   Reply With Quote
Old 06-08-2008, 06:27 PM   #1707
vnmsgt's Avatar
The Caster arms are a little thicker and look stronger. The only difference we could see is the shock mounting positions. The OCM had I think 4 or 5 holes and the Caster Had 2 but there were about in the middle of the OCM holes and were about where he had the shocks mounted anyways. Besides that they looked the same length and everything. The sway bar mount holes were the same too and lined up.
Old 06-08-2008, 07:26 PM   #1708
well that would help in getting parts for the truggy. You have some caster arms in stock?
Jeff
Old 06-08-2008, 07:45 PM   #1709
pumpkinfish's Avatar
Today at the track my friend broke his lower front arm. He didn't have a spare and used a Mugen lower front arm and replaced both so the geometery wouldn't be different side to side. They looked almost identical until we got the whole front back together. When the suspension compressed, the car had really bad bumpsteer. His tires went from 0* toe to about 3* toe-in when pushed down on the nose. Anyone know how to correct this until we can get him new OCM front arms?
Yokomo YZ-2, B-Max4 III
Kyosho RT6
Losi 22b, XX4 Worlds
Associated SC10.2, RC10B2, RC10T2, RC10
pumpkinfish is offline   Reply With Quote
Old 06-09-2008, 03:48 AM   #1710
Yes he has caster arms in stock, I got 2 sets for spares, also got a 3piece caster motor mount. Got my new ring and pinion in and put 6 tanks on it, it's holding up fine.
I notice my rear diff is hot after a run, I'm running 7-10-3, think I need to go up to 5 in rear, rear end comes around too easy. I'm running a vspec traded from a buddy, it's got mad power! I'm running a fls 2053 pipe,didn't think this combo would do so well.
Anyways there's new hope I can keep this truggy rolling, hopefully OCM will release some parts here. I got the ring and pinion overseas, shipping is the only bummer, it;s really expensive, if I run into any more diff issues I'm gonna put mooogen diffs in her.
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 9 04-16-2008 08:46 AM
OCM Kaos DT-19 EVO vino1 R/C Items: For Sale/Trade 4 04-11-2008 02:38 PM
~~~~~~~/~~/~ OCM Kaos EVO ~/~~/~~~~~~~ Brandon Powell R/C Items: For Sale/Trade 4 02-27-2008 07:08 AM
OCM KAOS!!! nik77356 R/C Items: For Sale/Trade 8 11-11-2007 04:30 PM
so whatever happened to the IP cells dominating the electric market hype? UCHEATULOSE Electric On-Road 34 05-06-2006 02:22 AM
