what to use to seal a carb and backplate?
what do you guys use to seal your carb and backplate. I have used automotive RTV but I do not like how it sticks to the seals. I have also used synthetic grease, but that does not seem to work the best.
Is there something out there that works, that does not stick to the o-rings, seals?
JB Weld.
Why would you need to use any sealant ?.
The o-rings that come with it do the job perfectly, if they are not damaged.
There are plenty of good choices when it comes to sealing an engine. The trick is applying the right amount to the right places, of whatever you chose to use. Too much of most anything is (usually) worse than none at all.
Another thing I see a lot of is folks thinking they have an air leak when it's really something else causing the problem.
I use Permatex #2 Form-A-Gasket sealant because it remains pliable for when I tear the engine apart later.
sealit and ferget it...
most any decent silicone sealant will work, but permatex is the best, i use High Temp RTV gasket maker (26B) it is good stuff stays pliable when dry and peels off easily from rubber seals already there when rebuild time comes... i have even used it to make a suspension part that was made of rubber and broke, it worked rather well...
sloopy.
sloopy.
any anerobic sealer is great, easy cleanup later and comes apart easy. Permatex sells a tube for 7$
